TPMS info
Discussion in 'SRT Hellcat Wheels and Tires' started by Tire God, Apr 17, 2016.
  1. Tire God
    Tire God Hellcat Member
    Apr 5, 2016
    30
    18
    If the tpms light is a solid light, it means low tire pressure. If the tpms light is flashing, it means a system malfunction for example, low sensor battery, dead sensor, or the receiver not working properly. The light comes on after a tire has dropped below the threshold of 25% below placard pressure. So if it says 32psi, it has to come on when it reaches 24 psi or lower. Sensors run off of a watch battery, last about 4-6 years or 100,000 miles on average.
    • Useful Useful x 2
  2. Slowpoke387
    Slowpoke387 VIP Hellcat Member
    Jan 31, 2016
    974
    250
    93
    Enfield, CT
    Was wondering if they still know where they are on the car after being rotated. Or will the info be incorrect location-wise after...
  3. Tire God
    Apr 5, 2016
    30
    18
    All the new dodges have an auto-relearn system. It takes up to one day of driving for the system to reset itself properly. Each tpms sensor has its own ID number and the computer will learn the new positions after a while.
    • Useful Useful x 3
  4. Slowpoke387
    Jan 31, 2016
    974
    250
    93
    Enfield, CT
    Awesome, thanks for that info.
  5. Catless
    Catless Silver Member
    Feb 2, 2015
    965
    195
    Parkersburg, WV
    Autolearn the position - but you can't always trust them. Our '10 Jeep and the 09 Challenger were prone to showing the tires in the wrong position. Not sure about the '15 Challenger, I haven't tested it. So if the system shows a low tire and it doesn't make sense when you check it, check all 4.
  6. Slowpoke387
    Jan 31, 2016
    974
    250
    93
    Enfield, CT
    Yeah i kinda just wanted to know so i could maybe know which one to check first. If it only shows one and its low then i wouldnt have to chk em all unless i wanted to.
  7. Tire God
    Apr 5, 2016
    30
    18
    Generally it's one day of driving, meaning driving for 24 hrs. It might take a while.
  8. Catless
    Feb 2, 2015
    965
    195
    Parkersburg, WV
    Ours always have relearned quickly maybe a couple of miles but I think the manual says up to 20 minutes of driving.
  9. Steven_sbs
    Steven_sbs Browncoats Unite Gold Supporting Member
    Dec 18, 2014
    818
    338
    South Jersey
    If I swap a wheel off of my car with a wheel off another Hellcat, how does the tpms deal with being on a new car?
  10. Tire God
    Apr 5, 2016
    30
    18
    If it is truly the exact year make and model it will work perfect. On rare occasions the vehicle manufacturer will change the type of tpms sensor from year to year, like if yours is a 2016 a 2015 sensor might not work. But if it is the same year make and model, it will relearn the sensor ID like normal.
  11. want2
    want2 Silver Member
    Oct 19, 2014
    133
    37
    Western Michigan lakeshore
    I just purchased a new set of rims and tires with the OEM Schrader TPMS installed and not from dealer. These were immediately recognized so where is the year relevant? My 'Cat is a 15. Also on the battery issue, the stock Schrader does not have a battery listed in the parts book at the dealer. When they go out, you just replace.
  12. Tire God
    Apr 5, 2016
    30
    18
    Correct. You can't replace the battery you have to replace the whole sensor. In some cases the vehicle manufacturer will change the type of tpms from year to year, like going from 315mhz to 433mhz ect... Not saying in your car. I haven't looked at the sensors in the Hellcats yet to see if they have changed at all. I'm sure it's the same. I was giving that info just in case. The NHTSA has been pushing the vehicle manufacturers to try to limit the different types to make them more uniform across the board as well as not use bolt in, and to use a rubber stem because it causes less probems. In fact honda, acura, vw, audi, have done away with the tpms "direct system" and went back to the old school "indirect system" where there are no longer sensors in the wheels, instead it uses the abs sensors to track the revolutions per mile and when it senses one tire spinning at a different speed due to low pressure, it turns the light on. Only downside is if they all lose pressure at the same rate at the same time it won't trigger it.
hellcat low tire pressure
reset tpms 2016 challenger after rotation
tpms 2016 challenger reset
