TPMS ??
Discussion in 'SRT Hellcat Wheels and Tires' started by Jungle Jim, Jun 12, 2016.
  1. Jungle Jim
    Jungle Jim Gold Member Hellcat Car Club HCC Charter Member
    Sep 27, 2014
    454
    298
    513
    Kentucky
    Question for tire god or anyone else that has the answer.
    What is the hi/lo range of tpms? Reason for my question has to do with DR's. Is there any reason why I can't use the tpms with them? Will the tpms read low enough to show on the screen (ie 17-18 psi)?
  2. Tire God 2.0
    Apr 24, 2016
    367
    91
    They will read from 0 psi to probably 60 or more. There is no issue running them with DR.
  3. Jungle Jim
    Sep 27, 2014
    454
    298
    513
    Kentucky
    Thank you for quick answer......
  4. TNCHARGER
    Nov 19, 2015
    1,169
    425
    258
    The only issue with a DR will be at the track. When you lower the PSI below the threshold (not sure maybe 30LBs?) you will get an alert tire pressure is low. Not sure how the HC does the alert but my 2013 SRT would ding and flash a warning in the EVIC. Very annoying when trying to concentrate on the tree. I had my tuner turn them off.
  5. Tire God 2.0
    Apr 24, 2016
    367
    91
    Yes very annoying. Alot of people just don't run sensors in their race setups and have a tuner of some sort to temporarily disable the tpms warnings while racing.
  6. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    5,999
    2,872
    818
    Amen tire God. Keep on keeping on
    We need good knowledge and advice.
  7. Linda's Hell Cat
    Linda's Hell Cat
    Record Holder
    Fastest HC Charger/Record Holder
    Oct 28, 2015
    842
    807
    718
    Bucks County Pa
    I think it will just read low. No dinging or bell going off.
    I actually don't use the dash and I think its not accurate anyway. We measure tire pressure before each 1/4 mile drag.
    Linda :)
  8. TNCHARGER
    Nov 19, 2015
    1,169
    425
    258
    Linda AJ may have turned your sensors off? MY 2013 SRT gave me no choice about the warnings...it just kept flashing and dinging regardless of the settings until AJ switched them off in the tune...interested in this because I will be taking my cat to the track in a couple weeks with 18" DAs and no sensors..
  9. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,071
    503
    413
    PASADENA, CALIFORNIA
    I ALWAYS run TPMS in my Drag radials. I use a Schrader 28291 and they work very well. They are even relatively accurate at low pressures such as 13-14 psi.
    The light in the dash is a zero issue for me. It also will sometimes say to service the TPMS system when you start then car but then it goes to the pressure display. Not really an issue unless for some reason you cannot stop dwelling on it. After all, YOU are the one who let the air out. Right?
    After racing I pump my tires back up to 32 PSI and the second I start the car the warning light is already off.
    So, lets review.....I can see if I get a flat on the way to or from the track, and if I should happen to look down and see 9 and 14 psi on the display for the back tires, then I would know I am getting a flat at the track. Why would you not want this?
    Also, the OEM ones do read up above 50 psi and that seems accurate as well in my experience. Many cars including mine are delivered with high shipping pressure still in the tires due to lack of PDI.
  10. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,071
    503
    413
    PS: The light will come on at 27-28 psi and it needs to exceed 30 to reset.
  11. Tire God 2.0
    Apr 24, 2016
    367
    91
    Nothing wrong with running sensors. Just extra weight :p
hellcat tpms
