Tie down on trailer
Discussion in 'SRT Hellcat General Discussions' started by PlumTexasCrazy, Oct 21, 2015.
  1. PlumTexasCrazy
    Oct 3, 2015
    2,429
    776
    308
    TEXAS
    Any good spots to tie down on trailer. Going to haul the cat a few miles?
  2. 81cj8
    81cj8 Worth the wait!
    Feb 16, 2015
    571
    173
    I'm not an expert, but I'm designing a trailer right now. (Atc) I'm having it built with versa track so I can do over the wheel tie downs. Looking forward to some replays from some seasoned haulers
  3. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    I had a tough time getting mine home from the dealer in my enclosed trailer and its set up for cars.
    • Useful Useful x 2
  4. Satanscat
    Satanscat Rookie
    Oct 16, 2015
    7
    1
    If you have a car hauler that is open use the wheel basket straps that go over the tire and ratchet down on two connections on the side. Basket on all 4 wheels, car suspension still has flex to help ease the load on the trailer suspension.
    Something like this...
    Double Ratchet Side Mount Tire Strap
    • Useful Useful x 2
  5. 81cj8
    Feb 16, 2015
    571
    173
    Do you come out the window?
  6. 1949chopper
    1949chopper NC STATE PRESIDENT Hellcat Car Club HCC Charter Member
    Oct 5, 2014
    1,436
    687
    563
    Gold Hill NC
    Well he's not coming out the sunroof.
    • Funny Funny x 3
  7. Johntpr
    Johntpr VIP Hellcat Member
    Aug 10, 2015
    110
    46
    98
    Rockland County, NY
    Any issue with rear trailer door angle approach as far as splitter spoiler clearance? I also intended on picking my car in an enclosed trailer and was hoping it wouldn't be an issue.
  8. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Yup it's really hard to get out I tested my trailer out with my sisters challenger and it was a tight fit!
  9. PlumTexasCrazy
    Oct 3, 2015
    2,429
    776
    308
    TEXAS
    No car hauler
  10. 70Cuda
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    yep
    not a problem with the splitter my trailer has a large ( long ) door so it fit just fine on the ramp.
    the tie downs were a huge pain
  11. 70Cuda
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    my trailer is extra tall with the beaver tail ramp so it cleared the splitter, but a basic enclosed car hauler like a US Cargo Brand may be a problem you need to watch it carefully when you load for the first time
  12. zerokiller
    zerokiller VIP Hellcat Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    May 22, 2015
    119
    47
    98
    Ardmore, TN
    I use xtra long axle straps and loop through the wheels(I have microfiber strap covers so as not to scratch them) and then crisscross the heavy duty ratchet straps from the axle straps and to the D-rings. If the trailer doesn't have an escape door on the drivers side, it's through the window you go. On the beavertail I have to use 2 2x6s where the beavertail meets the flap, place them under the rubber cushions and 2 on the other side of the hinge to save the splitter. The HC fills a trailer pretty good (very tight inside). Be careful with the beavertail door cables and your side view mirrors.
  13. Redboots
    Redboots Silver Member
    Nov 30, 2014
    549
    134
    Southern Utah
    Here's what I've done. Get a set of ratchet straps with RTJ hooks on the end. Check ebay. About mid way under the door there are uni-body frame rails with a oval slot in them. Stick one of the J hooks in the slot, cross them, and go forward to your trailer hold down point. You'll need fairly long straps for this. In back, you can use much shorter straps. Take the J hook and put it through the upper suspension crossmember where the big holes are. Cross them to your trailer hold downs. The rear probably isn't ideal because your attaching to the cross member, but it's right where it bolts to the body so should be okay. Done deal.
  14. Rocket Man
    Rocket Man Silver Member
    Aug 27, 2015
    204
    92
    178
    Lexington Park, Maryland
    I crawled out the trunk. :eek:
best way to tie down challenger on trailer
double ratchet side strap car hauler tie downs
enclose db trailer tiedowns
enclosed car trailer hellcat
how to trailer challenger srt
