Throttle body????
Discussion in 'Dodge Challenger SRT Hellcat' started by White noise, Jan 7, 2017.
  1. White noise
    White noise Silver Member
    Oct 3, 2016
    275
    139
    183
    Ft Lauderdale
    What's the verdict on the MM 95MM throttle body ... I know on my old car it made a huge difference hot the car responded but I also do not believe they give you HP but do believe everything works in unison and that each part helps the other to perform so .... how is it on the CAT???
  2. rayzazoo
    Nov 8, 2014
    3,498
    1,294
    668
    I think TopCat summed it up best: 95mm Throttle Body
    The stock 90mm is plenty and doesn't require tweaking; especially when you consider the 74mm bypass throttle body and part throttle driveability issues.
  3. White noise
    Oct 3, 2016
    275
    139
    183
    Ft Lauderdale
    thank you buddy ... yeah I found a couple of post and seems that its not needed and it seemed no one is really running them and they are hauling ass .... so I guess I will add that $500 to my 3.09 gear swap ....
    thanks again
  4. rayzazoo
    Nov 8, 2014
    3,498
    1,294
    668
    The 3.09 gear swap will be infinitely better than the Tbody
  5. catdodgehell
    catdodgehell VIP Hellcat Member
    Aug 30, 2016
    211
    102
    83
    Waco, TX
    I posted this before. I sent mine in to fastman and he bored, port, polished, changed the shaft small. So 95mm but WOT 98.5mm for $260. which is worth it. You will still have to go get it tuned or it will throw codes and put it in limp mode. If you send it in be ready to wait 2-3 weeks turn around. My tuner said stay away from after market TB. you can check it out here
    Contact The Fastman
  6. catdodgehell
    Aug 30, 2016
    211
    102
    83
    Waco, TX
    The "Bigger is Better Theory" is always an evil temptation but proper TB sizing does not work this way. All you need to do is match your motors air requirements. Once your motors needs are met going bigger than necessary is not going to give you anything extra.
