U joints a problem?
Discussion in 'Dodge Challenger SRT Hellcat' started by helldad, Sep 13, 2015.
  1. helldad
    helldad Gold Member Hellcat Car Club HCC Charter Member
    May 6, 2015
    135
    73
    278
    I started noticing a clunking sound in the last couple of days in low speeds, starting and stopping quickly. I thought it was the trans as I only heard it in 1st and 2nd gear, but I put it in neutral, and heard the same sounds while stopping spuratically. I'm gonna check with the dealer about new u joints, as this sound reminds me of when my u joints were bad on my 1st vehicle, manual s-10. It sounds like the front ones just behind the trans, but...
    Anyone else hear this? Did you upgrade your u joints with the upgraded drive shaft, for those that did this?
    Thanks for the feed back...
  2. 2510
    2510 BANNED
    Jun 1, 2015
    212
    73
    There are numerous threads on this one. Cars have had rear end issues, I would search for that and have the dealer check the third member - they (dealer) should be aware of this.
  3. GALTCAT
    GALTCAT Silver Member
    Jan 11, 2015
    216
    50
    When my wife drives the HC, I hear the clunking sound, when I drive it I don't. It appears she lets up too much on throttle when she shifts. Maybe the way she uses the clutch. She doesn't want to drive it anymore.
  4. NX91Notch
    NX91Notch Gold Member
    Jan 8, 2015
    497
    249
    Seminole, FL
    The drive shaft does not have u joints. It uses a form of a CV joint. The official name for them are: Plunging Cross Grove (CG) Constant Velocity (CV) joint, and Fixed Rzeppa CV joint
    The plunging joints are used at the center bearing and at the transmission end. The fixed joint is used were it connects to the diff.
    And the typically aren't known to have issues.
  5. helldad
    May 6, 2015
    135
    73
    278
    I only started hearing this noise within a few days... My driving hasn't changed since Break in, but thank you for the info.
    What is the third member?
  6. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,440
    457
    258
    The Boonies
    the third member is the rear gear housing and gears
  7. TomInNorCal
    TomInNorCal Hellcat Member
    Feb 6, 2015
    33
    16
    Folsom, CA
    I have exactly this problem too. My car is at the dealer now being looked at, the service manager was able to hear me reproduce the noise. I'll let you know what they say later today when hopefully it is fixed.
    • Useful Useful x 2
  8. TomInNorCal
    Feb 6, 2015
    33
    16
    Folsom, CA
    According to the dealer, they tried tightening a bunch of stuff (transmission mounts, exhaust hangers) with no luck. Then they lubricated the shift points, and the noise went away. It's gone now.
  9. helldad
    May 6, 2015
    135
    73
    278
    Wow. Thank you for the info. I will be taking Natsaha in to the dealer this week, so I really appreciate your feedback!
  10. helldad
    May 6, 2015
    135
    73
    278
    Turns out it was a bushing in the front of the shifter mounts that was making a noise, see # 5 on the diagram posted in my gallery. May help out the manual trans hellcat owners if they experience this issue.
  11. jojo80
    jojo80 Silver Member
    Jan 15, 2015
    221
    55
    SC
    okay... I got the same problem now on my Challenger M6 when shifting from 1st to 2nd. The issue came up since the clutch didnt engage in 4th gear one time... I was cruisin and shifting from 3rd to 4th. Shifter was in 4th, my foot not on the pedal...it took 5seconds and it suddenly engaged....since that time I have the clunking noise...
    Is there a service bulletin for the dealers? I would like them to take as little as possible apart and therefore want to precisely tell them what the issue is.
    What do they have to "open" to get this fixed....is this all from underneath the car without having to take parts off?
    thanks
  12. hopeful
    hopeful Senior Hellcat Member
    Feb 14, 2015
    137
    47
    Mine makes the same noise. I wasn't going to have it addressed until the next scheduled service. Does this pose a potential problem that should be looked at earlier? Thanks for any input.
    Hopeful
  13. stoneipa
    stoneipa Rookie
    Sep 4, 2015
    21
    Following. Same noise, but dealer couldn't figure out what it is.
  14. Sepipr21
    Sepipr21 Silver Member
    Oct 17, 2015
    405
    48
    I see the M6 have too many issues. Mine have been 8 days at the dealership and it doesn't seem to have an end to it. I'm paying so much a month and I cannot even enjoy the car Lol.
    I'm replacing the Clutch, I described the same noises in the Tans, stated in post number 1, and I have similar noises in right front tire(maybe the ball joints). Just 6K miles in the car.
    Do we have any replacements parts to avoid this issue? If not this is a weak, weak, kitty. And it's annoying me.
  15. Beelzebub
    Beelzebub Gold Member
    Oct 13, 2014
    198
    109
    Barton
hellcat popping and clunking
hellcat shifter clunking
problem with hellcats
