Transmission A8 limit
Discussion in 'SRT Hellcat Performance' started by Hector02, Aug 28, 2015.
  1. Hector02
    Hector02 Gold Member
    Apr 17, 2015
    158
    90
    278
    Hi
    what is the limit in whp for the A8 transmission on the Charger HC?
    What can be done to the transmission to support more whp?
    Thank you!
    • Funny Funny x 1
  2. SRT_HC_707
    Jan 1, 2015
    4,954
    1,445
    70.196059, -148.559760
  3. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    Someone posted quite recently a shop that does performance mods to ZF trannys (can't find it now.)
  4. TallCool1
    2,439
    831
    Pacific NW
  5. mowe
    mowe Gold Member
    Mar 25, 2015
    371
    195
    with a few 800-900 hp modified cars we have seen them have issues. I have seen them not want to shift into gear.... Guess we will see
  6. Hector02
    Apr 17, 2015
    158
    90
    278
    Thanks guys!
    Just want to see what upgrade can be done to be safe.
  7. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,452
    952
    668
    Cape Coral, SW Florida
    This Is something I posted elsewhere quite a while ago. Hopefully the links are still good
    I figured since this is new for the Challenger Hellcat, I would dig up some info and we can discuss this new transmission. Here are some informative
    links, a video showing the internals and some specs.
    An interesting thing is the converter can lock in first gear. Were the older units the same way?
    Also it can shift from 8th to 2nd.
    Along with a separate chain driven pump and other optimizations it looks like they worked hard to reduce parasitic loss.
    Main info:
    8HP Automatic Transmissions
    Video:
    ZF 8HP90 - Video
    NEW LINK Cars | 8-Speed Automatic Transmission - ZF Friedrichshafen AG
    Specs:
    8HP90_DataSheet.pdf
    ZF8 Info at Allpar
    845RE / 8R70: ZF 8-Speed Automatic Transmission for Chrysler cars
    ZF 8 Speed Automatic Transmission - Equipment and Tool Institute Tech Day - June13 2012
    Chrysler PDF Document
    Let's look at the transmission ratios for the Hellcat
    1st -- 4.714
    2nd -- 3.143
    3rd -- 2.106
    4th -- 1.667
    5th -- 1.285
    6th -- 1.000
    7th -- 0.839
    8th -- 0.667
    That first gear is crazy. I decided to do this because I wanted to know what was up with all the second gear starts I'm seeing. Then I wanted to compare it to other stuff. And then I just went silly with it :)
    Let's compare it to the NAG1 WA850
    1st -- 3.588
    2nd -- 2.186
    3rd -- 1.405
    4th -- 1.000
    5th -- 0.831
    So second is bit taller than first in the NAG1. ( Hellcat 2nd 3.142 vs NAG1 3.588 = 0.445 difference)
    Let's check out old school with the 904/727 for reference
    1st -- 2.45
    2nd -- 1.45
    3rd -- 1.00
    4th -- 0.69 ( later 4th used with above ratios, even the SRT Ram10 )
    Final Drive Ratio
    For the Hellcat with the 8 speed it's 2.62
    Tire: The 275/40R20 Pirelli P Zero is 28.7 inches in overall diameter.
    Let's look at gear multiplication, first gear comparisons for several ratios/setups.
    Hellcat
    ( 1st x Final )
    4.714 x 2.62 = 12.35068
    (2nd x Final )
    3.143 x 2.62 = 8.23466 (How I've seen people documenting 1/4 mile passes)
    Old NAG1
    ( 1st x Final )
    3.588 x 3.06 = 10.97928
    And to show the gearing now to my old school brain, let's compare it to some older stuff.
    OLD school 727/904 with various gear ratios
    ( 1st x final )
    2.45 x 4.10 = 10.045
    2.45 x 4.56 = 11.172 ( Close to NAG1 )
    2.45 x 4.88 = 11.956
    4.88s and still not there yet!!
    2.45 x 5.13 = 12.5685
    Hellcat vs Old School
    To compare a 1st gear start - Your final drive ratio would be around 5.04 with a 28" tire ( wow )
    To compare a 2nd gear start - Your final drive ratio would be around 3.36 with a 28" tire
    So back to the Challenger Hellcat. Let's look at max speed in each gear.
