Stock Hellcat Dyno Videos w/91 and 100 Octane
Discussion in 'Dodge Charger SRT Hellcat' started by Natasha Romanova, Oct 6, 2015.
  1. Natasha Romanova
    Natasha Romanova Rookie
    Jan 30, 2015
    12
    14
    Scottsdale, AZ
    Stock 2015 Hellcat. Dynojet dyno.
    First video is with 91 octane, 112 degree F temp
    626hp and 561 torque
    Second video is with 100 octane, 85 degree F temp. Higher humidity as well.
    691 hp and 616 torque (ignore 728 torque spike).
    Cooler temps definitely played a part in the hp gain on the second graph. I'll be going back in a week with 91 again for better comparative analysis.
    • Like Like x 7
  2. Charger_Hellcat
    Charger_Hellcat Gold Member Hellcat Car Club
    Sep 26, 2015
    243
    174
    493
    Did you have to re-tune with higher Octane or does the ECU take care of it? We have 101 at the F1 track here in Austin, but I'm worried the car might not like it and need to be tuned. I thought about going half 101 and half 93. Your input would be greatly appreciated!!!
  3. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,032
    Is that an auto or Six Speed
  4. Natasha Romanova
    Jan 30, 2015
    12
    14
    Scottsdale, AZ
    As long as it's unleaded, the ECU should take care of it and you should pick up some HP.
    Six speed :)
    • Like Like x 4
  5. Charger_Hellcat
    Sep 26, 2015
    243
    174
    493
    Sweet!!
  6. Meowzer
    Meowzer Hellcat Member
    Jun 19, 2015
    24
    28
    13
    I'll post next week's dyno up on here to compare 91 and 100 in the same weather/temps - I'm interested in seeing a better comparison of just the octane change. :)
    (This is the OP - I realized I was on an olllld account before, so I switched over)
  7. DShatzer
    DShatzer Gold Member
    Oct 13, 2014
    1,262
    285
    It would be interesting to see if 109 improves the numbers more. I know it takes $$$$ but finding the upper limits of the factory ECU tune based upon fuel quality would be interesting. Some manufacturers put upper bounds on their ECUs.
  8. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,466
    472
    258
    The Boonies
    good job! ill be interested in the results
  9. Confuzed2
    Confuzed2 Silver Member
    Jan 22, 2015
    367
    92
    "GO PACK GO"
    I'd love to see those runs on the same day, same temp and humidity but with different octane gas! So you have the right idea! ... Interesting you picked up that much more power with the higher octane.
  10. beefcake
    beefcake Gold Member Hellcat Supporting Vendor
    Apr 1, 2016
    121
    413
    if the stoich of the fuel is about the same, car shouldn't run any leaner, car will simply add the max timing the factory computer will allow. i always put about 2.5 gallons of e85 in to a fill up for the octane and cylinder cooling effect. e85 will run leaner, but at that amount, the pcm should be able to compensate
  11. currybob
    currybob Bob
    Jul 17, 2015
    1,027
    508
    Alexandria Alabama
    me too
  12. DShatzer
    Oct 13, 2014
    1,262
    285
    Where did you get this info? Most premium is E-10, then adding two gallons of E-85 puts you nearly effectively E-20. Just curious. Enjoy your car!
  13. pussycat
    pussycat BANNED
    May 18, 2016
    30
    16
    Dude what u waiting for drop some stupid numbers on the hellcat like ya do wit other hemi"s
  14. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    913
    466
    So Cal
    Wow! This is exactly the information I was looking for! I just found 100 octane race gas last night. I was wondering what kind of improvement I would see at 93.5 octane blending 100 with 91 octane. I guess you didn't try any blended you went with straight 100 octane from the looks of it. This is fascinating.
  15. TNCHARGER
    Nov 19, 2015
    1,210
    408
    Don't get too excited over this...dynos tend to lie and back 6 months ago when the OP did the dyno the temp was 27* hotter when he did the 91 octane compared to the 100 octane....heat will pull HP fast....plus others experience at the track (which is the accurate way to gauge HP) with race gas do not support a 65hp increase...
100 octane gas hellcat
hellcat stock dyno
is it same to put 100 octane on my new challenger
putting unleaded 100 octane fuel in hellcat
stock hellcat dyno
