Supercharger stopped working
Discussion in 'Dodge Charger SRT Hellcat' started by AER, Jun 27, 2015.
  1. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    I had my car out for spirited driving recently and after about 35 minutes the car seemed to lose a lot of power almost like the supercharger was heat soaked. It did not go into limp mode.
    Seemed to fix itself after letting the car sit for awhile.
    Any ideas?
    I will also say the next day the paddles weren't working correctly for a few hours.
  2. B5 Blue
    1,743
    Any codes? What did boost read when happening? What was IC temp?
  3. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    Nope no codes, didn't have the gauges on.
  4. budkole
    budkole Best Color and fastest is undoubtedly WHITE
    Mar 14, 2015
    554
    188
    St. Louis
    heat soak maybe?
  5. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,546
    433
    368
    Henderson, NV
    Positive displacement supercharger doesn't have a wastegate. I agree you probably had some serious heat soak. Heat soak will zap 50hp easily.
  6. TrackDay
    TrackDay Silver Member
    Mar 28, 2015
    951
    258
    173
    The bypass valve is functionally the waste gate.
  7. AER
    AER Gold Member
    Jan 15, 2015
    151
    65
    278
    So the question begs to be asked, did something fail or are these cars just really not designed to do anything other than look pretty?
  8. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,512
    1,425
    818
    Endless Mtns of Pa
    your not giving much information.. location & outside temps, altitude above sea level.., or any of the temps your engine was running..
  9. budkole
    Mar 14, 2015
    554
    188
    St. Louis
    No...nothing failed. Supercharged engines are prone to heat soak over a period of time. Thats why race cars are naturally aspirated. The hellcat wasnt designed to do lap after lap after lap all day, i cant find the video where they (SRT) was talking about this very thing. However, heat soaking takes longer to reach on these cars compared to the chevy's & mustangs
  10. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,605
    507
    423
    Chattanooga, Tennessee
    Your thread title would let everyone know you are clueless about your car. It's a positive displacement supercharger and would stop your engine if it failed. Only way it fails is if the belt breaks, or the bearings lock up. As others have said, if it "fixed itself" it may have been heat soak. Your thread title would have read "Engine Quit" if your supercharger stopped working.
  11. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    917
    235
    Somewhere, Texas
    I can tell you right now, without hesitation from my extensive non-scientific testing that temperature and humidity play a huge factor.
    I have personally seen HP swings of 60 hp all in a span of 14 degrees and 90-60% humidity over the span of 30+ runs of various temps.
    Hot & wet air suck for power-oh, and altitude.
    The claim is the car can run all day in 100 degree heat w/o pulling timing, but that doesn't mean that it can change the laws of nature. Also, it depends on the course-you need some speed to get air through the beak to shed the heat you have accumulated.
    Further, you must have been on a real short track to do 20 laps and not run out of fuel. Or maybe you were so low, the car wasn't getting all the fuel it needed?
  12. Paladin06
    Sep 3, 2014
    4,642
    1,787
    San Tan Valley, AZ
    This car is not a Vette. There was extensive testing done on the track and the dyno to ensure this heat soak you mentioned would not occur. I would take the car to the dealership for further inspection.
  13. rayzazoo
    Nov 8, 2014
    3,176
    1,135
    668
    Did you remove the lower front grill?
    • If equipped with a removable lower front fascia grille, it is recommended to remove it for track use during warm/hot weather to improve cooling airflow to critical powertrain and cooling system components
    [​IMG]
  14. Paladin06
    Sep 3, 2014
    4,642
    1,787
    San Tan Valley, AZ
    I don't believe the heat soak problem suggested on 75 degree day. I suggest you look else where for your problem.
  15. B5 Blue
    1,743
    Any suggestion is guesswork as we don't know any gauge readings. Not to sound harsh but I drive with gauges 1 on at all times let alone if one is thinking of a supercharger issue why not turn them on at that time.
supercharger fail on hellcat