    It's basically
    MPH = ( RPM x tire dia ) / ( gear ratio x 336 )
    or
    MPH = ( 6000 x 28.7 ) / ( gear ratio x 336 )
    where 'gear ratio' will be ( trans ratio x Final )
    or ( 172,200 / (( trans ratio x Final ) x 336 )) @ 6000 RPM
    AND ( 177,940 / (( trans ratio x Final ) x 336 )) @ 6200 RPM
    1st -- 4.714 x 2.62 = 12.351 ( x 336 = 4,149 ) = 41.5 MPH @ 6000 -- 42.8 MPH @ 6200
    2nd -- 3.143 x 2.62 = 8.235 ( x 336 = 2,766 ) = 62.3 MPH @ 6000 -- 64.3 MPH @ 6200
    3rd -- 2.106 x 2.62 = 5.518 ( x 336 = 1,854 ) = 92.9 MPH @ 6000 -- 95.9 MPH @ 6200
    4th -- 1.667 x 2.62 = 4.368 ( x 336 = 1,467 ) = 117.3 MPH @ 6000 -- 121.29 MPH @ 6200
    5th -- 1.285 x 2.62 = 3.367 ( x 336 = 1,131 ) = 152.2 MPH @ 6000 -- 157.32 MPH @ 6200
    6th -- 1.000 x 2.62 = 2.620 ( x 336 = 880 ) = 195.6 MPH @ 6000 -- 202.20 MPH @ 6200
    7th -- 0.839 x 2.62 = 2.198 ( x 336 = 738 ) = 233.3 MPH @ 6000 -- 241.11 MPH @ 6200 ( we're past the aero limit here )
    Then we enter driving in a vacuum land :)
    8th -- 0.667 x 2.62 = 1.748 ( x 336 = 587 ) = 293.3 MPH @ 6000 -- 303.13MPH @ 6200
    That's right..let it rip to redline in 8th with zero wind resistance and look at the speed!! haha!
    Note: I watched the K&N dyno run, the shift into 6th was around 148MPH, 7th at 191
    So my above results are close. There is some rounding in the above numbers.
    Also the Tire dia used plays a part ( no resting weight, air pressure, using tire specs, etc ).
    So what did I learn.
    - Well, I have to much time for one :)
    - Starting in 2nd has a gearing disadvantage to older NAG1 and gears used before. They have 2nd gear start in valet mode and it would be nice to be able to toggle that feature separately in transmission settings. If 2nd gear start is used then gearing could be changed.
    - It's insane how final gearing in first gear is compared to old school cars. 5.04s on a 28" tire, really? Need to stop thinking old school gearing.
    Questions:
    When does the converter lock? I read that it can lock in first gear ( "The tall first gear allows for early lockup of the torque converter clutch. -- Allpar ). Under what conditions though? When does it lock on launch or hard acceleration?
    Maybe somebody will throw in a spreadsheet to play with ratios/tire sizes
    Anybody want to tackle the 6M??
    Mistakes? Let me know!
    Discuss :)
    Edited:
    v1.02 - Changed/recalculated old NAG1 gearing to 3.06, not 3.09
    - Changed "steeper" to "taller"
    - Added MPH calcs for 6200 RPM
    - Added link for Allpar ZF8 info
    - Added converter lockup quote from Allpar ZF8
    - Added Chrysler document link
    • Useful Useful x 7
  8. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,452
    952
    668
  9. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    man talk about need for speed haha
  10. Lucky Campbell
    Lucky Campbell Rookie
    Feb 8, 2015
    22
    15
    Max RPM 1 - 7 is 7000, max RPM in 8th is 5600
  11. Hector02
    Apr 17, 2015
    158
    90
    278
    I was looking at various site but neither tells what exactly can be done so the transmission support more than the 700 lb of torque
  12. sinister707
    sinister707 Silver Member
    Aug 10, 2015
    168
    28
    New Jersey
    i'm a rookie at this so please be gentle :)
    so i read the post and most of the documentation... is it really a flange that separates our transmission from supporting AWD?
    Reason i ask is because as you know at SEMA they unveiled an AWD Challenger... I'm looking at making my somewhat of a handling vehicle as opposed to a dragster. AWD would help :)
  13. DGatzby
    Jan 16, 2015
    3,644
    1,941
    748
    Twin Cities, MN
    We have a member doing 9.7 second quarters, in a A8 Charger so go for it.
    Way to go Linda and TC!
  14. ArizonaGasMonkey
    ArizonaGasMonkey Hellcat Member
    Jan 18, 2016
    31
    5
    Phoenix AZ
    TigWelder that's great info to share.
  15. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,611
    668
    I always drive my car in manual mode, and the TCC locks around 1,300rpm in 1st give or take a little.
    I also have an eco diesel. I think the 8spd auto in that sucker is very similar to the HC Trans.
    There are twin turbo kits out for the Eco diesels that put them around 450rwhp. (If the oilfield was doing better I'd have a kit on mine)
    The hp isn't the deal, but the torque getting close to 1,000lbs is interesting. Suncoast already has parts available. That is, if it's the same Trans.
8hp90 power limit c
challenger hellcat a8 modifications
charger hellcat transmission power limit
hellcat 8sp converter lockup mapping
hellcat a8 power limit
hellcat a8 transmission ratios
stock hellcat transmission limit
zf 8hp level check
