Start up question
Discussion in 'Dodge Challenger SRT Hellcat' started by magnummrk, Jun 1, 2015.
  1. magnummrk
    magnummrk Platinum Member
    Sep 30, 2014
    3,828
    1,116
    918
    Wisconsin
    My car has about 1500 miles on it and it started doing something odd a few weeks ago.
    On start up it idles up normally then stumbles almost like it wants to stop. Then it runs normal.
    Today after I washed it I had the door open and noticed a little smoke on start up. Again the runs fine. The only thing I have done to it was put in the green air filter. Wondering if that might be the cause of it
  2. gabe
    gabe Gold Member Hellcat Car Club
    Dec 24, 2014
    728
    354
    My car on start up shock for 2 or 3 seconds and then it was fine. It started doing that last Friday and after driving it for 5 min. the check engine light went on with code p0300.
    My hellcat challenger has 1400 miles.
  3. B5 Blue
    1,748
    MM need better story like engine temp ambient temp all the time etc.
  4. Snappycat
    Jan 22, 2015
    3,557
    1,118
    The I.E. So. Cal
    Gabe....what did you find out? I remember your post from last week.
  5. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,518
    1,435
    818
    Endless Mtns of Pa
    only one time I saw any smoke... I started it and pulled it right out of garage and shut it down still cold... when I started it a while later I saw a little smoke.. I wrote it off as the rich hi idle never fired off the cats and when I went to restart there was a bit of residuals to burn off.. maybe the rich fuel washed the cylinders a bit so it smoked a second when refired?
  6. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,782
    2,050
    B5 are you putting the green air filter in your hellcat?? Mines been in from Dec...Really no issues,, when I start the car cold, it sounds like it has a little cam,, but no issues..Only going to have it a few more weeks..That's when I hope to have my CAI
  7. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    Odd I have the same symptoms you describe immediately after fuel rail was replaced, minus smoke, at 1380 miles. Except last 2 cold starts the car did die, after it fired up, and stumbled. Taking in this weekend to diagnose problem. No DTC set I can find using torque software. Oem air filter. Always pure gas. Built November 2014. Search fuel rail and my tag name you'll see my history on this. Will let you know what I find. (Prior to fuel rail swap it never did this once always started ran perfect. Happened immediately after rail replaced 1st cold start. Never does it when engine's warm.)
  8. hellcat1
    Sep 27, 2014
    10,782
    2,050
    And this is no reason I'm not in a hurry to get my fuel rail done,, that and they want the car over night,,, just something about leaving my car that long for a two hour job,,I don't like it.. Btw mine was built oct 15
  9. B5 Blue
    1,748
    I was but haven't yet it's still in the R/T you wanna sell yours?
  10. B5 Blue
    1,748
    fnkychkn is a check valve or pressure regulator part of the fuel rail?
  11. American Muscle
    American Muscle Silver Member
    Apr 23, 2015
    278
    83
    Green air filter? Is that like a K&N or similar filter with better flow over the stock? If so did you let it map air/fuel before driving? Anytime you change something that improves air flow you have to let it map so it doesn't lean out. It's almost like breaking in the car all over again so it knows how much fuel to add at various throttle positions from idle to wide open.
  12. gabe
    Dec 24, 2014
    728
    354
    No dealership in Austin would see my car because they had a 15 day waiting list. So I have an appointment on the 15th of June.
  13. dHL0L
    dHL0L Gold Member
    Apr 7, 2015
    304
    159
    Racine, WI
    Mine did something like that the other day, 780 miles on it. Started up and it sounded real choppy, let it rest in idle and it calmed down. Pulled out and going into second gear it almost died. Drove around for a few minutes and didn't have the problem again. It had sat for about 10 days without being ran so I figured it just needed to be warmed up....but maybe it's more than that.
  14. gabe
    Dec 24, 2014
    728
    354
    My car isn't a daily driver. I drive it 2 or 3 times on weekend and put around 30 miles.
  15. hellcat1
    Sep 27, 2014
    10,782
    2,050
    B5,, I will sell it after I get my kit.. Like gabe my car gets driven only 1 or 2 times a week,, but my green filter went in with like maybe 100 miles on it, then sat for four months in sleep mode
2015 hellcat cold start
hellcat cold start rpm
