Tires slipping on wheel
Discussion in 'SRT Hellcat Wheels and Tires' started by Tire God 2.0, May 4, 2016.
  1. Tire God 2.0
    Apr 24, 2016
    382
    95
    The OEM Hellcat wheels have a riged bead seat area to minimize this issue. But even with that some of you still have this issue. This is perticularly bad when you pay for a road force balance. Hunter engineering states that after tires have been lubricated, you should drive like a grandma for 500 miles to ensure the lube dries completely to avoid the issue. I know this is probably not possible for some or even all of you, but I thought I would share this.
    • Useful Useful x 5
    • Like Like x 3
  2. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    I had this issue with drag radials on my 2013 SRT stroker that I race in the MSHS races. I resolved the slippage issue by mounting the tires dry and putting Permatex High Tack on the bead area of the wheel. Tires are a ***** to mount dry but it can be done.
    My tires have been thru two race days and one tire moved less than an inch and the other stayed in place. I was pulling 1.5 second sixty foot.
  3. Bandit
    Bandit Gold Member
    Jun 20, 2015
    975
    312
    I got tired of it and just drove 4 screws into my tires on each one. Screwed em right into the wheel. They don't hold air for shit anymore, but they aren't slipping!
    • Funny Funny x 10
  4. WNY Cat
    Nov 16, 2014
    588
    384
    513
    I have read that you can use Permatex High Tack on the beads to keep the tires from slipping. I plan to try it in a month or two.
  5. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Permatex High Tack....that is what I used not RV cement...
  6. Catless
    Catless Silver Member
    Feb 2, 2015
    1,032
    214
    198
    Parkersburg, WV
    Sounds like I better take photos of each wheel.
  7. Tire God 2.0
    Apr 24, 2016
    382
    95
    Race tires are very flexible. Street tires on the other hand, if you don't use lube you run a very high risk of ripping the beads, as well as the tires not seating properly.
  8. DB2
    DB2 Silver Member
    Feb 4, 2015
    342
    83
    I mounted my Nitto NT05R's on the Brvado's dry, they moved about 1/2 inch each side at first but that was it.
  9. Tire God 2.0
    Apr 24, 2016
    382
    95
    Yeah the race tires are pretty easy to mount dry. Also depends on the bead seat area. I would still use lube but also the permatex stuff.
  10. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Both my HC and 2013 SRT have dry mounted rear street tires....had to be very careful but worked...no slippage..
  11. Tire God 2.0
    Apr 24, 2016
    382
    95
    That's good. I would assume the tire glue would act as a lubricant long enough to mount the tires. Might be a good idea. Only other good option is to get bead lock wheels. (Not rim screws)
  12. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    The guy who mounts my tires cringes every time I mention changing tires...he says mounting them is a major workout...
  13. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,239
    620
    413
    PASADENA, CALIFORNIA
    This last time I had them balance the wheels without the tires. Installer said the balance machine actually had a setting for this. Both took weight exactly opposite the TPMS, 2.0 and 2.5 ounce. Then they mounted the tires and no additional balancing. I have found they always move when the tire mount is fresh. Then the heavy spot on the tire can align with the weights that were added causing issues. I am just too afraid to glue them on, because if they do turn anyways I do not want the glue balling up and disturbing the seal or any such thing. Plus the next time you need new tires do the installers have to clean the bead seats? Will they do a good Job? ANyhow, so far they are smooth enough for racing and actually run quite smooth at 75 on smooth highway. They have bounced some when first driven on the way to the track and even at the track depending on how long the car has sit or if they are in or out of sync.. But, for the most part they are smooth.
  14. DB2
    DB2 Silver Member
    Feb 4, 2015
    342
    83
    I dont want any glue on mine either, my Street R's moved a total of 2 inches in 4 runs. The first being the largest at 1 inch. Second launch about 1/2, the next 2 not so much. We'll see what happens.
  15. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,239
    620
    413
    Finspeed offers a knurled bead seat option that is $40 per wheel.
wheels slipping in tires
