SuperHarmonic ATI Street Damper made for the Hellcat
Discussion in 'General Automotive Discussion' started by FA5T CAT, May 6, 2015.
  1. FA5T CAT
    FA5T CAT Silver Member
    Feb 16, 2015
    460
    180
    Santa Clarita, California
    I found this damper on eBay and was wondering if any of my fellow Hellcat owners have any insight on this before I install it. Any insight would be greatly appreciated.
    http://pages.ebay.com/link/?nav=item.view&alt=web&id=191549588462
    Thanks y'all
    Adam
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    I was told by a few people that there is no room for a bigger pulley because of the four bolt ac pump...and the casting is to big for a smaller pulley on top....please let us know if you have any l luck with this product
  3. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,064
    644
    413
    So Cal
    Well it oem size yet it says don't use a/c belt if racing ???
    Not sure what the advantage is except dampening vibration ?
    Specifics: Dodge Hellcat 6.2L 2015+
    • Aluminum Shell
    • 8.19" OD, OEM size
    • 10 & 6 Ribs
    Notes: Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive- DO NOT USE BELT IF RACING! 3% underdrive on powersteering. OEM size on water pump.
  4. hellcat1
    Sep 27, 2014
    10,668
    2,027
    So,, they're not offering it at a pulley to make more boost! That's the only real reason to purchase one is to get the supercharger to spin faster and make more boost.....at least those are most people thoughts...including mine. But sense were in this topic, maybe there is another pulley that can be changed to make more boost,, or close up the hole where the.bypass controller is,, is the opening is smaller, less air will move through it,, meaning holding boost longer.. please let me know if I have to clue as to what I'm talking about.Lol.. but when certain people talk,,I listen..
  5. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    Hey Adam do the driveshaft before the damper plus magic sauce on the way to you ;) so don't panic you gonna be very powerful
  6. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    Weird underdrive setup. You can't run the a/c belt when racing...I assume prolonged high RPM? Hello, isn't that the point of this car?
    Also, why would you need better crankshaft dampening? Seems like an "upgrade" to skip to me.
  7. RoRo
    RoRo VIP Hellcat Member
    Apr 11, 2015
    421
    107
    73
    Gilbert Arizona
    I wish I knew boost lingo :(
  8. Harley88
    Harley88 Gold Member
    Nov 15, 2014
    1,210
    340
    I've said before, like watching Jeopardy
    And not even understanding the question!
  9. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    So no performance improvement claims? Overdrive the a/c by 25% and underdrive the p/s by 3%? Sounds like it will make less power than stock. What am I missing here?
  10. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,437
    943
    668
    Cape Coral, SW Florida
    Why would you need to upgrade to a "Street" dampener in the first place? If you are going to switch it out, it would be for racing/performance.
    This looks like a money grab to sell a product which has no real use/market reason.
  11. B5 Blue
    1,743
    I won't be buying one
  12. Deputydog
    Deputydog Gold Member
    Nov 2, 2014
    1,002
    260
    Spokane, Washington
    I had an ATI damper on my Cummins. They should really be balanced with the crank though. I wouldn't put one on my cat personally.
  13. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    Is the 6.2L internally or externaly balanced? (I haven't looked at our balancer) If internally, then the ATI will need to be neutrally balanced.
  14. Slowhand
    Slowhand Gold Member
    Jan 26, 2015
    602
    261
    Maryland by the bay
    From a performance perspective, removing the A/C belt reduces parasitic drag on the engine, of which some is present even if the A/C is off. You don't use A/C when racing (please say no). And underdriving the PS by 3% reduces the drag load there as well. So a marginal power savings and no other benefit I can ascertain, except a lighter wallet. ATi makes quality products and I use an Ati SuperDamper on my 528 Hemi. But no way I'd buy this one unless all I planned to do is race my HellCat.
  15. Bascadog
    Bascadog Silver Member
    Mar 15, 2015
    422
    175
    Southern Ca
    Its not as easy as just adding more boost. More air needs for fuel too. Doing a tune with the pulley change correctly will give more power. Start doing one without the other haphazardly will cause issues I'm sure. I will be passing on this upgrade.
14 ram 1500 ati pulley
advantage of under driven ati superdamper
ati balancer for hellcat challenger
ati damper for dodge hellcat
ati damper install hellcat
hellcat overdrive pulley
pulley for hellcat
shotcuts to replacehellcat challenger damper on the car
