sway bar end links install question
Discussion in 'SRT Hellcat Maintenance' started by Ohiotj, Sep 3, 2015.
  1. Ohiotj
    Ohiotj Silver Member
    Nov 29, 2014
    358
    116
    i am putting on bwoody's with end links today. I don't have a lift and just the basic jack stands and jack. Is it easier/ possible to disconnect and install the new links while on the floor or while in the air? I know in my jeeping days to reconnect the front sway bar and links the jeep had to be on the ground and pretty dang flat. My guess is try to do it while on the ground. Let me know what you guys know. Thanks.
  2. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    697
    234
    Should be a simple deal. Remove stock one pull down sway bar, reinstall new one. I have a 4 post lift so I did it with the weight on the tires.
  3. Ohiotj
    Nov 29, 2014
    358
    116
    So I got a little done today. First the sway bar does clear now. Bwoody makes the correct sway bar end links to correct my problem. I can fit the weld rims with 6.7 BS and 30 mm offset in a 17" rim. It's tight to fit while on jack stand and no weight on the suspension. But it does clear. I did have to reem out the sleeve in the bushing but it's now done. Missed by about 1/64 of an inch from bwoody. Two of the sleeves worked and two did not. They shipped four out to me but I wanted to get it on to see if I cleared. Now I need a nice day to race!
  4. Trucker Bob
    Trucker Bob Silver Member
    Feb 21, 2015
    390
    99
    Northern IL
    Put your jack stands under the front A-arms that will load the front suspension. Some times it's good to wait until you hear from others. By your post it seems like you didn't wait since you had to reem things out. I'm saying and I'm not one of them by Far,But a lot of great minds on this Sight.
bwoody end links
bwoody end links install
hellcat swaybar
how to change stabilizer bar end links ram 1500
installing bwoody end links on a dodge challenger
replace front charger sway bar links
