Sticking brake pedal
Discussion in 'SRT Hellcat General Discussions' started by Hubbs, Feb 3, 2016.
  1. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    One of the cars at the SRT Challenge I attended last year had a weird, clunky brake pedal. The guys said they were aware of it and their mechanic team had replaced everything, but couldn't fix it.
    My HC just started doing the same thing. Every once in awhile the pedal sticks slightly as I start to press it. It doesn't take a lot of pressure to overcome the "stick", but it does throw you off a bit when it happens. It's also pretty annoying.
    There's no squeak or other sound when it happens. I need to watch it a bit more to see if it only happens when the brakes are warm or cold.
    Anyone experience this? Any ideas?
  2. blaze
    blaze ☆★✪ The Watcher ✪★☆ Hellcat Car Club Gold Supporting Member
    Dec 28, 2015
    2,030
    973
    498
    26.7100° N, 80.0500° W
    air in the brake lines? if it were me i would start with brake system physical components, process of elimination then move to the ECM components..
  3. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Wouldn't air just make the pedal spongy? I figure it's probably something with the linkage or master cylinder, but want to see if anyone's run into this yet.
  4. Angel
    Angel Gold Member
    Aug 19, 2015
    1,357
    724
    413
    League City, TX
    That's strange indeed
  5. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    It seems to do it randomly and all brake temps. It only happens about 1 out of every 10 times I push the pedal and doesn't do it at all if I sit still repeatedly pushing the pedal. Weird indeed! I was hoping someone else has seen this problem since it's my 2nd time to see it.
  6. fifty
    fifty Active Hellcat Member
    Jan 22, 2017
    150
    26
    28
    Did you ever get this resolved?
    If it's not something in the pedal linkage itself, it almost sounds like a seal is folded or ripped and getting caught in the M/C or the pistons.
    Even worse a sticking valve in the abs block
  7. fnkychkn
    Jan 24, 2015
    1,534
    642
    greasy cardboard box
    Sticky booster inlet valve???
  8. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Never got it resolved since the dealer just says CND on anything they can. Luckily it's pretty much gone away over time. I'm betting on the dragging seal idea. That's what it feels like. No biggie, just an annoying feeling.
  9. Catless
    Catless Silver Member
    Feb 2, 2015
    1,009
    208
    198
    Parkersburg, WV
    I've felt this in other vehicles but not either Challenger I have owned. I just attributed it to take up in the linkage before it engaged the booster but I didn't investigate it. It never seemed to get worse or actually cause a problem.
  10. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,820
    3,907
    963
    I would keep monitoring it and since you have it documented already that is important
    Don't give up if you feel there is something wrong
