Throttle Body Code! HELP!
Discussion in 'SRT Hellcat Purchasing' started by Drew871105, Sep 17, 2015.
  1. Drew871105
    Drew871105 Hellcat Member
    Sep 12, 2015
    54
    19
    So, I got the throttle body malfunction code merging into an intersection! Car feels very sluggish and it's like it wants to turn off! Any solutions before taking her to a dealer?
  2. Cimon hellcat
    Cimon hellcat SRT Hellcat Supporter Gold Supporting Member
    Aug 9, 2015
    221
    119
    What did you do , and how that started
  3. Drew871105
    Sep 12, 2015
    54
    19
    Merging into the highway from dead stop, gave it a lil bit of gas and as she straightens the warning came up
  4. Cimon hellcat
    Aug 9, 2015
    221
    119
    Unplug the batery for 10 seconds and plug it back in see if that going to help
  5. Drew871105
    Sep 12, 2015
    54
    19
    That's would reset everything wouldn't it?
  6. Cimon hellcat
    Aug 9, 2015
    221
    119
    Yes it will , happened to me once and I called one of my friends he Work service center and he told me to reset the battery and everything should go back to normal and it did
  7. Drew871105
    Sep 12, 2015
    54
    19
    Nothing so far
  8. Cimon hellcat
    Aug 9, 2015
    221
    119
    OK do it one more time if it doesn't do anything , your throttle body its in the loop the dealership they can reset it try one more time before you take it in
  9. Drew871105
    Sep 12, 2015
    54
    19
    Should I remove both leads or just negative?
  10. Cimon hellcat
    Aug 9, 2015
    221
    119
    Both the positive and the negative
  11. Drew871105
    Sep 12, 2015
    54
    19
    No luck friend, guess I'll take her in
  12. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Actually you only need to take off the positive terminal, then mash on the brakes, that will drain any residual current very quickly.
  13. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,541
    431
    368
    Henderson, NV
    Warranty item don't mess with it.
  14. Drew871105
    Sep 12, 2015
    54
    19
    So apparently my Throttle Body had to be replaced. My dealer was extremely helpful and understanding. Dropped off the car Friday morning and picked her up today. Technician said that so far, they have had to replaced 3 Throttle bodies on SRT products. He didnt say if it was a Hellcat only problem (do 392 SRT Challengers use the same Throttle Body as the Hellcat? I doubt it), but he did say that he was able to get me the only available throttle body IN THE WHOLE COUNTRY! Okkkkkkk. Guess I'm one lucky SOB.
    She rides beautiful again and i can sleep in peace also.
  15. rayzazoo
    Nov 8, 2014
    3,157
    1,130
    668
    392 uses an 80mm throttle body. The 'Cat uses a 92mm throttle body and a 64mm bypass throttle body (the one connected vertically to the supercharger housing).
hellcats 92mm throttle body
