Speed adjusted volume control defaults on
Discussion in 'SRT Hellcat Electronics' started by Johnman, Mar 19, 2016.
  1. Johnman
    Johnman Senior Hellcat Member
    Jan 6, 2015
    57
    28
    Even though it says it is off, it always defaults on, and the only way to turn it off is to turn it "on" then "off". Is there a software fix for this yet?
  2. 06SRT10NR
    06SRT10NR The K.N.O.B. Rules Hellcat Car Club HCC Charter Member
    Nov 9, 2014
    246
    89
    Team Hellcat GA
    Nothing new posted, at least for my VIN. Ever since I had the amp flash done, been stuck with this f'in annoying speed adjusted volume pita, but at least all the speakers work now. Often have to turn it on then off 2 or 3 times before it stays off
  3. Slowpoke387
    Slowpoke387 Gold Member
    Jan 31, 2016
    1,949
    573
    Enfield, CT
    Didnt have this issue until the reflash. Wonder if the 16's have this problem considering they shouldnt need the reflash
  4. VAL
    VAL Silver Member
    Dec 22, 2015
    145
    57
    178
    I have a 2016 and it does have the problem. I love the stereo and in my opinion, it sounds great, but I cannot shut off the speed adjusted volume. I have actually gotten used to it and now kind of like it.
  5. Bandit
    Bandit Gold Member
    Jun 20, 2015
    975
    It's a side effect of the latest flash, and unfortunately it has not been fixed yet. So now it's part of my start-up routine.
    Wait for all systems to become active (hands-free, NAV, wait for red key notification to end)
    Turn speed adjusted volume on then off again
    Hit SRT button twice to activate my custom mode
    Put on seatbelt
    Hey, now I get to drive!
  6. Robert7
    Robert7 Silver Member
    Dec 20, 2014
    133
    52
    178
    Washington
    My 2016 Charger came with this "feature". It is not horrible but it bugs me that something in my car is broken.
  7. Slowpoke387
    Jan 31, 2016
    1,949
    573
    Enfield, CT
    Funny thing is turning it off doesnt work. It's never off. As a matter of fact it works the opposite of how it should. The settings for it actually work backwards. Im surprised Dodge isnt getting bombarded with more complaints.
  8. Bandit
    Bandit Gold Member
    Jun 20, 2015
    975
    It's a pain in the ass for sure, but once the car is on, and you haven't moved yet... if you go turn the feature on then off again, it should remain off till you turn the car off again. Mine was very noticeable after the flash, then I read about this trick... tried it and no more issue. I do hate when I forget to do it though... I start pulling away and go "awwww shit".
  9. Slowpoke387
    Jan 31, 2016
    1,949
    573
    Enfield, CT
    Thanks for the tip - didnt know that was an option. These are the reasons i come here, love the info that is available. Thanks again.
  10. David Neibert
    David Neibert Gold Member
    Jan 15, 2016
    142
    92
    Just brought home a 16 Hellcat Challenger yesterday and other than the radio volume randomly adjusting up and down, I love this car. I checked the speed adjusted volume control in audio settings and it showed to be off. Good to know it's not just me having this issue. So the temp fix is to start car, turn the speed adjusted volume on then off before moving the car ??
    Thanks, David
  11. MN B5 Blue
    MN B5 Blue Hellcat Member
    Jan 30, 2016
    17
    Mine is doing the same. Seems to change the volume at random times. I'll try this trick too once the weather allows me to take her out again. Thanks for the tip!
  12. roadwingsrt
    roadwingsrt SRT Hellcat Supporter Gold Supporting Member
    Jan 24, 2016
    35
    20
    Illinois
    100% confirm that this is happening to my radio too. I called SRT, they want me to take it to a dealer so a tech can hear it and document it. I can prove it with a dB meter in the car. With the setting "Off" from a stop to 25-30 MPH the radio volume rises at least 10 dB.
  13. David Neibert
    Jan 15, 2016
    142
    92
    I did the routine where you turn the Speed Adjusted Volume on and then turn it back off before moving the car for a couple times. Then after a couple days and forgetting to reset it, I was pleasantly surprised to find that it's no longer doing the volume up and down thing.
    David
  14. Radride
    Radride Silver Member
    Jan 15, 2016
    1,097
    208
    198
    Up Here!!!
    I have a 15 and it did this before and after the update. I'm going to have to try this trick because its getting annoying.
    R.K.
  15. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    My latest is performance page locks and intermittently cannot be returned too, unless I go to active running apps and close then re start it. o_O
2015 hellcat speed active volume
how to adjust valume speakers in dodge challenger
how to turn on speed adjusted volume in challenger
speed adjustment volume dodge charger
speed volume control is backwards
what is speed adjusted volume dodge charger
