Tire god this is the result of RF balancing two of my tires
Discussion in 'SRT Hellcat Wheels and Tires' started by Aarcuda, Apr 21, 2016.
  1. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,464
    472
    258
    The Boonies
    image.jpeg image.jpeg image.jpeg image.jpeg check out the pics
  2. Tire God
    Tire God Hellcat Member
    Apr 5, 2016
    33
    18
    On the first pic. You see at the top where it says net pull? That's a shitload. One of the tires is shaped more like a cone than it is a circle. That is where your pulling issue is. Normal net pull should be about 2-8lbs. On the last pic, the harmonics of the tire is perfect. But you need to turn it on the rim. Assuming the rim runout is good, the tech should be able to fix the radial force variation and it should read between 5-15lbs. Anything 20lbs and up is technically out of spec and can cause vibrations. Not to mention he balanced with smart weight. Always make them turn off smart weight and balance to 0.00
  3. Tire God
    Apr 5, 2016
    33
    18
    If it's currently pulling right, rotate the rf to the lf. And then after that if it pulls left, the tire with the horrible radial pull is the current rf tire(in the pic). It's much easier to diagnose when I can see all 4 tires on the chart. And really easy if I can just fix it myself lol.
  4. Tire God
    Apr 5, 2016
    33
    18
    You have to have the shop call the tire manufacturer and send the tire back for radial pull, they will prorate it based on the tread depth not used. If the tire is within the first 2/32" of tread depth from new, they will replace it free of charge, but you will have to pay any shop fees.
  5. BODUKE
    BODUKE Gold Member
    Jan 31, 2015
    1,697
    395
    Detroit
    Even though you called my Camaro outdated and a pos, I hope your able to get this tire problem fixed soon.
    • Funny Funny x 2
  6. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,578
    637
    Was he lieing?
    Haha. Jk.
  7. BODUKE
    BODUKE Gold Member
    Jan 31, 2015
    1,697
    395
    Detroit
    Yes he was.
  8. Racist Cat
    Jan 28, 2016
    1,578
    637
    image.jpeg Hey.
    At least you don't have a Mustang.
  9. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,464
    472
    258
    The Boonies
    Lol. These two tires were supposedly the good ones that I took off the back of my hellcat. I took em off to put on my drag radials. Then we put them on the front of my wife's 392 to replace the backs that we wore out. Her original front went to the back
  10. Tire God
    Apr 5, 2016
    33
    18
    So was he able to fix the road force? Or were they left at 20ish?
