Thoughts on my build
Discussion in 'SRT Hellcat Builds' started by He11ion, Sep 4, 2016.
  1. He11ion
    He11ion Silver Member
    Aug 31, 2016
    106
    69
    168
    Central Ohio
    So stock we made 621/575 on a dyno jet.
    Here is a list of mods done.
    ATI 10% overdriven crank pulley with pinning kit.
    Metco 3.10 upper pulley.
    Metco idler pulleys.
    BWoody anti-slip idler with a Metco pulley.
    Ported blower snout.
    Ported 95mm Throttle body.
    JBA cat delete with Vibrant Performance mufflers (Resonators) This really helped to keep it sounding stock.
    Brisk spark plugs (ER12S)
    K&N Air filter.
    160* thermostat.
    309 rear gears.
    Aluminum drive shaft.
    Custom tune by Crucial Performance in Columbus Ohio.
    Tires ET Street SS P305/35R20 on stock rims.
    **UPDATE** as of 9/24/16
    The car made 773/735 on the same dyno jet.
    The boost has increased 5lbs with the pulley combo. We are at 15lbs now.
    • Winner Winner x 2
  2. shadowsk
    shadowsk Silver Member
    Mar 10, 2016
    446
    201
    South Carolina
    My mods are:
    10% lower pulley (Stock upper)
    Metco idlers
    180 Thermostat
    309 gears
    DSS AL DS
    DSS Axles
    20" Nitto NT05R and 18" Mickey ET Streets (havnt run the MT's yet)
    Mine made 717/631 on a Dyno Jet in Charleston SC 100 deg/47 humidity. I'm only getting 2.5 more boost with mine but I'm happy where I'm at. Demon suggested I just do the lower since I wanted to stay with the kushy OEM drive. We didn't do a baseline because of time constraints (I was out of town on a schedule) and Demon Performance's dyno guy is an hour away from their shop.
  3. MABBRYFL30
    Feb 10, 2016
    7,959
    5,619
    1,163
    How much did this set up cost you?
  4. weebz
    weebz Gold Member Hellcat Supporting Vendor
    Jan 17, 2016
    547
    551
    568
    I agree it appears your 50 horsepower short for that setup.
    I see you did an email tune, that could be the difference there's no substitute for a custom Dyno tune. There's no mistaking HHP's reputation but no two cars are the same. When you do an email tune you're getting a generic tune, when you do a Dyno tune you're getting one that will get the most out of your car.
  5. Bstudey01
    Bstudey01 Gold Member
    Mar 26, 2016
    162
    493
    Racine, WI
    1st tune from hhp will always be on the safe side for fueling and timing. Get some logs and send em to Josh for a revision.
  6. Bstudey01
    Mar 26, 2016
    162
    493
    Racine, WI
    Btw again for safety he will not get very aggressive with timing on pump gas.
  7. weebz
    Jan 17, 2016
    547
    551
    568
    Why waste all that time and money sending tunes back and forth through email? Just go find a reputable Dyno shop and get one dialed in for your car.
  8. Bstudey01
    Mar 26, 2016
    162
    493
    Racine, WI
    Doesn't cost anything extra for a revision on the tune from hhp to dial it in. Just log a pull up to redline and log it with the trinity and email to them. Usually he will have it nailed down by 2nd or 3rd revision. Personally I would never let just any tuner touch my car. Imo thats asking for trouble. They are some horror stories from other tuners. Hhp has a bunch of cars dialed into the 9s and Josh really knows this platform well.
  9. weebz
    Jan 17, 2016
    547
    551
    568
    I paid just over $5000 for:
    10% underdrive pulley to include pinned crank
    American Racing long tube headers
    Custom Dyno tune
    740 RWHP
  10. He11ion
    Aug 31, 2016
    106
    69
    168
    Central Ohio
    So in all fairness I will see what Josh at HHP comes back with for a 2nd and 3rd tune if needed. I already sent him my log files we saved from the dyno and Trinity. The shop here in Columbus that I use has done a 2015 Charger and with meth injection on 16 lbs of boost made 780 whp. We compared the tune files on what Josh did in my car v's what my tuner did in the other charger and they are very close with the exception of timing the other car has a ton more timing through the whole pull. Josh doesn't have much timing in the lower RPM's at all. Josh has all my fuel tables stock but with this ECU and 02 sensors they can compensate for the needed fuel.
    To answer another guys question I have 8K in everything in my build list including the labor to install everything.
  11. weebz
    Jan 17, 2016
    547
    551
    568
    Real good investment. I can't wait to see your final numbers when they get it all dialed in, good luck.
  12. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,620
    673
    Meth injection needs to run even less timing as the meth advances timing! Playing with fire on that one IMHO.
    Timing on timing is never good. That's like a nos tune, and the timing is advanced.
    I don't know a whole lot of things about gassers, but meth + advanced timing is asking for trouble.
  13. weebz
    Jan 17, 2016
    547
    551
    568
    When you guys are saying "meth injection" are you referring to water-methanol injection or just straight meth?
  14. Racist Cat
    Jan 28, 2016
    1,620
    673
    I'd think it's a 50/50 mix. I don't know what is actually happening.
  15. He11ion
    Aug 31, 2016
    106
    69
    168
    Central Ohio
    Well Meth injection is really a band aid to achieve more timing in the motor. For an example you may only run 15* of timing WOT on 93 octane fuel without any knock, but when you add meth you can run 21* of timing at WOT without knock as this increases the octane to roughly 105 to 110. Another thing Meth does is decrease the AIT. So 6* will add a good bit of hp. The problem comes when something happens to your meth injection as you will now have to much timing for just 93 octane. I hope this clears this up for some. That is why a lot of people will switch to E85 as that equates to roughly 104 octane.
