Stumbling on cold startup TSB?
Discussion in 'SRT Hellcat TSB's' started by Hemibuck, Oct 2, 2015.
  1. Hemibuck
    Hemibuck Gold Member
    Jan 9, 2015
    1,628
    386
    WA
    So after the cat sits for a couple days when it's started it stumbles and acts like it wants to die. Like it's not getting enough air. Then it finds its way back and is fine after that. Anyone know of a TSB update for this? @resume & fnkychkn ?
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    Lets hope someone has an answer to this.....
  3. L.J.E.
    L.J.E. Hellcat Member
    Sep 28, 2014
    53
    12
    Mine started doing that after the Fuel Rail Recall was performed.
    Discussed with the Service Manager whom I trust and he researched it and came up with nothing.
    Just for kicks I tried starting with remote and symptom went away so for the last couple of months I always used the remote start which makes it fun to listen to anyway.
    About a week ago I thought I'd try it again without the remote and it has started perfectly with no "stumble" ever since.
    I have no logical explanation, just thought I'd thro it out for another data point for those experiencing the symptom.
  4. TinCuda
    TinCuda Gold Member
    Aug 14, 2015
    260
    266
    513
    Texas
    I don't have experience with this engine specifically but could this just be part of a normal break in process? I have run across many different engines that did this for the first couple hundred of hours.
  5. fnkychkn
    Jan 24, 2015
    1,449
    558
    423
    plastic take-out container
    no TSB to address this concern yet.
  6. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    669
    224
    Mine is doing it more regularly. 3000 miles on car. Almost everytime if the car stills a few days. If I feed it a little gas on start up it's fine. Like fuel starvation on start up.
  7. HellFox
    HellFox Senior Hellcat Member
    Jan 29, 2015
    113
    26
    Alberta
    Mine has done this from day one. I dont drive it every day so that may be why i noticed it so soon. It seems if it sits for more than 24hrs its almost garunteed to struggle for fuel on start up (remote or push button). However, when im starting and i put the ignition to run without turning over for a few seconds then fire it up i dont have any issues.
  8. Oldman66
    Oldman66 Senior Hellcat Member
    Mar 31, 2015
    53
    23
    48
    Fairborn Ohio
    Mine just started doing it about a week ago as the temperature dropped. As some of you have mentioned, it's more likely to do it after the car has been sitting for a couple days without being started. It acts as if it runs out of gas. Maybe it's not holding fuel pressure in the rails or trying to start before the pump fully pressurizes the systems. But I'm just guessing based on the way is acts. Second attempt to start it fires right up.
  9. gabe
    gabe Gold Member Hellcat Car Club
    Dec 24, 2014
    613
    295
    My challenger started doing tha
    My challenger hellcat started doing the same thing about a month now. It also throws some white smoke right before it wants to stall. The temp outside was around 70 degrees.
  10. Hemibuck
    Jan 9, 2015
    1,628
    386
    WA
    My SRT tech said it could have also been because of how these cars learn and adapt to driving habits and could have been adapting to the cold weather. Because it just stopped for me out of the blue. It was that or bad gas.
  11. slester1
    slester1 Silver Member
    Jan 13, 2015
    325
    72
    Well it might be something to this as mine is not as bad now as it was . It sat for a week and stumbled only a little before it went back to smooth idle.
  12. Catless
    Catless Silver Member
    Feb 2, 2015
    965
    195
    Parkersburg, WV
    I just thought it was part of the bada$$ retro theme.....
  13. Driller
    Driller Senior Hellcat Member
    Jan 30, 2015
    99
    44
    Phoenix, Arizona
    Mine is doing the same thing as the car is only driven a couple of times a month
  14. Mike Lannom
    Mike Lannom Gold Member
    Jun 21, 2015
    186
    95
    278
    Chicago Suburbs
    I heard this second hand so please check out. Reprogram the powertrain control module should fix this problem.
  15. ReoTom
    ReoTom Silver Member
    Dec 15, 2014
    658
    149
    Arizona
    Yea... fuel pump needs a sec to fill / pressurize the rail, I do the same thing..
