suspension/alignment help...
Discussion in 'SRT Hellcat Builds' started by Dr. SS, Jul 11, 2016.
  1. Dr. SS
    Dr. SS Silver Member
    Feb 23, 2015
    192
    45
    Chicago, Illinois
    my car is on KW sleeve kit/coils
    razor edge/speed logix, billet rear upper and lower control arms
    razor edge/speed logix trailing arms
    DSS shaft
    I got the car aligned, to get the camber neutralized from being lowered
    they were able to get the RT rear to -0.1, but the left would not go anymore then -0.8... which was peculiar
    apparently camber settings are diff from left to right on challengers? perhaps from loading and fuel tank weight
    anyhow to make it all even and get the cross camber right, its now set at -0.8 left and 1.0 on right for camber
    im told the caster and toe , total toe have all ben placed into spec
    the front camber is -1.9 and -1.3 (R / L) ? I have to look at the exact spec- and im told that's from lowering the car and cannot be adjusted
    on the REAR the driver tire sticks out more then passenger but I think this is due to the cradle being lowered and its out of alignment its very subtle but my mechanic is going to realign the cradle
    anyhow along with all that I did put on a fresh set of MT ET S/S 305 DR, and the car hooks way better
    but now the car has some really weird handling dynamic...
    on power when ur accelerating sometimes I feel like the back end is swaying and squirming its unnerving
    also when ur taking a curve or corner kind of fast the steering feels numb not communicative, disconnected and the rear end as well it will feel like the car is floating not connected to road its just weird as ****.
    I don't remember the car doing any of this stuff stock, or even when it was just lowered...
    I also feel the steering has lost some its sharpness and quickness and on center feel
    I know the car is not a great handling car but it def was not as floaty and swaying as it is now
    if the cradle is off center just a hair could that be causing all these symptoms?
    has anyone used the whiteline kit for the cradle? or solid bushings? does that help?
    I do realize the DR are going to be diff then a max performance tire for handling and cornering but before the MT ET I had NITTO NT555R and I used to hammer the shit out of it and the car was solid and cornered solid granted at that time I was not making the power I am now I was stock power wise
    rt now the car is on 2.65/10% OD/ID1300 and makes 825/877 on E85
    thanks for any advice just want the car to feel buttoned down and controlled like it used to be
  2. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    411
    It's the MT SS tires. The sidewall has much more flex and will allow the rear end to feel loose.
  3. DGatzby
    Jan 16, 2015
    3,632
    1,934
    748
    Twin Cities, MN
    Could be what he says. Your equipment sounds close to exactly what I have done to my car. Have them re-check your toe settings again. But I have been road coursing it, and it DOES handle well, it should not feel like you describe. You have some other cars that are nice machines and this should not disappoint like that. Here is a copy of my last alignment sheet. If it is close to these settings it should steer like it wants to get into the corner and feel real planted coming out. Was lapping the Hellcat with a modified GTR the other day, the Cat was not doing too bad.
  4. thedynoguy
    thedynoguy Gold Member
    Jun 22, 2015
    171
    135
    493
    Webster, NY
    I've got the KW springs with P-Zero 305's in the back and mine feels EXACTLY the same . I haven't done all of the other pieces that you have though. I'm kind of thinking that the P Zero 305's are my issue...
  5. pivotal
    pivotal Senior Hellcat Member
    Mar 24, 2016
    122
    35
    Silver Spring MD
    I also have the KW sleeve kit and I'm running 295/35 Michelin Pilot Super Sports - my car behaves much like yours as well. I'm adding the RE/Speedlogix arms this month, but I'm also going to upgrade the rear subframe bushings to Whiteline and see if that helps to keep the rear end planted.
    Matt
  6. Dr. SS
    Feb 23, 2015
    192
    45
    Chicago, Illinois
    well guys mine is doing that after doing the RE/Speedlogix arms and getting the alighment straight
    my cradle is off however
    going to see StellasHC
    he knows a guy who can line up and square up my cradle and recheck my alignment hope that improves the issue
    I will say this my MT ET S/S tires were at 36 psi, I dropped to 28 and it actually helped the float sensation some
  7. sorbs
    sorbs Hellcat Member
    Jun 22, 2016
    33
    28
    18
    Any updates on this? I put new rubber on all four wheels - 285/35 Pilot Sports - KW adjustable springs - 1.5" drop - and noticed the wollowing handling before the springs hoping they'd fix it. Nope! Now running 36PSI - tried 30PSI - weird.
  8. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,413
    444
    To all of you with this issue after lowering your car, check your alignment. You especially want your rear camber to be very similar side to side and to have the least thrust angle you can have in the rear from toe. My right toe was way off and under power it had a very scary wallowing back and forth. Alignment fixed it.
  9. Demon_HellKitty15
    Demon_HellKitty15 Senior Hellcat Member
    Dec 8, 2016
    56
    41
    Calumet Oklahoma
    Are you putting the car on a drag strip? The toe out on the front will line itself out when you got the throttle... The front end will come up allowing the tires to come back in... The rear... Not so sure. How does she run from a stand still in a straight line when hitting the throttle hard?
  10. Demon_HellKitty15
    Dec 8, 2016
    56
    41
    Calumet Oklahoma
    On the rear... cHeck the bushings and sway bar
    If the cradle isn't set up properly or the bushings are out of whack it can ruin the way it drives and handles.
  11. JLCat
    JLCat Rookie
    Sep 11, 2016
    13
    It' it's the MTs mine does the same and I just ran the cat at Daytona on Firestone F1 it handled great once the tires heated up
  12. sorbs
    Jun 22, 2016
    33
    28
    18
    Yep, it is the tires...either live with the sway or go back stock spec tires.
    I went back to stock with BFG Sport Comp 2s. Car handles better than with the Pzeros (stay away from Michelin SS) and for less than $1k for the set I don't feel bad when I smoke them off the line. Also, I run a custom setup in my SRT settings that helps too.
    Sport suspension, Track transmission and Stock traction control setting. Car sticks in the corners and very predictable. Makes it really fun to drive fast and when the tires get warm barely any squeal through the turns.
    Enjoy!
2016 charger alignment specs
challenger hellcat alignment specs
kw hellcat springs alignment
