Stubble on start up
Discussion in 'General Automotive Discussion' started by paul suloff, Sep 26, 2015.
  1. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    699
    236
    Anyone experiencing a stubble or stall on start up? A couple time when I start the car it almost stalls. Like running out of fuel. Never experienced this with a Fuel Injected car. It's like the fuel pump is not up to pressure?
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,032
    Mine runs a little rough in a cold start,, but I just thought it's because it's a huge powerful engine...plus I don't drive it very often
  3. TallCool1
    2,435
    825
    Pacific NW
    3 or 4 threads on this, no specific root cause (or solution, not quite yet.)
    In my case its not fuel supply. Pressure is there, no decay. Using accessory on to pressure fuel system before start doesn't fix it.
  4. Teo
    Teo Judge Yooper
    Jun 7, 2015
    889
    443
    Yooper Land
    Too cold of a plug can cause start problems. Plus we are at 9.5 to 1 CR not the normal 10.9 to 1 like the 392 is. Also a extended tip plug in the 392.
    Mine started hard from day one until warmed up and still continues to do so. I will be checking with NGK for their recommendation here shortly. Backing off one heat range (going hotter) may not be a wise move? Re-gapping to .025 to .028 may help. We are at .031 stock now. Time to play again! :cool:
  5. Aaron Vogel
    Aaron Vogel Gold Member
    Jan 23, 2015
    1,566
    285
    Everywhere
    My car had a little stubble once, I just gave it a shave
  6. Teo
    Teo Judge Yooper
    Jun 7, 2015
    889
    443
    Yooper Land
    Maybe using Nair Hair Off will keep it ------ Gone! :D:p:cool:
  7. Aaron Vogel
    Jan 23, 2015
    1,566
    285
    Everywhere
    usually just a good waxing
  8. Teo
    Teo Judge Yooper
    Jun 7, 2015
    889
    443
    Yooper Land
    :eek::eek::eek::D:p:cool:
  9. NorCaletch19He77Kat
    Aug 30, 2015
    935
    281
    173
    Should be ZERO issues with cold start up and plugs will have nothing to do with it unless your car is modified--get to the dealer and they will check MAP, MAF and software for any issues--you should get an initial higher rpm cold start that lasts for about 10 seconds or so--but no stumble or lag issues at all.. These engines are built VERY lean and any data from sensors that cause even leaner fuel conditions will give you the lag, stumble.. Fuel pump problem--I doubt it, because most fuel pump issues are after hot/warmed up run or high rpm demand.. should be very easily corrected at dealer.
  10. redhemi
    redhemi Gold Member
    Dec 9, 2014
    473
    222
    southeast Pa.
    On start up mine goes too high idle,at least 1800 rpm,very loud and all the animals run;)then slowly down too a mean rumble :D
  11. Lord Hellcat
    Jan 6, 2015
    1,610
    727
    UK
    Mine does exactly the same. I think you need to take it to your main dealer Paul
  12. TallCool1
    2,435
    825
    Pacific NW
    It lay very well be bau no cause (which is to say no cure minus tuning) for concern.
    On EFI setups, often tuning correction factors are used, fuel is enriched at cold start. It can be a challenge to optimize combustion during initial cycles while things warm up. It can take a few cycles for MAF to even begin providing useful data, some injector pulses to account for fuel evap etc so lamda targets are adjusted then.
    I'd love to see Hemituner or HighHorseman weigh in on that, they just might be able to educate us, so as to save chasing something that stock tuning may be causing at cold start.
    Tuning is likely different for cold engine starts it would be presumptuous to think it's lean condition related until that's known.
  13. Lacan
    Lacan Rookie
    Aug 18, 2015
    28
    9
    Mine does this every morning. I leave for work early so its colder outside for my area (40 degrees) Ive tripple tapped the start button before starting nothing matters. I've had it to the dealer for P0300 code. They can never find anything wrong since its only at cold start and unable to replicate it. Often I'm told its carbon build up... Sick of the CEL coming on. So now I tripple button start and lightly press the accelerator when the rpms start to drop at start up until it stabilizes itself. Hopefully they find a fix its getting annoying.
  14. slester1
    slester1 Silver Member
    Jan 13, 2015
    338
    78
    My HC almost stalls also on cold start after sitting for 2 days.
    Rough idle for a few secs then normal but it has done it since day 1 and from all Ive read on here its about normal.
    I don't like it and waiting for a fix like everyone.
  15. TallCool1
    2,435
    825
    Pacific NW
hellcat start up problems
