Stock Dyno thread
Discussion in 'SRT Hellcat Performance' started by HellDoc, Aug 21, 2015.
  1. HellDoc
    HellDoc The Doctor is IN!
    Jan 8, 2015
    249
    154
    Atlanta, GA
    Can we start a stock dyno thread so we can see variations car-car and dyno-dyno.
    Mustang Dyno, only mod Drag Radials
    631HP
    569TQ
  2. DB2
    DB2 Silver Member
    Feb 4, 2015
    346
    85
    Green air filter, aluminum shaft, drag radials. Mid 70's, Superflow AWD dyno
  3. B5 Blue
    1,748
    We can but not sure what good it does with dyno operators that don't know what gear to use, traction control on, smoothing not all at same, manufacture's and whatever else that I've read on here. Me I know nothing about them just do timeslips
  4. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    Where the tempatures ?? Or maybe I'm
    Burnt and read the wrong dr Seuss hellcat and Green eggs and ham
    • Funny Funny x 2
  5. HellDoc
    Jan 8, 2015
    249
    154
    Atlanta, GA
    Do you know what brand dyno?
  6. HellDoc
    Jan 8, 2015
    249
    154
    Atlanta, GA
    You would not dyno on a train you would not dyno on a plane?
    I'll ask if they can spit out environmental variables.
  7. mowe
    mowe Gold Member
    Mar 25, 2015
    371
    195
    Stock M6 - SAE - 70 degrees in April
    Dyno jet - the STD numbers were over 700
    686whp / 624 tq
  8. jpg0511
    jpg0511 Senior Hellcat Member
    Jun 5, 2015
    76
    30
    Mobile, AL
    647hp 639tq dynojet 6th gear 93degs and 70%humid
  9. Hemi1632
    Hemi1632 BANNED
    Jun 25, 2015
    354
    267
    513
    Cicero Illinois
    I don't understand the point of this?
    I could care care less if I made a pull and it read 100 hp. All that I care about, is that If I make a change, and the Dyno now reads 105 hp I know that whatever I did just added 5% more power. The Dyno is not a measuring stick to see who has bigger balls. It is a tool to measure how much you have improved or hurt your performance.
    • Winner Winner x 2
  10. HellDoc
    Jan 8, 2015
    249
    154
    Atlanta, GA
    When measuring upgrades, absolutely correct. Only matters before and after hopefully same dyno.
    But theoretically dynojet inertia drums and environmental corrections are supposed to have them somewhat standardized and the resistance dyno like mustang have significant variances.
    I was interested in what the spread of dyno results would be on stock (or close) hellcats. It's not dyno queen biggest ball comparison on stock vehicles, just a data point.
  11. Teo
    Teo Judge Yooper
    Jun 7, 2015
    907
    451
    Yooper Land
    Bingo - Exactly! :D
  12. Hemi1632
    Hemi1632 BANNED
    Jun 25, 2015
    354
    267
    513
    Cicero Illinois
    Well I am not a doctor, but I do like to approach things in a scientific matter. So if your data is derived from different cars, on different dyno's, with different weather conditions, some cars are stock, some are "close" to stock, and let's not forget which correction factor did you use? SAE, STD, Uncorrected.........
    I would like to think that you don't have to be a doctor to realize that data that you are seeking is a little flawed. And to draw a hypothesis from this data would in my opinion not be recommended.
    • Funny Funny x 1
  13. HellDoc
    Jan 8, 2015
    249
    154
    Atlanta, GA
    I don't know what your inclination is to create an online pissing match, but if you don't agree in the validity, don't participate. I was interested and posted in case others were interested as well. You apparently have nothing better to do then to disparage a thread that you don't agree with instead of ignoring it. Whats the motivation there? Why going out of your way to create negativity?
    I AM a PhD, coincidentally in data analytics, and if you care to read the dyno manufacturers documentation, companies like dynojet actually brag about their result consistency from dyno to dyno, measuring their inertial drums to a few decimal places and decades of altitude/temp/pressure/humidity adjustments. Regardless this was based on curiosity, not data mining.
    • Useful Useful x 2
  14. rayzazoo
    Nov 8, 2014
    4,077
    1,660
    818
    For the dynos, in addition to Density Altitude, could we also post the intercooler temperature, engine coolant temperature, and intake temperatures at the time of the runs?
    From what I've seen with other Hellcat dynos and results, the optimal dyno temperatures are:
    Intake temp - 140-160 deg F
    Coolant temp - 190-210 deg F
    Intercooler temp - 116-120 deg F
    Of course, lower intake temperatures will produce better results, however, I think coolant temperature should be within that range.
  15. Hemi1632
    Hemi1632 BANNED
    Jun 25, 2015
    354
    267
    513
    Cicero Illinois
    Good questions!
    Oh boy, more data?!? Is this going to skew the curve even more???
    Hey Doc, are you starting to get the point? I guess I should have asked WHY you wanted to compare "car-car" and "dyno-dyno" numbers? Then I could have told you that you are introducing to many variables to make a valid comparison.
    Now as to why I am creating a so called "online pissing match" is because many people that have not owned a Dyno, run a Dyno, understood the use of a Dyno or even had their car on a Dyno. Are going to read this thread and think hey, this looks like good data and draw incorrect conclusions from it.
    I am not pissing, just trying to teach. But I guess that is where I went wrong, I couldn't think of teaching a doctor who went to school, has his PhD and can actually read about a Dynojet Dyno anything!
    • Funny Funny x 1
hellcat challenger stock dyno
hellcat dyno stock
stock hell cat dyno sheet
stock hellcat dyno
stock hellcat dyno numbers at high altitude
