Tpms and Stability Control with ESC Off
Discussion in 'Dodge Challenger SRT Hellcat' started by SlowSRT8, Apr 26, 2015.
  1. SlowSRT8
    SlowSRT8 Rookie
    Apr 4, 2015
    21
    Anybody know if the tpms system inputs any info to the stability control??
    Like if the tpms thinks the tire is low going into a hard right turn at the track would it send a signal to the gyro / stability control to start pulsing the brakes? Even with ESC off??
    Any information appreciated.
    Thanks,
    Dale
  2. B5 Blue
    1,747
    None that I'm aware of at least on an Audi which is more advanced
  3. paul suloff
    paul suloff Gold Member
    Aug 25, 2014
    753
    260
    I wondered the same, Low pressure on DRs will light a dash warning. Will that cause the computer to pull power? I'm not hearing from anyone who has already raced their car, that this is a problem. I attended an event recently with several SRT engineers there. They didn't indicate that the low tire warning would cause any effects on power. I'll be at the track as soon as my MTs arrive so we'll see.
  4. christman787
    christman787 Hellcat Member
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    are you sure you have the traction control all the way off? You have to be stopped with the traction on and hold the button down for 10 seconds and it will ding and say traction off. if it says drag mode or sport mode its not .all the way off
  5. christman787
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    I have ran mine twice with m/ts 305s with 18psi and never had a problem. I ran a 10.91 and 10.87 at 127mph
  6. christman787
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    Just remember when you shut the car off it will automatically turn back on and you will have to manually turn it off again.
  7. B5 Blue
    1,747
    nice runs!
  8. SlowSRT8
    SlowSRT8 Rookie
    Apr 4, 2015
    21
    Yes it's off with the button but I think I need the bypass switch for the twisties because going in a straight line don't have any problems. I don't think even on these cars that the ESC button turns it off 100%.
    When I get my SRT track day scheduled I will ask that specific question.
    Dale
  9. DGatzby
    Jan 16, 2015
    3,718
    1,987
    748
    Twin Cities, MN
    You hold that button down until it dings, it is off. Try it, the tires spin up much, much differently with mine. My '06 SRT had much less power, it was easier to tell the difference, same button, when it dings it is off.
  10. SlowSRT8
    SlowSRT8 Rookie
    Apr 4, 2015
    21
    It dings but I'm not sure that it's 100% off...
    In hard cornering you can feel the ABS system working....I still believe that the DSS module (if that is what it's still called) is still affecting it in hard cornering.
    The switch on the 2014 cuts it completely off and you can tell the difference in the corners
2015 challenger trackton controolll off
challenger hellcat esc
dodge hellcat esc
hellcat shut off esc
hellcat stability control
how to service esc on 2015 dodge challenger
turn off stabability control challenger 2014
