TPMS part number
Discussion in 'SRT Hellcat Wheels and Tires' started by Coldheartid, Dec 29, 2014.
  1. Coldheartid
    Coldheartid Silver Member
    Aug 29, 2014
    222
    77
    Miami Fl
    Well I just ordered a pair of 20x11 wheels that I plan on stuffing under the beast with 315x35's, However I do not want to break down the stock wheels just to get the TPMS out and would rather just buy new ones. Anyone know the part number.?
    Thanks
  2. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    What kind of wheels did you get? Pics? Links?
    I'm anxious to see them installed and get the specs as to offset/backspace.
  3. Coldheartid
    Aug 29, 2014
    222
    77
    Miami Fl
    Bravado.jpg This is the wheel 20x11 21mm ET on rear and 20x9.5 18mm ET on front when they get here in about 2 weeks. Just need the TPMS part number so I don't have to break down the stock wheels.
  4. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    I'm curious to see what's the smallest diameter wheel that will clear the brakes, for more tire sidewall when running a slick.
  5. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    The back brakes are not the issue,, you could probably throw a 17" wheel on the back
  6. Coldheartid
    Aug 29, 2014
    222
    77
    Miami Fl
    There is no good service anywhere??
    I called
    [​IMG]
    I called to get a part number for the TPMS on my 2015 Dodge Hellcat and heres how it went.
    I was given part number 56053037AB when I asked the price I was told $5.85 to which I said that can't be correct as they usually run $50 to $100 for this part then he said oh yeah here it is part number 68020719AC or if that doesn't work try 56054084AA and they run $60.20 I said thank you and proceeded to put these part numbers into your system and found neither of them to be the TPMS (Tire pressure measuring sensor) either. I will not be buying from your business nor will I recommend to any of the folks I converse with on Hellcat.org in fact I will caution them away from your service and explain my experience. Thanks anyway.
    This car is just too new to get parts from most places. I have however recommended for EBC to let me know when they get Redstuff for our cars so I have a POC there. I also contacted discount tires direct and Hellcat has been added to the site. I'll tell you what, It is a lot of work to teach all the Dodge salesman and get the aftermarket suppliers on board. I'll be glad to go back to my real job on the 5th. lol
  7. B5 Blue
    1,745
    Do your wheels have rubber valve stems? If so it doesn't have a sensor it uses the ABS sensor noise like an Audi I assume. My R/T has rubber stems.
  8. ResumeSpeed
    ResumeSpeed Platinum Member Agent 707
    Nov 1, 2014
    9,805
    4,904
    1,563
    Donate to this user:
    Donate money to this user
    56053037AB - Sensor nut (Challenger HC)
    68020719AC - Nut, washer, cap, valve core and seal (Challenger HC)
    56054084AA - Dodge Charger sensor
    The Challenger HC sensors are not listed in the parts system yet.
  9. Coldheartid
    Aug 29, 2014
    222
    77
    Miami Fl
    Yes, That is good info for those numbers and I also found out the sensor number is 56029400AE Won't know for sure until I see if the TPMS see's them after the road test.
  10. 1FSTCAT
    1FSTCAT The Punisher
    Dec 28, 2014
    1,130
    407
    358
    Virginia
    Questions?
    56054084AA - comes up as an air bag side sensor?
    56029400AE - did they work?
    any information on the Hellcat part number being released?
  11. fnkychkn
    Jan 24, 2015
    1,543
    648
    greasy cardboard box
    still no listing on StarParts.
  12. HellDoc
    HellDoc The Doctor is IN!
    Jan 8, 2015
    249
    154
    Atlanta, GA
    True on brakes! but will it clear control arms on inner side of rim.
  13. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    I think those may have a clearance problem, good luck, let us know
  14. lbeagles
    lbeagles Hellcat Member
    Nov 12, 2014
    69
    14
    You will need both part numbers. The stem nut is not included.
    Nut #56053037-AB 3.38 ea.
    Sensor #56029400-AE 69.63 ea
    Other part numbers,
    Hellcat wheel #5LD38VXW-AB $1065.00 They can be bought for $1000.00 if your dealer treats you right!
    SRT center caps #5QW99RXF-AA $18.75
    FYI, It appears that Centerline is the manufacture for the Hellcat wheels..
    When I ordered the center caps they where sent in the Centerline packaging.
    Does anyone know a contact at Centerline and see if they would make us a wider matching aftermarket wheel?
  15. 1FSTCAT
    Dec 28, 2014
    1,130
    407
    358
    Virginia
    Interesting, would have never guessed Centerline. The rims are the perfect match to the CHR BBS series of rims.
2015 challenger hellcat tpms
2016 challenger no tpms
20x11 on a hellcat
dodge challenger 2015 tps sensers
dodge charger hellcat wheels part number
hellcat hood part number
hellcat rims part number
hellcat tpms
