SRT Hellcat - 2017 ZL1 - GT500 - Z/28 - Spec Comparisons
Discussion in 'General Automotive Discussion' started by rayzazoo, Mar 17, 2016.
  1. rayzazoo
    Nov 8, 2014
    3,478
    1,287
    668
    Engine Performance
    GT500 Engine - Trinity
    2013 Ford Shelby GT500 Trinity 5.8L V8 - Power Of Three - 5.0 Mustang & Super Fords Magazine
    662hp @ 6500 rpm / 631tq @ 4000 rpm (rated)
    ZL1 Engine - LT4 Compact Powerhouse: Inside Corvette Z06’s LT4 Engine
    650hp @ 6400 rpm / 650tq @ 3600 rpm (rated)
    646hp @ 6400 rpm / 656tq @ 3600 rpm (measured)
    Z28 Engine - LS7 Race Proven LS7 7.0L V-8, Ruthless Pursuit of Power: The Mystique of the C6 Corvette LS7 Engine - Page 1 of 26 - CorvetteActionCenter.com
    505hp @ 6100 rpm / 481tq @ 4800 rpm (rated)
    SRT Engine - Hellcat We Take A Hard Look At Dodge's Paradigm-Shifting 707hp Hellcat Hemi
    707hp @ 6000 rpm / 650tq @ 4800 rpm (rated)
    714hp @ 6200 rpm / 652tq @ 4800rpm (measured)
    Heat Dispersion
    Trinity (5W-50 oil), with a 2.3L Eaton supercharger, cycles coolant (temperatures up to 230 degrees) through oil-to-water cooling. Extended track driving will raise oil temps closer to 300, which is why open-track fans need the Track Cooling package. The PCM will start closing the throttle and limiting engine speed when the coolant hits 251; de-rating the engine.
    LT4 (0W-30 oil) (current without the added heat exchangers of the new 2017 ZL1), the 1.7L Eaton Style Roots blower cycles the coolant (up to 248 degrees) through a single front mounted intercooler mounted right in front of the engine radiator. The LT4 coolant to oil cooler is mounted next to the catalytic converter. The rated horsepower is only valid under normal highway use for a limited period of full-throttle time. Once the air charge temperature elevates to levels where detonation and knock begin, the engine controller limits ignition and boost; de-rating the engine.
    LS7 (15W-50 oil) with a naturally aspirated 7.0L engine, like most road racing engines, the Z/28's dry-sump system includes an engine oil cooler. It is an oil-to-coolant heat exchanger originally developed for the C6 Corvette ZR1 and is bolted to the oil pan on the driver side of the engine. The large-capacity reservoir, combined with a high efficiency air-to-oil cooler, provides necessary engine oil cooling under the demands of the engine’s power output. The Small-Block does not have coolant flowing completely around the valve seat inserts. Because of the siamesed valve seats, there's no cooling at all in the "valve bridge" between the ports. When things get extra hot, you want rapid transfer of heat away from the valves and seats and into the water jacket. For that reason, the exhausts use "copper-infiltrated" seat inserts.
    Hellcat (0W-40 oil), with a 2.4L whipple-like twin screw blower, generates less heat due to supercharger efficiency and cycles the coolant (temperature does not exceed 220 degrees) through two intercoolers; with the supercharger coolant entering the first, driver side mounted intercooler before heading out for the main center mounted main intercooler. Hellcat employs a front mounted oil to air intercooler mounted behind the passenger side fog light opening. This system is so effective that the Hellcat can be driven for 20 laps on a 3.1-mile road course in 100-degree ambient heat without the engine power de-rating.
