TPMS question!
Discussion in 'SRT Hellcat Wheels and Tires' started by CDNHellcat, Feb 22, 2015.
  1. CDNHellcat
    CDNHellcat Silver Member Hellcat Supporting Vendor
    Nov 23, 2014
    499
    223
    Vancouver BC
    I have 18" rims with the Nitto NT05R 305/45R18 with a 28.9 inch diameter that I used for drag racing my 2010 RT Classic. The question I have is that some have speculated that if I don't have the tire pressure sensors in the rim it will cause the Hellcat to bog done or cause electronic issues. Now with my 2010 I had an interceptor gauge pod that allowed my turn off traction control and outside of my tire light showing on the dash it caused me no bogging issues.
    The stock tires look like they measures i at 28.66"
    So without having a tuner the variance is;
    Revolutions per mile (km) 700.11 (435.03) for the 305/45/R18 compared to stock 703.67 (437.24) 3.56 (2.21) which is less than 0.5%.
    I know with my stock tires on my RT of 245/45/20 the car would go into limp mode as the revolutions did not match or was outside of tolerance.
    With the stock tires being a 275 and the Nitto's in a 305 I'm as close as I'm going to get.
    With the new Hellcat is this an issue?
    Thanks!
  2. fnkychkn
    Jan 24, 2015
    1,612
    700
    greasy cardboard box
    not sure if 0.5% is enough of a difference to cause problems but missing TPM sensors should only cause warning lamp illumination.
  3. CDNHellcat
    Nov 23, 2014
    499
    223
    Vancouver BC
    Awesome, don't want to waste money with sensors just for a mil light as I don't keep the tires on when I'm off the track.
  4. Brauner
    Brauner Active Hellcat Member
    Mar 18, 2015
    106
    30
    28
    just installed my 18" Bravado Tribute wheels without the TPMS and it bogs or goes into limp mode. I will try to install a new set and see if that makes a difference
  5. B5 Blue
    1,745
    Correct, no issues with mine on
  6. B5 Blue
    1,745
    What are you talking about? I've had mine for a month and no sensors don't cause a bog. TPM is just a warning and nothing else.
  7. Brauner
    Mar 18, 2015
    106
    30
    28
    HMM... wondering what would be causing it then? Would it be possible the car thinks something is wrong and that why it would go into limp mode?
  8. Brauner
    Mar 18, 2015
    106
    30
    28
    it was acting like the traction control was on but I had it in track mode and the light indicated traction control was off.
  9. B5 Blue
    1,745
    You got another issue then, mines at track every weekend and track is how I do burnouts
  10. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    718
    249
    Traction control is not all the way off unless you hold the button down until it beeps. Track mode only partially disables it!
  11. Brauner
    Mar 18, 2015
    106
    30
    28
    I will give that a shot, thanks!
  12. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,066
    650
    413
    So Cal
    Fyi I have sensors and when you drop the tire pressure down to 18-20 psi the light comes on anyway so if they are just track wheels you don't need them.
  13. DB2
    DB2 Silver Member
    Feb 4, 2015
    342
    83
    I have the same combo, bravado 18's without sensors. I install them at the track & get 6 runs or so in before i get a TPMS warning. I have never had any bog whatsoever. When i put my stocks on at the end of the night it only takes a mile or two for the system to be happy.
  14. Rickymoto
    Rickymoto Rookie
    Oct 12, 2014
    22
    2
    What do you means limp mode, because my a8 hellcat wont shift with the 17" hossier slicks.
2015 challenger tpms
2015 hellcat tpms
dodge challenger tpms traction control light
dodge hellcat tpms
hellcat tpsm a8 problem
hellcat traction issue
why does my hellcat go into limp mode with the new forsyth auto body
will low tire pressure on a 2016 dodge 2500 put it in limp mode
