Is the HC Tremec configured with one or two clutch plates and does the rear end have an open or limited slip differential? Additionally, do the drive mode settings alter the state of traction control?
I recently had a situation where I spun the rear tire(s) on dry asphalt due to unloading one of the rear wheels during a slow speed turn onto a graded driveway. I couldn't tell if I spun only one or both wheels due to the lack of witness marks from my 3-season Pirelli's. A good friend tells me that some high performance cars no longer use a limited-slip differential. Instead, the brake at the corner with excessive tire slippage under acceleration is applied. In my case, I'm quite sure that upon engine start-up, traction control is enabled by default so I assume it was activated during this event and only the unloaded wheel spun. Any thoughts??