    Tires
    Calculated out and based on recommended factory tire pressures and curb weight distribution (full tank of gas, no driver)
    Contact Patch Area
    52.32 sq/in front; 49.38 sq/in rear - GT500 (2013-2014)
    52.22 sq/in front; 51.43 sq/in rear - ZL1 (2017) est
    54.93 sq/in front; 51.22 sq/in rear - Z/28
    58.96 sq/in front; 47.86 sq/in rear; 50.00 sq/in with 30 psi rear - Hellcat (2015+); 52.35 sq/in with 38 psi front
    GT500
    265/40ZR19 (98Y) front; 285/35ZR20 (92Y) rear - Goodyear Eagle F1 Supercar G2 - GT500 (2013-2014)
    35psi factory recommended inflation - manual coupe curb weight 3852lbs
    220 AA A; 8/32 tread depth; 29lbs front - 220 AA A; 9/32 tread depth; 29lbs rear
    ZL1
    285/30ZR20 (100Y) front; 305/30ZR20 (104Y) rear - Goodyear Eagle F1 Supercar (pending new model) - ZL1 (2017)
    estimates until actual data is released
    32psi factory recommended inflation - auto coupe curb weight 3949lbs (est)
    220 AA A; 8/32 tread depth; 31lbs front - 220 AA A; 8/32 tread depth; 32lbs rear
    Z/28
    305/30ZR20 (104Y) front/rear - Pirelli PZero Trofeo R
    32psi factory recommended inflation - manual coupe curb weight 3820lbs
    60 AA A; 5/32 tread depth
    Hellcat
    275/40ZR20 (106Y) front; 275/40ZR20 (106Y) rear - Pirelli PZero or PZero Nero - Hellcat (2015+)
    32psi factory recommended inflation (32 psi front/30 psi rear recommended track use) - auto curb weight 4439 (2015)
    220 AA A; 10/32 tread depth; 34lbs front/rear
    400 AA A; 10/32 tread depth; 35lbs front/rear (Neros)
    Wheels
    19 x 9.5-in front, 20 x 9.5-in rear, forged-aluminum wheels - GT500 (2013-2014)
    19 x 11-in front, 19 x 11.5-in rear, forged-aluminum wheels - Z/28
    20 x 10-in front, 20 x 11-in rear, forged-aluminum wheels - ZL1 (2017)
    20 x 9.5-in front, 20 x 9.5-in rear, forged-aluminum wheels - Hellcat (2015+)
    Brakes
    15.00-inch (381mm), 2-piece front rotor, 6-piston caliper - GT500 (2013-2014)
    15.50-inch (394mm), 2-piece front rotor, 6-piston caliper - Z/28
    15.35-inch (390mm), 2-piece front rotor, 6-piston caliper - ZL1 (2017)
    15.35-inch (390mm), 2-piece front rotor, 6-piston caliper - Hellcat (2015+)
    Of note, more on the topic of carbon-ceramics: Cadillac's data showed that, to realize the benefits of carbon-ceramic brake rotors over iron ones, the pieces would have to be quite large (in this case, larger than the stock 15.35 in rotors). For reference, the Z06 uses 15.5in carbon ceramic matrix rotors on their Z07 performance package). The listed benefits of carbon ceramic brakes are 50% less weight than iron rotors, they do not corrode, and should last longer. Why You Should, Or Shouldn’t, Upgrade to Carbon Ceramic Brakes » AutoGuide.com News
    Driveshaft
    1-piece Carbon Fiber - GT500 (2013-2014)
    tbd - ZL1 (2017)
    2-piece Steel - Hellcat (2015+)
    Suspension
    Magnetic Ride Control Dampers - GT500 (2013-2014)
    Magnetic Ride Control Dampers - ZL1 (2017)
    Hydraulic Active Damper - Hellcat (2015+)
    Steering
    Electric - GT500 (2013-2014)
    Electric - ZL1 (2017)
    Hydraulic - Hellcat (2015+)
    Transmissions
    GT500
    (2013-2014) -
    6-speed Manual Tremec 6060
    ZL1 (2017) -
    10-speed Automatic Ford/GM with a 7.39 overall gear ratio (2.85 rear axle) - Holy Shift! A Look inside GM’s new 10-Speed Automatic
    Z/28 -
    Hellcat (2015-2018) -
    8-speed Automatic ZF with a 7.00 overall gear ratio (2.62 rear axle)
    Weight to Power Ratios (lower is better)
    7.90 lbs / tq (avg) Hellcat
    6.86 lbs / tq (avg) ZL1 (est)
    16.04 lbs / hp (avg) Hellcat
    13.41 lbs / hp (avg) ZL1 (est)
    GT500 (2013-2014)
    3852 lb coupe manual (57%/43%)
    3970 lb convertible manual (56%/43%)
    ZL1 (est) -
    3949 lb coupe auto (52.7%/47.3%) (est)
    3920 lb coupe manual
    4203 lb convertible auto
    4174 lb convertible manual
    Z/28
    3820 lb coupe manual
    3602 lb (est) coupe - 2018
    Hellcat
    4476 lb auto (2016) (57%/43%)
    4470 lb manual (2016) (57%/43%)
    4439 lb auto (2015) (57%/43%)
    4449 lb manual (2015) (57%/43%)
    [​IMG]
    Comparatively
    2016 Z06:
    3524 lb coupe
    3582 lb convertible
    2016 Viper:
    3366 lb Base
    3390 lb T/A 2.0
    3390 lb ACR
    3415 lb GTS
    • Useful Useful x 2
  2. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,491
    Albany NY
    Yeah they're chasing the magic 707... still can't get there... and the best part our 707 is just a carrot... a minor tweak by Dodge up goes our number.;) It has to be discouraging for the Bowtie & Blue Ovals guys.
