Switched upper pulley, I feel Gilgamesh's pain.
Discussion in 'SRT Hellcat General Discussions' started by moparmangamble, Apr 30, 2016.
  1. moparmangamble
    moparmangamble Gold Member
    Sep 7, 2015
    417
    269
    image.jpeg Here's my OEM upper pulley. PITA go figure. Fought me every inch! I had most of the inner hub cut away, maybe 1-2 threads were still engaged. Made 2 more cuts and some type of thread lock was sizzling and let go. I disassembled my snout to check the bearings, all okay.
    • Winner Winner x 2
  2. moparmangamble
    Sep 7, 2015
    417
    269
    image.jpeg Front bearing is a 6405, rear is a 6305 if anyone wanted to know. I also recorded dimensions on the 8 pin pattern if guys need to make a holding tool.
    • Useful Useful x 2
  3. slester1
    slester1 Silver Member
    Jan 13, 2015
    352
    86
    Damn I can see this might be one of those tales that keeps my wrenchs in my drawers.
    • Winner Winner x 2
  4. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,666
    549
    423
    Chattanooga, Tennessee
    You are the first I have seen that had to cut the pulley off. May I ask why?
  5. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    I just did my 3rd one without any of issue, sorry for your troubles
  6. moparmangamble
    Sep 7, 2015
    417
    269
    Second one to be cut off. Wasn't a big deal other than extra time which I don't have a lot of. I own my own fab shop so I have everything at my disposal including CNC mill and lathe. Just irritating. Double pinned my ATI lower, new injectors, even spark plug change went well. Had to be one snag...
  7. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    334
    181
    If you're willing to share the details on the pin layout for the holding tool I'd owe you a big favor.
    Sorry the original pulley put up such a fight - good job getting it done.
    rick@metcomotorsports.com
  8. moparmangamble
    Sep 7, 2015
    417
    269
    The 8 pins have a diameter of .235". The diameter of the bolt circle is 1.615". On my mill with Accurite contoller I just pick my bolt circle with 8 holes and the magic happens! LOL That SOB would not let loose! But it was no match for a cut off wheel!
  9. Rick@Metco
    Sep 7, 2014
    334
    181
    1.615" measured across, center-of-pin to center-of-pin?
  10. moparmangamble
    Sep 7, 2015
    417
    269
    1.615" center of pin to center of pin, you had a typo.
  11. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,381
    688
    413
    PASADENA, CALIFORNIA
    I thought you were already making these tools? I heard mention of it MONTHS ago. Sorry to bust your balls, but I would not even buy a pulley without this tool, so hopefully it will be affordable or we can rent it etc.........
  12. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    281
    129
    New Mexico
    I remember Gilgamesh's thread, that's why my metco 2.85 is still in my tool box.
  13. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,768
    515
    423
    Henderson, NV
    Sorry a little late on this, but do we have a pulley removal tool for the Hellcat? I know the Shelby has a bunch of vendors that make them. I've never seen a pulley have to be cut off like that.
  14. moparmangamble
    Sep 7, 2015
    417
    269
    With Rick asking I'm sure they'll finally make them to hold the 8 pins. Problem is if the pulley is locked to the shaft like mine when you try turning the pulley off, you are turning the pulley and shaft together and the bolt retaining the 8 pin hub backs out. I tried over and over, then tried heat, and a little more heat, etc. Nothing. I cut everything away to get at the inner pulley hub. I then cut away the part of the hub that is threaded. There was 1-2 threads left and I couldn't budge it. At this time, I had the shaft out of the snout and in a vise, and a pipe wrench on what remained of the hub. Next I cut diagonally to avoid the cut off wheel contacting the bearing. I made 2 cuts and something started sizzling and smoking, large deposit of thread locker? Then I grabbed it with my leather glove on and spun it off by hand. Fought me all the way to the end! Maybe the assembler of mine and Gilgamesh's loves loctite! It wasn't difficult to cut off, just frustrating and time consuming.
    • Funny Funny x 1
  15. Rick@Metco
    Sep 7, 2014
    334
    181
    NO ONE has been willing to share the necessary details until now.
    Because the HC uses a threaded supercharger shaft, it is necessary to hold the shaft stationary to unscrew the original pulley and thread the replacement pulley into place. It is for this reason that the blower must be partially disassembled and the snout removed to access the shaft pins at the rear.
    OP, PM sent.
    • Useful Useful x 2
