So damn sick of the paddle shifters not working!
Discussion in 'SRT Hellcat TSB's' started by Hemibuck, Apr 19, 2017.
  1. Hemibuck
    Hemibuck Gold Member
    Jan 9, 2015
    1,885
    445
    WA
    I really enjoy using the paddle shifters, especially after the Bondourant course. However I'm so sick of them downshifting when I pull the up shift paddle. They contacted Dodge and they said to update the software and if that doesn't work they will need to pull the valve body to look for debris. It only does it with the paddle shifters not another way so why tear into the tranny?!
    They did the software update and on the way home it was still downshifting when I pulled the up shift paddle. So frustrated because I'm sick of taking it to the dealer and just want to enjoy my car not drive it worried that it's going to act up and redline the calm motor.
    Anyone have any other ideas?
  2. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,530
    4,881
    963
    Not as of yet. Research time. Fnkychkn are you around kind sir?
  3. Hemibuck
    Jan 9, 2015
    1,885
    445
    WA
    Sucks it's truly taking away from the enjoyment of the car. Not that I wanna get rid of it but I may epically if they can't fix it. Maybe they can buy it back and i can get the new one in 2019 when they change the body style.
  4. Hemibuck
    Jan 9, 2015
    1,885
    445
    WA
    fnkychkn. If it's getting a different voltage like my mechanic thinks it is how would you go about fixing that? Is it in one of the boards that relay the signal to the tranny? Makes no sense to me to be cracking open the tranny if it doesn't do it when it's in auto or if you use the stick to shift it.
  5. intercooler
    intercooler Gold Member
    Jan 16, 2015
    221
    187
    798
  6. fnkychkn
    Jan 24, 2015
    1,612
    700
    greasy cardboard box
    This concern seems to only manìfest itself using the paddles. Since it doesn't happen using the shifter mounted switches, this would pretty much eliminate internal transmission components. I vaguely remember posting about this a while back. I am convinced that this is a voltage drop issue, most likely caused by poor connections at the steering wheel harness.
  7. BlackSunshine
    BlackSunshine Gold Member
    Mar 26, 2016
    549
    238
    M6...
    Sorry had to do it after seeing suggestions on other threads.
    • Funny Funny x 2
    • Winner Winner x 2
  8. Pockybreak
    Pockybreak Rookie
    Jun 14, 2016
    2
    Toronto, ON
    Same thing, I think, is happening in my 392.
    I'll be in 2nd gear and use paddles to try and shift up but then it drops me back to 1st....only notice it on those low gears though.
    Sometimes hitting skip button on steering wheel for track playing also goes to previous track instead. Although not sure if that's related to the paddles.
  9. Hemibuck
    Jan 9, 2015
    1,885
    445
    WA
    Thanks I have sent my service guys in this direction. How hard is it to swap the paddles out along with the harness? Are they going to be pulling my dash apart? I'm hoping this will fix it. So frustrating!
  10. fnkychkn
    Jan 24, 2015
    1,612
    700
    No need to disassemble instrument panel. Just the steering wheel.
  11. Hemibuck
    Jan 9, 2015
    1,885
    445
    WA
    Ok. Is there any case or someone I should point my guys in the direction of? Dodge told them the next step would be cracking into the tranny and I don't want that nor do I think it is warranted.
    Also do you know if the paddle shifters and harnesses that are being used now are any different than those a year ago? Seems to me that there are a lot of threads about this but no true fix. Some had the problem fixed with the harness and shifters being swapped but then it would come back. But then others said they have had luck with this as of recently.
    Thanks for all you help I am relaying what you have helped me with to my service adviser and mechanic.
  12. Jefe
    Jefe VIP Hellcat Member
    Aug 29, 2016
    991
    335
    93
    AZ
    There appears to be an extended billet paddle upgrade coming soon from a member in the FB group. You can also pick a color:
    [​IMG]
    Someone asked about the shifting issues and he said its a switch voltage problem but hasn't seen a fix yet. I stopped using my paddles a while ago. Im all shifter now
  13. Hemibuck
    Jan 9, 2015
    1,885
    445
    WA
    Ya saw that, seems cool. Pretty sure the consensus is it's a voltage problem. Even my mechanic thinks that's the problem, however there is still no concrete fix 3 years into the build. Hopefully the new paddles and harness will fix it.
  14. fnkychkn
    Jan 24, 2015
    1,612
    700
    I'll look into it tomorrow and get back to you.
  15. Hemibuck
    Jan 9, 2015
    1,885
    445
    WA
    Thank you very much! I really appreciate it!
