Title
Discussion in 'SRT Hellcat General Discussions' started by Booky, Feb 25, 2016.
  1. Booky
    Booky Gold Member
    Feb 6, 2016
    854
    536
    763
    Removed
  2. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    901
    320
    173
    Akron, Ohio
    I have lifted my car several times under the differential. My jack has a thick rubber pad the distributes the load well over the base and does absolutely no damage.
  3. MoparR/T
    MoparR/T Senior Hellcat Member
    Sep 22, 2015
    73
    26
    I don't like to, but I have a few times. Hasnt hurt anything so far. On my old R/T I used to a lot.
  4. Q5Dart
    Q5Dart Gold Member
    Mar 4, 2015
    556
    322
    I lift there every time
  5. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    I don't like using the diff as a jack point for anything on a vehicle with an aluminum diff. If you do, a block of wood or rubber is definitely a good idea IMO. Distribute the load as much as possible.
  6. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,824
    1,304
    933
    Kenosha, Wisconsin
    I cut a 2x6 down for this very purpose. I wouldn't even consider metal on those cooling fins that are cast into the diff housing
  7. Jungle Cat
    Jungle Cat Silver Member
    Feb 24, 2016
    1,082
    251
    178
    Standard procedure on every rear drive car I have ever owned but never had one with aluminum. The wood is a great idea.
  8. Ray Hunsaker
    Ray Hunsaker Silver Member Hellcat Car Club HCC Charter Member
    Jan 26, 2015
    545
    157
    I do it all the time, I have rubber pad on my jack.
  9. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,622
    905
    Virginia
    Nope, won't do it. To much weight for an aluminum housing
  10. graybear
    graybear Senior Hellcat Member
    Nov 4, 2015
    95
    57
    I have a rubber pad on my jack and did lift the car using the differential. I noticed that the fins on the aluminum housing are not flat across the dif. so you do not get to spread the weight properly. I notice after I was done that it looked like the outside fin had cracked a bit. Luckily no oil leaking or anything like that but I will not be lifting it using the dif. ever again. Since the fins are cast they are more likely to crack than bend.
    • Useful Useful x 2
  11. Jungle Cat
    Feb 24, 2016
    1,082
    251
    178
    Sorry you had to be the sacrificial rear diff. I guess I will not be doing it then.
  12. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,454
    466
    258
    The Boonies
    i wont do it. why risk it?
  13. rollieman
    rollieman Silver Member
    Aug 17, 2015
    268
    49
    I considered it, but decided against it for the reasons cited above; instead, I use ZL-1 jack pads at the rear pinch weld jack points (both sides) and jack the car up evenly using 2 floor jacks.
  14. Jungle Cat
    Feb 24, 2016
    1,082
    251
    178
    I have considered this also but now where do the jackstands go in the rear?
  15. rollieman
    Aug 17, 2015
    268
    49
    You can slide the Zl-1 "pinch weld" jack pads slightly towards the rear to allow more room for your jack stands on the black pedestal pads which is what I do. (Note I use Esco #10499 flat bottom jack stands).
    Another option would be to use ZL-1 jack stops which would eliminate the need for jack stands; however, they are designed to be used with Pittsburg 1-1/2 ton floor jacks from Harbor Tool which are inexpensive and work great. Note: with this option I would add a jack stand slightly under the rear axle as a safety.
does the ranger quickjack work on a challenger srt
is it ok to jack your dodge charger by the differential
lifting challenger from rear differential
