Summer Tire Inflation
Discussion in 'SRT Hellcat Wheels and Tires' started by solo7777, Jan 14, 2015.
  1. solo7777
    Nov 25, 2014
    3,070
    1,370
    768
    City Of The Angels
    or for all seasons too..Mine are the summer tires.
    Just wondering what the proper inflation for these Pirellis should be, the door sticker says 32, but I think that would be for standard tires. Mine are around 35 right now. I'm thinking 33-35 PSI cold. Couldn't find anything about it on the Pirelli site.
  2. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    What's the max psi? I know in LEDT (law enforcement driver training) they tell you to run tires at max psi for best handling and least chance of rolling the bead off if while in pursuit. I'd just make sure to check the wear pattern to ensure you aren't just wearing the center section from over-inflation. But max psi shouldn't be over-inflated. You also get better MPG from a max psi tire. I'd have nitrogen put in. I run it in all my vehicles, then you don't have to jack with air pressures from varying temperatures.
  3. solo7777
    Nov 25, 2014
    3,070
    1,370
    768
    City Of The Angels
    I'll have to check. How much do they charge you for nitrogen? Does it last, and how often would you say you have to top off?
  4. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Price varies from free/fairly cheap to $10/tire. Unless you have a leak, you shouldn't ever have to top it off. It isn't affected by differences in temp like regular air is so it always keeps the same pressure whether it's 110 or 5 degrees outside.
  5. solo7777
    Nov 25, 2014
    3,070
    1,370
    768
    City Of The Angels
    I didn't know that. I'll have to check that out. Normally where can you get nitrogen from? Auto shops? Garages?
  6. 440 Superbee
    440 Superbee Gold Member Hellcat Car Club HCC Charter Member
    Dec 3, 2014
    1,042
    252
    MOVED - Clearwater, FL
    If you decide to use the max psi pholosphy and don't use Nitrogen, you will always typically increase psi by 2psi once the tires are ran and heat up. Then tie in the outside air temp, and you will have to monitor tire psi. Good thing about living in Cali is the temps don't typically fluctuate to extreme like other states like WI winters compared to WI summers, etc.
  7. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Any decent tire/wheel shop will have it and some nicer Mechanics/Garage/Maintenance type places. You may have to go to the 'city' if you live in a rural area.
  8. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    229
    AZ
    I run 38 PSI in my tires but I always run more pressure in my vehicles
  9. MVT
    MVT Silver Member
    Jan 11, 2015
    1,079
    307
    The advantage of nitrogen is it will fluctuate less then air but it still will change slightly depending on the outdoor temperature. Nitrogen molecules are bigger then air, therefor less chance of seepage from the tire. Also the inside of the tire dose not build up condensation like air.
    Nascar uses it so they have less fluctuation on air pressures.
  10. Jim Hetrick
    Jim Hetrick Silver Member
    Dec 5, 2014
    1,338
    263
    108
    Orange County Cal
    Comon Ma we goin to the city, we getin out tyres fixed.......................................LOL
  11. Michael Jutovsky
    Michael Jutovsky The Mean Green Raccoon Eating Machine Hellcat Car Club
    Sep 25, 2014
    376
    154
    Wauconda, Illinois
    I can't speak from personal experience but I have heard that Costco will replace the air in your tires with nitrogen for free if you are a member. Can anyone confirm this?
  12. Fast cat
    Sep 23, 2014
    2,255
    713
    498
    Indiana
    My Summer tires fluctuate approximately 4 PSI on a 50° day
  13. DShatzer
    DShatzer Gold Member
    Oct 13, 2014
    1,228
    280
    Max pressure on sidewall is fine. Tire pressure may increase 10% during highway driving. NEVER reduce heat induced pressure increases. Changing door placard pressures, if there are front/rear bias pressures can alter handling. Dramatically.
  14. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    If you want nitrogen filled tires, take your car back to the dealer, they have it there, probably will do it for free,, they did mine for free when I got my oil changed
  15. Mtr
    Mtr Silver Member
    Jan 13, 2015
    262
    69
    I think it's questionable for street use. Normal air is already 78% nitrogen, after all. I doubt it makes any difference except in competition driving situations.
2015 challenger tire pressure
tire psi challenger hellcat pzero summer
