Trickle charger
Discussion in 'SRT Hellcat General Discussions' started by Hell-of-a-Cat, Mar 5, 2016.
  1. Hell-of-a-Cat
    Hell-of-a-Cat Senior Hellcat Member
    Sep 12, 2015
    59
    Has anyone connected a trickle charger to their Hellcat? If so, how'd you do it? Did you connect to the battery in the trunk or the terminals under the hood?
  2. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,907
    4,068
    963
    at the battery please
  3. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    903
    323
    173
    Akron, Ohio
    Under the hood
  4. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,907
    4,068
    963
    Make mention that it is safe to charge battery from either location,however the the plastic b + cover hinge doesn't last long and tends to break at the hinge point. The plastic b+ cover is not a serviceable part and will need to be removed from a used harness, if u can find a good one.
  5. Sublimecat
    Oct 2, 2014
    903
    323
    173
    Akron, Ohio
    And the benefits? What makes a difference and why would Dodge give you a ground post under the hood if not to connect to?
  6. Hell-of-a-Cat
    Sep 12, 2015
    59
    I was hoping to go under the hood so I can run the plug behind the grill. Otherwise I would have to open the trunk every time I wanted to plug it in. If you don't mind can you explain the pro's and con's of either approach? Appreciate the advice.
  7. Sublimecat
    Oct 2, 2014
    903
    323
    173
    Akron, Ohio
    Page 174 of the 2015 owners manual outline the procedure for jump starting the car. It provides direction to do it from under the hood using the positive and negative post provided by dodge in the design of the car. A trickle charger hooked to the same location should have no issues. I am not an SRT tech but I am an electrical engineer. It doesn't concern me to charge the car from these points with a trickle charger.
  8. Catless
    Catless Silver Member
    Feb 2, 2015
    1,011
    208
    198
    Parkersburg, WV
    Battery Tender connected under the hood every winter on my 09 SRT and now the Hellcat. 09 Battery was still fine when I traded it Oct 2015 on the Hellcat. You are only talking an amp or so max so no problem with voltage drop.
  9. Obiefox
    Obiefox Silver Member
    Aug 22, 2015
    378
    97
    Cincinnati
    under hood
  10. Cglhawk260
    Cglhawk260 Silver Member
    Jul 20, 2015
    343
    122
    CT
    Under the hood so far this winter no problems. + and - connections.
  11. FarAwayFromHere
    FarAwayFromHere Gold Member
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Plastic fantastic.....
  12. Hellcat15
    Hellcat15 Silver Member
    Jan 3, 2015
    460
    141
    Chicago southwest subs
    Is it safe through the inside console power port?
  13. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    354
    165
    NJ
    image.jpeg Connect it under the hood. Red positive on the left under the cover and negative on the "ground post" on the right. Thats how they charge the battery during Dealer Prep.
  14. hemiplymouth
    hemiplymouth Silver Member
    Dec 13, 2015
    468
    135
    Bridgeport, WV
    Under hood here also
  15. SRCHALLENGER
    SRCHALLENGER Hellcat Member
    Aug 30, 2014
    84
    32
    18
    Fort Bragg, NC
    I plug mine I to the center console. No issues what's so ever. Do this with all my vehicles. One battery is going on 9 years.
trickle charger for challenger hellcat
