Suggestions for a vehicle lift?
Discussion in 'General Automotive Discussion' started by Monkey PoXXX, Feb 4, 2016.
  1. Monkey PoXXX
    Monkey PoXXX Hellcat Member
    Aug 2, 2015
    71
    22
  2. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    411
    I have both; an assymetrical lift at my shop and a 4 post in my garage
    It depends mainly on how much maintenance/modifications you plan on doing.
    I use my assymetrical for most f the work, my 4 post is primarily for parking.
    There's lots of less expensive optins than Bendpak that are just as good.
    There's a good thread on lifts here if you search.
  3. YLWJKT
    Oct 12, 2015
    411
  4. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,136
    744
    i have the bendpak hd9
    do you want to drive up your lift or mess with a 2 post
    will your garage floor need extra thickness? with a 4 post it doesnt (if you have a 4" pour like most)
    i think its an easy answer...get the hd9....
    if your installing it yourself PM me for a few tips
  5. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    2 post if you want to do tire changes and major work on the car....4 post if oil changes and minor work........I have a Challenger 2 post in my garage. I started out going with the 4 post but a good friend of mine who is service dept forman for my dealer talked me into the 2 post...and I am glad he did.
    I don't know how many times I have done something to my 2013 SRT and thought if I had bought the 4 post I wouldn't have been able to do this.
    Challenger requires a minimum of 4" of concrete.
    [​IMG]
  6. huggytree
    Nov 22, 2014
    3,136
    744
    i agree if you plan to do constant mods/work on your car the 2 post is better.....when we replaced my driveshaft we were not able to get the exhaust out of the lift and had to work with the exhaust laying on the lift....while it still worked just fine, it did make things more difficult.....this is the ONE time a 2 post would have been better
    also on the bendpak i notice my HC scrapes once in a while....i will be jacking up the ramps a bit next year to prevent this...my front mud flaps have the bottoms wore through from hitting...my 2011 srt did not hit...the HC just baaaarely does
    i would buy the Bendpak 9 over again....for the $$ i think its the best.....and once again remember your concrete....2 post is putting 2x the pressure on your slab....i know the 4 post wont crack your concrete...but i do not know if the 2 post will or not......its 2300+lbs on each post vs 1100lbs per post
  7. Monkey PoXXX
    Aug 2, 2015
    71
    22
    Thanks guys for your help. I'll have to see how much concrete I have before I make any final decisions. I am looking to do mostly light modifications like wheels, oil changes, etc. Would like to be able to do more eventually but don't have the skills for that yet.
    This is one of the best forums I've ever been a member of. Keep on rockin' fellas!
  8. Mopar Magic
    Mopar Magic Hellcat Member
    Aug 13, 2015
    93
    25
    Wichita, KS
    Atlas® 10-OHSC Overhead 10,000 lbs. Capacity 2 Post Lift (EXTRA TALL) | Greg Smith Equipment Sales, Inc.
    I have the one in the link above. It's a 10,000 pound symmetric
    Two post is definitely better for working on the vehicles.
    .Four post is definitely better for storing vehicles.
    Some of the four post lifts support jacks that allow you to free the wheels for working on them but there is an additional cost and not as handy as the two post.
    The argument that two post lifts put twice the pressure on the concrete over the four post lifts is misleading.
    You really should consider the weight per square inch. Since the two post pads are larger than the four post pad there isn't anywhere near twice as much weight per square inch.
    Most two post lifts under and including 10000 pound lifts are designed to work on a 4 inch concrete slab.
    Pretty much any kind of lift is better than crawling around on the ground.
    Good luck and enjoy if you get one.
  9. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    70.196059, -148.559760
    I have and prefer a two post lift. My requirement was that it had to be top quality and American made (the latter just because that is what I wanted).
    I have a Mowhawk System 1. It's a BEAST. Made in NY, by US workers with US steel. Most lifts look like junk when compared with this thing. It's over built. I was only buying one so the price wasn't a factor. Yes, it's more expensive than many lifts but not enough to matter.
    I've done a TON of work on this thing in the 10 years that I've owned it and it is one of the best purchases I've ever made.
  10. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    If you really want to do just wheels, oil changes etc you may even consider one of the many mid-rise scissor type lifts. They don't have to be permanently mounted and you can easily get the car off the ground to do they types of things you want to do.
  11. 1FSTCAT
    1FSTCAT The Punisher
    Dec 28, 2014
    1,130
    407
    358
    Virginia
  12. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    This looks like a GREAT option for someone that doesn't need or want a full blown two post lift but wants to work on a car (rather than store a couple of cars in which case a four poster is also a good option).
  13. huggytree
    Nov 22, 2014
    3,136
    744
    most garages are 4" pour
    the lift may say you need more, but remember its meant for 9,000 lbs and your only lifting 4400lbs
    i am the one who brought up dividing the weight by 4 vs 2....i did not know the 2 post lift had bigger pads
    as far as the wheel kit on a 4 post lift....when trying to load a M6 car my lift would move all over the place...12" easy just from the sudden jerk of stopping the car while flooring it to get up over the ramps...i tossed my caster kit and bolted mine down to the ground
    if storage is your main thing ---ive never seen anyone use a 2 post for storage...not that it couldnt work, but with my job im in 1-4 peoples houses a day and i see a few lifts a year....not 1 has ever been a 2 post
  14. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    You have never been over my house
    I went two post as I work on the cars. Works great for storage too. Not knocking the four poster. It's good to have options.
  15. Mopar Magic
    Aug 13, 2015
    93
    25
    Wichita, KS
    Good point on the garage door opener.
    I forgot to mention that and also jack stands for the two post if you go that way.
    I also use the LiftMaster 8500 and recommend it for any type of lift.
    If you go with a two post and do any significant mechanic work I highly recommend stands like the link below.
    2 Ton Heavy Duty Tripod Stand TALL | Greg Smith Equipment Sales, Inc.
