Small "whine" I'm hearing now....could it be the DS?
Discussion in 'SRT Hellcat Performance' started by Driver72, Jul 14, 2015.
  1. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,204
    276
    So today I took the Hellcat out for a spin around town for the first time since I had the aluminum DS installed (other than the 7-8 mile drive home after the install).
    I turned the stereo off to do a little cruising and accelerating to see if I could hear or feel anything different.
    I noticed when I was cruising, 40, 50 or so mph, almost like on cruise control, that if/when I just ever so lightly rested my foot on the accelerator, almost barely picking up speed...literally just enough that I wasn't losing speed....I could hear what sounds like a little hum or whine.
    It's NOT the supercharger whine, as it doesn't sound like it's coming from the front. It actually sounds more like it's coming from behind me, and definitely from below.
    I hadn't really tested this before when the OEM driveshaft was in.
    You really need a keen ear to hear it, it's not overly loud and if you give the car any real throttle it's not there.
    It's literally just when cruising and you almost just rest your foot on the accelerator with a minute amount of pressure. Or if you have the stereo on even a low volume it drowns it out. But it's definitely there now.
    Again, maybe it was there stock too, I don't know. But I hear it now, so wanted to see if this was a result of going with an aluminum DS or it's there stock too and I never noticed it.
    Not a big deal if it is a result of the aluminum DS, as the pros outweigh that little con.
    So the question is, has anybody else noticed this?
  2. B5 Blue
    1,743
    I never drive with radio on and noticed mine on the way home when I bought it because of the 55mph limit. Now it's more past 70 that I hear the rear end. I can tell you more after this weekend as I will put my shaft in and will see if it's the same. Driveshafts don't make noise but if the pinion angle changed it MIGHT make a difference but I doubt it.
    If you really have to listen to hear it you're okay IMHO
    usmc341 was really loud
  3. Driver72
    Mar 10, 2015
    1,204
    276
    Good to know that you heard yours stock.
    That's a good point, it may be the rear end.
    I just never paid that close attention to it before. I was wondering "how could a 1 piece aluminum shaft make a whine noise"?
    The connectors are the same as stock, it's just a different shaft. So, yes, it was baffling me that it would be the shaft.
    More than likely it was there since stock, I just never took the time to really listen and pay attention to it.
    You can definitely hear it when you do what I posted in the OP. When I gave it even the smallest amount more of throttle the whine goes away.
  4. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,816
    1,290
    933
    Kenosha, Wisconsin
    Its the diff... A lot of us are having this issue, some worse than others. Some are getting their diffs replaced...
  5. TallCool1
    2,401
    798
    Pacific NW
    So would you hear it during no acceleration? I take mine up to speed but darn it I cannot discern all the noises going on, being un educated what to listen for, not having any experience listening for a diff issue. :confused: I hear something I question what it is, only at certain speeds. Ugh...
  6. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    I heard the same thing when I brought my car home,, and the first 200 miles ,,I haven't heard it in a long time
  7. B5 Blue
    1,743
    When it's really bad you'll hear it all the time. Usually the pinion gear makes noise under load and swerving makes no difference. Carrier gears are the same but swerving can make a diffemce so you need chassis ears to see if that or axle bearings on a solid rear.
    Hope this helps
  8. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    917
    235
    Somewhere, Texas
    Yes & No. I have had the whine for a while and wondered, but once it increased when I lowered the car I knew it was the Dif.
    And when I added the CF DS, it made it worse-technically just due to the fact that it is one pieces vs the 2 piece heavier stocker..
    One look at mine showed wagging heads.
  9. Fast cat
    Sep 23, 2014
    2,255
    713
    498
    Indiana
    I have the same sound and I am 100%stock!
  10. gerlacher
    gerlacher Hellcat Member
    Oct 13, 2014
    94
    21
    Have the same noise, does it exactly as described. Just hardly on the throttle. All stock, 2500 miles on it. Not too concerned with it yet.
  11. DGatzby
    Jan 16, 2015
    3,115
    1,565
    598
    Twin Cities, MN
    Mine exactly since mile #5. I will say at 4000 mi it is not as loud now. Also more noticeable before total warm-up.
    I had a couple of techs listen early. They said wait and see as it wears/breaks-in the lash may change and then potentially all is good. I am going to live with it for a while, we have a monster warranty.
  12. Driver72
    Mar 10, 2015
    1,204
    276
    Thanks guys for all the replies and input.
    If it's been there since stock, well then I've never heard it before. But since many of you have noticed it since stock, well then chances are it has been.
    I don't know if the aluminum DS has made it more apparent or not. I also installed under carriage subframe braces so wasn't sure if that affected anything. Figured there is no way it would, but since it was the very next day that I heard it, those may be a culprit. But again, I was intentionally listening for the DS when I noticed the whine.
    I'll keep my ears peeled to see if it gets worse, better, or no change. If I do notice it getting worse, I'll have them take a look and listen at the dealer sometime.
  13. Link
    Link Silver Member
    Jan 27, 2015
    831
    166
    I have 400 miles on mine and have heard the same thing. Around 40-50 if you barely hit the gas a whine comes from the rear, but doesn't do it under no load. I don't notice it at higher speeds.
  14. Driver72
    Mar 10, 2015
    1,204
    276
    Yup that's exactly it too.
    I was just driving around and noticed it again, but then after about 5-6 miles and a couple quick little blasts up to 90 mph, on my way home, I was cruising at 40 mph and tried to get it to do it, and it would not. Tried it at 50 mph and still couldn't
    So it seems once the rear end warms up a bit, it may go away....maybe why I never noticed it before.
  15. upnorthstar
    upnorthstar Silver Member
    Mar 2, 2015
    390
    116
    I have this noise...it seems normal...never heard of a completely silent diff....of course I would't hear it if it was silent..lol
Similar Threads
  1. Bad Kitty!
    18
    1,100
  2. Bad Kitty!
    32
    1,397
Loading...
