Stage 3 with 2.65 pulley and injectors.....dyno numbers??? 93oct and E85???
Discussion in 'SRT Hellcat Performance' started by shakenbake, Jun 28, 2016.
  1. shakenbake
    shakenbake SRT Hellcat Supporter Gold Supporting Member
    Apr 29, 2016
    151
    136
    413
    I just ordered the stage 3 ID motorsports/bwoody kit. I went with the 2.65 pulley. Curious if there is anyone with this combo and what numbers they put down on 93 octane.
    Im also going to ask about an e85 tune as well.
    Thoughts?
  2. BAADCAT
    BAADCAT Senior Hellcat Member
    Apr 14, 2016
    141
    35
    The Great State of Texas
    I would be curious as well. I am going with same setup but local dyno tune by Alex P.
  3. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,066
    650
    413
    So Cal
    I would not run the 2.65 with 93 octane I was getting over 17lbs of boost with that pulley to high for pump gas IMO ;) If your going to run the 2.65 go with e85.
  4. BAADCAT
    Apr 14, 2016
    141
    35
    On Just the upper? That sounds pretty high.
  5. Billet Hellcat
    Dec 2, 2014
    1,066
    650
    413
    So Cal
    Yup just the upper + 5-6lbs stock is 11psi
    Call HHP the recommend the 2.85 for pump gas.
  6. Wack_Cat
    Wack_Cat Silver Member
    Feb 5, 2016
    207
    34
    Northern Colorado
    I'll be running 2.50 on 94 with ID tunning.
    With heat exchanger.
  7. Link
    Link Silver Member
    Jan 27, 2015
    895
    206
    HHP says 2.85 is highest recommended for 93 octane.
  8. Mills
    Mills Silver Member
    Jan 28, 2015
    762
    190
    Airdrie, Alberta
    Maybe for sea level guys...
  9. shakenbake
    Apr 29, 2016
    151
    136
    413
    Im gonna give it a shot. 2.65 with 1000cc injectors. We shall see
  10. Wack_Cat
    Feb 5, 2016
    207
    34
    Northern Colorado
    Ya if you look at most builds on here they are at sea level. Which would be awesome. But every car is different.
    Mine is 2.50 with 94 mix, but I'm at 5000 feet. Everyone I talked to had a different idea. Most said e85 was a bad idea and I understand that cause we run a race car on that and it's a pain. It would be even worse as a daily driver cause every station is different.
    I know of several cars making over 800 at sea level with stock injectors on a 2.7 pulley but 90% will tell you that you have to have injectors.
    You have to take what you have read and heard and make you own decisions, or play fallow the leader.
    There are a lot of things they won't tell you about the car. At the end of the day it's all a business and they are here to make money, and be the best.
    Is the car a daily driver or a weekend warrior. Can you afford the car to sit. How fair do you want to push it.
    Just my two cents.
    • Agree Agree x 4
  11. shakenbake
    Apr 29, 2016
    151
    136
    413
    Here in Ft Worth were at 653ft above sea level
  12. Wack_Cat
    Feb 5, 2016
    207
    34
    Northern Colorado
    See much different from where I'm at. So yes I would follow the basic recipe
  13. Cimon hellcat
    Cimon hellcat SRT Hellcat Supporter Gold Supporting Member
    Aug 9, 2015
    234
    132
    It's not going to work go with 2.85 it's better and safe .
  14. BAADCAT
    Apr 14, 2016
    141
    35
    From what Alex Peitz, Serious HP and Fastlane down here in Houston are telling me they have a ton of cars running 2.65 and smaller pulleys. Many with the ATI OD pulley as well. One was E85 the other 93. So why does everyone keep saying anything less than 2.75 is unsafe?
    "That car has a 2.65 upper and a 10 percent lower with E85 and a custom fuel system. We kept it conservative on the non-nitrous tune."
    "We usually do the upper and lower pulley at the same time. 10% overdrive lower and 2.65 upper will give you right below 18psi of boost."
  15. Wack_Cat
    Feb 5, 2016
    207
    34
    Northern Colorado
    Yes I agree. There are many cars out there running small pulleys. I think the form is getting to that point where info is getting confusing.
