the Hellcat burns some serious oil
Discussion in 'Dodge Charger SRT Hellcat' started by blaze, Dec 28, 2015.
  1. blaze
    blaze ☆★✪ The Watcher ✪★☆ Hellcat Car Club Gold Supporting Member
    Dec 28, 2015
    2,030
    974
    498
    26.7100° N, 80.0500° W
    thread title edit:
    the Hellcat *can burn some serious oil if you are not paying attention*
    i know i read some threads on this somewhere around here but my car went through a lot of oil before i realized it. i was told by a couple different service managers not to change my oil at 500 miles and that was "old school"
    and i did not need to worry about it till 5 grand or whatever the owners manual specifies.. upon speaking with a great tech, i learned that "old school" is the way to go (in his opinion and mine) and that you need to watch the oil consumption closely on this vehicle with any "spirited" driving.. i stopped reading the forums for a while and came back and saw some horror stories.. i thought the engine had already been tested and DYNOd before install so i figured it may be a little low or consume a small amount of oil.. no.. i was about 2.5 quarts shy of being really sad with a blown motor.. i am still worried about it. if only i had taken the time to pull the dipstick once in a while.. i feel like a real... dipstick... as i place my palm to my face and facepalm.. :oops:
  2. ppowell1983
    ppowell1983 BANNED
    Mar 24, 2015
    863
    401
    Plainfield, IL
    I've checked my oil the night I got it and I have Checked it two additional times in the first 500 miles. I have not had any oil burning yet. I will be taking to get its oil changed the first time I take it out of storage.
  3. blaze
    Dec 28, 2015
    2,030
    974
    498
    good deal. i made a very serious error not keeping an eye on it.. it will go through some oil. i guess i just got caught up with it being new and wanting to drive and drive and...drive. it says to check oil level during fuel up in the owners manual i believe..
    i plan on making this a habit now.. does anyone have any feedback on what damage i may have done having 2.5 to 3.0 quarts as opposed to the full 7? its well known to always check your oil, i do not know how i made such a rookie mistake. i did not think it would go through that much with only 3,900 on the odometer..
  4. DrRouse
    DrRouse Hellcat Member Hellcat Car Club
    Aug 28, 2015
    38
    20
    New York
    Mine burned just a half quart during the first 500 miles. I changed the oil at 800 miles and have not burned any at all since then. Car now has 2K miles.
    I seriously doubt you damaged the engine running a low oil level unless you either ran very high oil temps or it starved with low oil pressure due to sustained high g's, which is highly unlikely unless you were lapping a track.
    Just monitor oil pressure. Significant bearing damage often results in low pressures.
    Good luck!
    • Agree Agree x 3
  5. blaze
    Dec 28, 2015
    2,030
    974
    498
    ok thank you DrRouse
  6. Jim M
    Jim M SRT Hellcat Supporter Gold Supporting Member
    Jan 12, 2015
    620
    217
    Oviedo, FL
    Mine burned a half quart in the first 1k miles. I changed it then and it hasn't used any since. I now have 4k miles and will change it again at 5k, then every 5k.
  7. blaze
    Dec 28, 2015
    2,030
    974
    498
    thanks Jim M, i am wondering how i could have gone through so much.. :confused: i drive it fast on sunday drives sometimes? im scratching my head when people tell me they have similar mileage and have not burned as much..
  8. Tammie
    Sep 11, 2014
    13,547
    4,631
    1,223
    Washington
    I freaked out the first time I checked mine and it wasn't registering on the dipstick, I felt like you did. I then found out the dipstick only shows the top 1.5 quarts of oil. I thought I had ran my car dry in first 1k, I was only 1.5 quarts low. My car does use some oil and was another 1.5 quarts low at 1,500 miles and first oil change and then again at 6,000 another 1.5 quarts low at second oil change. I check it regularly. It isn't using as much now as it did early on. I am only at 7,200 after 1 year.
  9. ppowell1983
    ppowell1983 BANNED
    Mar 24, 2015
    863
    401
    Plainfield, IL
    I plan on changing my oil every 3,000 miles after the first 500 then the next 1,500 miles
  10. blaze
    Dec 28, 2015
    2,030
    974
    498
    Tammie!!! its good to finally say hello to you! i watched you track your car on the freight and when you got it!! sooo cool. thanks for replying! and yeah.. i freaked out.. right in the service bay.. there were facepalms left and right.. :rolleyes:
    wait.. what? it only shows the top 1.5 quarts?
  11. Rham
    Rham Senior Hellcat Member Hellcat Car Club
    Oct 21, 2015
    129
    98
    I drove my hellcat 1,600 miles back from the dealer, only went through half a quart and has been fine since. My 08 Audi RS4 used to burn about 3/4 quart every 30-40 gallons of fuel. That ratio seemed high, so the hellcat is low maintenance in comparison based on my previous experience. It's always good to periodically check the oil on any vehicle though.
  12. blaze
    Dec 28, 2015
    2,030
    974
    498
    ok thanks Rham.. i think i went through 4.5 quarts of oil in roughly 4,000 miles though.. which seems..woa.
  13. NorCaletch19He77Kat
    Aug 30, 2015
    960
    294
    173
    zero damage done even though it may have been low according to measure standards.. volume and pressure in the oiling system will protect you even under low measure standards.
    the consumption is not at all abnormal--many of the Euro cars will not consider any diagnostics or attempt a repair unless continued use exceeds 1 qt per 500 miles..
    sleep well!
  14. blaze
    Dec 28, 2015
    2,030
    974
    498
    NorCaletch19He77Kat: Thank you.. as the sigh of relief washes over me..
  15. NorCaletch19He77Kat
    Aug 30, 2015
    960
    294
    173
    remember this too--oil consumption in a supercharged engine is normal--pressure on rings will make for blow by--all normal..
    • Useful Useful x 2
charger hellcat oil consumption
dodge hellcat burning oil
hellcat burn oil after track
hellcat oil burning
is anyone having oil consumption in hellcat
