The Charger has been sitting since Dec 10th
Discussion in 'SRT Hellcat Maintenance' started by sizzler, Jan 30, 2016.
  1. sizzler
    sizzler Rookie
    Dec 12, 2015
    23
    13
    Irwin, PA
    So I thought I would through a trickle charger on it (justin case). Measured voltage (percentage) with the charge I have and it read 20%. I thought that was quite low, so I charged the battery for 6 hrs and it was up to 62%. I feel something is not quite correct but will leave it on overnight.The voltage read 11.23 DC....I know and realize there is a lot going on even when the car is shut down but is this normal for a new car. It most likely see any road until mid March unless the weather changes to the better.
  2. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,086
    274
    Newport, MI
    I've read somewhere that the battery can be near dead after sitting for just 3 weeks. I put a CTEK battery tender as soon as it went into storage. I've also read u can put car into some sort of delivery mode to shut a lot of things down
  3. sizzler
    sizzler Rookie
    Dec 12, 2015
    23
    13
    Irwin, PA
    TY, I will look further into the delivery mode idea.
  4. MattG
    MattG Gold Member Hellcat Car Club
    Mar 12, 2015
    851
    457
    Allentown, PA
    I can't leave my Cat alone for too long. I have to go out to the garage and open the doors up to the exhaust and start it up every so often.
    But agree a good trickle charger can't harm anything. Careful of the trunk being open. there is a suggestion in another post that says to close the ( ? clasp) on the lock to the closed position. This turns off the trunk light.
    Matt
  5. terryturner
    Apr 1, 2015
    1,086
    274
    Newport, MI
    Or u could just hook it up under the hood. If u want to go straight on the battery tho just unplug the trunk light
  6. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    350
    161
    NJ
  7. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,122
    739
    just put a battery tender on it all winter....put the leads on under the hood(not the trunk)
    if your going to store any modern car for more than a month it needs to be on a charger...they are like $30 on amazon.com
  8. Catless
    Catless Silver Member
    Feb 2, 2015
    991
    204
    Parkersburg, WV
    Typical drain is .030 amps or about 3/4 Ahr per day. A month or so can half discharge the battery.
    It has been stated the 2015 and up goes into a "deep sleep" mode after a period of days but I choose not to risk it and just hook up the Battery Tender if not driving for more than a week or so.
