Stock 1/4 mile times
Discussion in 'Dodge Challenger SRT Hellcat' started by WHT SNK, Nov 28, 2015.
  1. WHT SNK
    WHT SNK Hellcat Member
    Nov 15, 2015
    55
    16
    What time is a normal 1/4 mile time for a off the floor A8 hellcat challenger. Stock tires , stock everything. No burn out on a drag strip. I have heard and read M6 cars are .5 second slower. What is the typical time.
    thank you
  2. Lighty
    Lighty Silver Member
    Dec 20, 2014
    770
    171
    Ontario
    Best I could get was 11.7 129.25. Poor launch lots of spin or Traction control kicking in. There has been better though.
  3. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,101
    732
    Dodge says 11.2
  4. WHT SNK
    Nov 15, 2015
    55
    16
    I am looking for real data not dodge numbers . I am sure they had a perfectly prepped track so on . Just looking for real feed back.
    Thanks. :)
  5. huggytree
    Nov 22, 2014
    3,101
    732
    ive never seen a M6 get below 12......most are beginners and they get 12.5-13+--one got 14's
    ive never seem a A8 w/ stock tires at the track
  6. WHT SNK
    Nov 15, 2015
    55
    16
    huggytree Ok thanks. Much appreciated.
  7. Ponycarkilla
    Ponycarkilla Silver Member
    Nov 13, 2014
    533
    211
    Kenosha, WI
    Seen a stock charger go 11.1 with 18psi stock tires. typically 1210 to 1170s with stock tire pressure with lots of wheel spin and 1160s to 1130s with 18psi. But those are the average. 11.10s 11.00s are capable on a track that's prepped well with a good 60ft. Weather conditions, driver and track prep play a key role getting those times. A8.
  8. sublime6spd
    sublime6spd Gold Member
    Nov 2, 2014
    853
    486
    Ontario Canada
    My best with stock summers and 6spd is 12.13 and my best with Mickeys is 11.50
  9. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,816
    1,290
    933
    Kenosha, Wisconsin
    I've personally watched a factory stock A8 Challenger on stock tires run 11.4...and the track wasn't prepped all that well...
  10. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,204
    276
    Here's a link I posted awhile back.
    Keep in mind this was on a low mileage car with very little practice and not the greatest of weather.
    On the street totally stock, meaning totally stock, with a car with 3,000+ miles on odometer in good weather conditions, I think 11.4's-11.5's would be easily attainable. Keep in mind too, trap speeds on the street will be a couple mph higher than drag strip (why you ask? because it's not coated with sticky VHT that causes lots of friction, great for launches, not as great for trap speeds. Higher ET's also often result in higher traps).
    1/4 mile runs...on the street...stock (Round 2) | SRT Hellcat Forum
    On a good drag strip, with good prep and sea level or below DA, totally stock (for those that don't seem to understand what totally stock means: it means, no DR's, no aftermarket DS, no race fuel, no weight reduction, and no other performance enhancing modifications of any kind), 11.1-11.2 in A8 cars.
  11. j_niko
    j_niko Silver Member
    Jun 12, 2015
    143
    56
    Sagamore Hills, Ohio
    Best I could do was 12.1. Never raced an M6 before. I fairly confident that high 11s are very possible. I blame it on myself. Next time it gets walked off the line.
  12. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    1,984
    473
    403
    Westchester
    11.4 on street tires, took like 10 pulls to get it and alot of luck.
  13. Challyboi
    Challyboi Rookie
    Jun 29, 2015
    4
    1
    Atlantic Canada
    I ran 11.87 @ 118MPH on stock tires with only a few passes. There is definitely more in it; but launching the M6 is tricky, for sure. I tried many combinations of traction & suspension set ups. This pass I launched at 4200RPM. 20PSI in the stock rear tires. Want to try some drag radials, for sure.
  14. helldad
    helldad Gold Member Hellcat Car Club HCC Charter Member
    May 6, 2015
    135
    73
    278
    11.97 all stock. Only been to the track 1 time...
    M6
  15. boosted srt
    boosted srt SRT Hellcat Supporter Gold Supporting Member
    Jul 13, 2015
    132
    79
    278
    Alexandria, ohio
    I ran a 11.6 at 120 mph second time down the track in 20 years stock p-zeros w/24 psi
    Left line at 1200rpm went full throttle just after Christmas tree. A8 set auto shift suspension street transmission track traction control on. I never expected it to pull that hard. Tires broke loose going into 4th, felt t/c pull engine down.
a8 hellcat track times
hellcat 1 4 mile stock
