Strange startup and drive mode issues
Discussion in 'SRT Hellcat TSB's' started by Justin_M_2, Jul 16, 2015.
  1. Justin_M_2
    Justin_M_2 Rookie
    Dec 21, 2014
    16
    6
    Iowa
    Has anyone else had either of the below issues??
    1. When I start the car it revs up high like it should when the car is cold. However when I start it up after its been shut off for a few minutes, it starts very low idle and almost gargles a little. The other day it started for half a second, died, then gave me this really weird wineing sound, then started up again. ?????
    2. I've noticed when it did the above or starts with a lot to gargle, it reset my custom drive mode. I have to go in and repick my custom settings.
    Please help!! Thanks!!
  2. B5 Blue
    1,745
    Never had either happen to me. Did you get a fuel line recall done? If so was it only after that?
  3. Justin_M_2
    Justin_M_2 Rookie
    Dec 21, 2014
    16
    6
    Iowa
    Yes I had that recall done. I also did the pcm and trans flash as well at that time. I think it was after all that.
  4. B5 Blue
    1,745
    A few on here had the dying issue TallCool1 whatever happened with yours?
  5. goingsolo2
    Oct 29, 2014
    1,531
    622
    Long Island, NY
    I'm still have a rough first start of the day since the fuel line recall. It always starts but it never happened so rough and with a hesitation before the recall.
  6. TallCool1
    2,433
    817
    Pacific NW
    I thought I solve it after changing gas, not. Happened yesterday 1st time in a while. Seems maybe outside or ambient temp related, maybe. Higher ambient temp at cold start, less frequent. Dunno. Maybe. Bothers the shit out of me in cold temps makes remote start almost useless, best case unreliable.
    It'll be sometime before I tear into further. I did open case with SRT. Back to shop many times as you know. Rail replaced twice no difference. Never tore into detailing injector performance, rail pressure or decay etc. That will be an all day ordeal, hooked up to WiTech, probably fall time. I may record some data with my scantool and torque pro, to see what it shows between now and then.
  7. TallCool1
    2,433
    817
    Pacific NW
    In reading 1st post my car behaves bass awkward, only happens cold start, after car hasn't ran for quite a long time. Never warm, never 2nd attempt on cold start. Only 1st attempt cold start. Otherwise perfect.
  8. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    I would take it to the dealer and have them put it on the analyzer. Somethings very wrong. IMVHO
  9. TallCool1
    2,433
    817
    Pacific NW
    Oh agree have done so many times, but, not hooked up when cold, so... But no DTC's set, nothing obvious seen. Need to due when it shows...
    (Never once heard a whine like original op, but his issue written happens when warm. And does appear priming fuel pump with key on and waiting, seems to reduce frequency on mine... at 1st cold start.)
  10. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    Very strange. I guess after my black hood hell experience, I've been pretty lucky. Hope you get it resolved soon. Keep us informed.
  11. Justin_M_2
    Justin_M_2 Rookie
    Dec 21, 2014
    16
    6
    Iowa
    Yeah on cold start mine really starts great and revs up. After I drive it and shut it off, then restart it, it starts kind of hesitantly. Only scared me one time when it didn't start right away and made some winding sound then started.
    As for the SRT drive modes, the custom mode always resets after a weird start too...weird...
  12. Fast cat
    Sep 23, 2014
    2,255
    714
    498
    Indiana
    I know magnummrk was having a problem like the one you guys are describing. I think he was trying an oiled air filter. And was thinking that might have had something to do with it!
  13. mblasr
    mblasr Silver Member
    Jan 13, 2015
    268
    117
    Northern California
    Does this happen with remote start , button start ,both?
  14. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    Hearing these issues, is the reason I have not had my recall done, I don't want to start having an issues with something that's there is nothing wrong with to begin with... I wonder if anyone on this forum has actually had a fuel rail leak of any kind....
  15. Lord Hellcat
    Jan 6, 2015
    1,592
    712
    UK
    I'm been thinking somewhat along the same lines. I've found a fuel rail and it is on its way. But is it a new fuel rail issue or just the PCM updates the dealer carries out that is causing the problem. I have no worries there
2015 challender srt dies after first start of the day
charger hellcat strange startup
dodge challenger hellcat fuel pump weird sound
does anyones challenger hellcat make weird noises
srt drive modes pcm update
