tpms
Discussion in 'SRT Hellcat Wheels and Tires' started by BALZ-OUT, Nov 19, 2015.
  1. BALZ-OUT
    BALZ-OUT Hellcat Member
    Oct 8, 2015
    61
    20
    NEWYORK
    hey can anyone tell me if these are the right tpms for hellcat. they are a lot cheaper on ebay or amazon
  2. FarAwayFromHere
    FarAwayFromHere Gold Member
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    If you are going to get a set,go for ones with rubber flexible stems.
    The ones shown are solid stem and the retaining nuts are very suseptable to corrosion(they split in half basically) they can be repaired with a kit though!
    Schrader makes them the frequency they work on 433.92 MHz.
    For a 2009' challenger I am not sure if they have changed freq. for the 2015 or not.
    I believe Replacement ones supplied by schrader are self learning so no scan tool is needed to set them up,check their website not SURE!
    https://www.schraderinternational.c...ary PDFs/North America/EZappCoverageV532.ashx
    2015 OEM p/n 56029398AA
    Schrader EZ-Sensor P/N 33200 (same for model years 2008-2015)
    These are 433 MHz frequency as well,this is from catalog!
    Below is look up vehicle,may be worth a phone call to schrader support to confirm
    P/N 's their catolog is not up to date!
    2016' OEM p/n 56029398 AB
    Schrader P/N 20398 This will be with the flexible Valve,
    but do require a scan tool I Believe.
    Look up here SCHRADER REGION
    Good luck!
  3. BALZ-OUT
    Oct 8, 2015
    61
    20
    NEWYORK
    i thought i saw some one right to use the metal ones for speed rating.., i dont know if its true or not
  4. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    I doubt if that makes any difference,
    I would have more confidence in the rubber ones honestly.
2015 challenger hellcat tpms
