SRT Active Exhaust disconnected, No check engine light (Solved).
Discussion in 'SRT Hellcat Performance' started by RdRang95, Apr 12, 2015.
  1. RdRang95
    RdRang95 Rookie
    Apr 2, 2015
    11
    So I installed the SLP Loudmouth catback exhaust from my 2012 Challenger SRT 392 on my new 2015 Challenger SRT 392. However, like everyone else, I was left with what to do about the active exhaust setup. Disconnecting it completely throws a code and plugging it back in without being attached to the stock valves throws a new set of codes. I watched the forums for a bit and saw Zoomers had released a system the supposedly solved the engine light problem by just plugging them in and tying them up, which I knew didn't work. I emailed them about it but no one got back to me. So I fixed it myself.....
    [​IMG]
    Using toggle bolts I was able to create stops for the motor. I used a nail that I clipped the head off of to replace the spring in the original setup. The motor isn't concerned about where it stops, just that it stops. Without resistance it just free spins which is what throws the code because it thinks something has failed. Simply install the toggle bolts through the existing bolt holes like in the photo. one thing you cant see is that I etched four very small notches into the plastic ridge around the edges so the toggle could sit in them and keep them from moving. The motor is fairly strong. The notches are super tiny and won't affect anything on the unit. Tied it up out of the way and no light since. It's not the fanciest, but it works until someone comes up with a tune or a device to fake out the pcm.
    • Like Like x 4
    • Useful Useful x 4
  2. RdRang95
    RdRang95 Rookie
    Apr 2, 2015
    11
    Also here's a clip of the exhaust for anyone interested. The cars warmed up it was just really cold that day.
    • Like Like x 5
  3. B5 Blue
    1,745
    nice
  4. Carnage
    Sep 21, 2014
    12,107
    3,271
    823
    Houston, TX
    Nice speaker broke on my phone lol
    • Funny Funny x 3
  5. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    Way to Macgyver that shizzy and make it work!!! Thanks for sharing. Well done!:D
    • Funny Funny x 2
  6. RdRang95
    RdRang95 Rookie
    Apr 2, 2015
    11
    :D
    Thanks guys. I tried to make a plate out of some thin sheet metal first with some tabs as stoppers. But the motor base is too uneven and only one bolt hole lined up nicely. This soultion was faster and worked juat as well. I'm going to try to trace the wire back a bit and see if maybe it runs out of the trunk or something. The motors are tied up outta the way but I'd feel more comfortable with them out of the elements over the long term.
  7. TallCool1
    2,432
    813
    Pacific NW
    Very creative.
    • Agree Agree x 3
  8. redlinegw
    redlinegw Rookie
    Feb 24, 2015
    22
    got any better pics?
  9. B5 Blue
    1,745
    Bigger pic needed
    • Agree Agree x 3
  10. RdRang95
    RdRang95 Rookie
    Apr 2, 2015
    11
    [​IMG]
    Sorry been a way for a little bit. Here's a MUCH larger photo of the setup. And an update: Had this Installed since March, no codes or failures of the mod at all.
  11. redlinegw
    redlinegw Rookie
    Feb 24, 2015
    22
    Thermal R&D did the same setup with our Hellcat and it still threw a code, however they have 10 SRT 392 cars with this setup and no code. We had to put the stock exhaust back on our Hellcat until it gets figured out. I think something is different between the Hellcats and the SRT 392 cars.
  12. RdRang95
    RdRang95 Rookie
    Apr 2, 2015
    11
    Seems strange. The exhausts are Identical on the 392's and Hellcats. I wonder if maybe the hellcat needs more information about the position of the valves rather than just whether it stops at both ends or not. Seems unlikely though since the valve motors are the same and most likely broadcast the same amount of information.
  13. redlinegw
    redlinegw Rookie
    Feb 24, 2015
    22
    Not sure, it is frustrating because the Thermal exhaust sounds so much better! I wonder if there are any other Hellcats on here with custom exhaust that don't have the check engine light on. I sure wish someone would come out with something that could just plug in and be done with it.
  14. stoneipa
    stoneipa Rookie
    Sep 4, 2015
    21
    What does the valve actually do?
  15. Milspec
    Milspec Silver Member
    Feb 15, 2015
    206
    43
    I think it opens the exhaust up more during acceleration.
2015 challenger active exhaust throwing code
2015 challenger exhaust code
2015 dodge challenger active exhaust
hellcat active exhaust
how does active exchust work on challenger
how does the challenger active exhaust work
how to disable active exhaust on challenger
