Supercharger Info
Discussion in 'SRT Hellcat General Discussions' started by BKuz, Dec 8, 2014.
  1. BKuz
    BKuz Retired American Fighting Man
    Oct 22, 2014
    1,559
    748
    Weeki Wachee, Florida
    The Hellcat Supercharger is made by IHI Turbo America. IHI builds superchargers for Mercedes AMG engines. The supercharger produces 11.6 pounds of boost and I am sure it can push at least 14 pounds of boost. I heard people talk about Diablo Trinity tuning the Hellcat, but if you want more horsepower don't you have to change out the supercharger pulleys to produce more horsepower? Just throwing this out there for discussion.
    BKuz
  2. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    Seems like I've heard it's 'boost limited' to 11.6. I'm not sure if they are doing that via the pulley size or if there is a blow-off valve somewhere? If there is some type of blow-off valve, that could probably be modified (stiffer spring(s)) or replaced...but until you can alter fuel/spark in the ECU I wouldn't touch it. Outside of that, yes a smaller pulley for any measurable performance increase...which again will require tuning. Beyond that, someday Whipple and/or Kenne Bell may make some larger superchargers for these cars.
    And when you start getting smaller and smaller pulleys, then you have problems with belt slippage because there just isn't enough surface area for the belt to grip.
    • Funny Funny x 1
  3. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    belt slip will be a huge problem!
    also it takes hp to spin the pulley. My theory is the small the pulley the more hp it takes to spin it.
    This comes from my playing with my GT500 and the upgrades over the course of a couple years. Seems like I lost a bit of low end power on the Shelby with the smaller pulley but got a ton more on the mid and big end.
    Probably not a bad thing, tires don't hook up as it is.
  4. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    True, might actually help on launch. They make those pulleys with those very rough textures, but then the belt doesn't last as long. Also seen people go to a wider belt and pulleys with more ribs.
  5. SinisterKitty
    SinisterKitty Silver Member
    Dec 6, 2014
    348
    Houston, TX
    Isnt the belt on the pulley already pretty big, comparatively speaking? What does it look like compared to your mustang? I have heard a lot of comments on the width of the belt being pretty big. I am just curious because I was planning on messing with the pulley diameter when I get mine. Thanks for any insight.
  6. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    I had forgot the Hellcats already had a 10-rib belt. Would be hard to find a wider belt.
  7. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,781
    2,048
    The hellcat has a very wide belt already.. plus there is a blow off valve and im sure that can be controlled to hold boost longer.. but the bigger problem we will have is the is a spring loaded pulley that fits inside the supercharger pulley and its used to keep the the supercharger from running when not needed,and from turning backwards... the is write up about it in this forum..They hint around at things that can be tweeked
  8. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Also IHI is a Japanese design company :)
  9. Alan
    Alan Active Hellcat Member
    Sep 8, 2014
    100
    33
    28
    Also need to know what the max flow rate is on injectors. If you run out of injector pulse width due to more airflow the throttle will close a liitle so that engine will not run lean. Running lean on this engine will ruin pistons and wreak havoc.
    Can't do this without changing cal.
  10. hellcat1
    Sep 27, 2014
    10,781
    2,048
    They make the superchargers in Indiana, I googled it...
  11. hellcat1
    Sep 27, 2014
    10,781
    2,048
    I don't think anything is going to work until you can remap/ rewrite the ecm...But there has to be room to make more power, there all write ups everywhere saying the built the car to handle more power, and rumors that it was making better to 800 hp at the motor
  12. SinisterKitty
    Dec 6, 2014
    348
    Houston, TX
    Yeah I heard it has been tuned down as well. Emissions problems and what not.
  13. Alan
    Sep 8, 2014
    100
    33
    28
    I agree.
    The key is whether or not the 800+ was accomplished on an engine dyno or the actual vehicle. I'm sure you could do it on the dyno but whether there is enough infrastructure to support the extra horsepower in the car is another thing.
  14. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    Link please...because IHI is a Japanese company...and this is such a low production run...I find it hard to believe that IHI, the supercharger manufacturer of Mercedes AMG has a plant in Indiana...
  15. hellcat1
    Sep 27, 2014
    10,781
    2,048
    I think the car is built for the power, and can withstand it with little problems, but I think the issue cam down to emissions,, some states are very tough on getting cars pasted , so why not detune them all and they can go anywhere and pass.. but for those of us that live in states with relaxed emissions, I for one want more power,
can the hellcat supercharger
hellcat supercharger size
ihi hellcat supercharger
ihi supercharger
ihi supercharger hellcat
ihi superchargers
supercharger info