  3. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    319
    Jacksonville, FL
    And I shed a tear
  4. BODUKE
    BODUKE Gold Member
    Jan 31, 2015
    1,694
    395
    Detroit
    I don't they need to hit 707. Its the rwhp that matters. The ZL1 is lighter and shouldn't have the heat soak problem. The 10 speed auto will make it fly.
  5. carcass
    carcass Silver Member
    Sep 7, 2015
    857
    263
    173
    I like the left chicken wing it's much more tasty than the right one
    • Funny Funny x 2
  6. rayzazoo
    Nov 8, 2014
    3,478
    1,287
    668
    I think that is accounting for the sunroof weight. Without it, and you'll probably have the weight of the 2015.
    • Funny Funny x 1
  7. rayzazoo
    Nov 8, 2014
    3,478
    1,287
    668
    Sunroof is optional equipment on a 2016 at the price of $1,995. I remember when the sunroof on a Challenger was a $995 option.
  8. Sean99
    Sean99 Senior Hellcat Member
    Apr 13, 2015
    117
    23
    48
    KS
    Correction on the ZL1: It is 640 hp and 640 tq, not 650. It's detuned so it doesn't compete with the Z06.
  9. Mills
    Mills Silver Member
    Jan 28, 2015
    712
    166
    Airdrie, Alberta
    Agreed. But the Hellcat also makes well over 707 from trap speeds recorded (rwhp like you say), and will do it over and over.
    While the ZL1 will be by far the best Camaro they ever built (expect for those 2000's F bodies of course ;)) it will not be as fast as the Z06, but the front end "openness" leads me to believe it will be a more consistent car. You KNOW GM is already at work on the next Vette...and it will be a CRAZY machine (as if the current C7 isn't already - probably the best all around car for straight line, twisty's, comfort, and price...IMO)
    I think the ZL1 will be a dynamite car, just like the Hellcat is, and certainly just like the GT500 is
  10. rayzazoo
    Nov 8, 2014
    3,478
    1,287
    668
    Very true, I'll update once they get the ZL1 spec sheet published as the only data they've got is the SAE dyno Z06 and CTSV specs.
  11. rayzazoo
    Nov 8, 2014
    3,478
    1,287
    668
    Camaro6.com forum has the 2017 ZL1 Camaro Order Guide.
    Some key 2017 ZL1 specs:
    - 650 HP / 650 TQ (LT4 engine)
    - 10-speed automatic; 2.85 rear axle
    - 6-speed manual; 3.73 rear axle
    - Magnetic Ride Control
    - Brembo 6-piston front and 4-piston rear, performance, 4-wheel antilock, 4-wheel disc
    - 20" x 10" (50.8 cm x 25.4 cm) front and 20" x 11" (50.8 cm x 27.9 cm) rear Dark Graphite premium paint, forged aluminum
    - 285/30R20 front and 305/30R20 rear, blackwall, summer-only
    - electronic limited slip (eLSD)
    - Driver Selector Mode, up to 4 modes available for various driving conditions - Snow/Ice, Tour, Sport and Track (SS and ZL1 models only)
    - Teen Driver mode, a configurable feature that lets you activate customizable vehicle settings associated with a key fob, to encourage safe driving behavior. It can limit certain vehicle features, and it prevents certain safety systems from being turned off. An in-vehicle report gives you information on your teen's driving habits and helps you to continue to coach your new driver
  12. Aaron Vogel
    Aaron Vogel Gold Member
    Jan 23, 2015
    1,460
    265
    Everywhere
    Also, the Hellcat driveshaft is steel not AL
  13. Cglhawk260
    Cglhawk260 Silver Member
    Jul 20, 2015
    339
    117
    CT
    They put a decent size wheel and tire out back.
  14. nocarbutmopar
    nocarbutmopar Silver Member
    Oct 21, 2015
    399
    120
    New Mexico
    I think i read somewhere on here a while back something about additional HP on the Sunroof cars?
  15. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,344
    825
    Suwanee, Georgia
    Looks like They heard the Hellcat owner's bi**hing LOL and improved their own.
    • Funny Funny x 1
2017 camaro zl1 vs hellcat
2017 carmaro verses hellcat
2017 hellcat challenger specs
2017 zl1 vs hellcat
camaro zl1 vs challenger hellcat
new camaro zl1 2017 forum
zl1 vs hellcat
