Uconnect model
Discussion in 'New Member Introduction' started by Jim M, Feb 24, 2015.
  1. Jim M
    Jim M SRT Hellcat Supporter Gold Supporting Member
    Jan 12, 2015
    620
    217
    Oviedo, FL
    I'm finding very little info on the Uconnect that is now standard in the Charger HC. I've found that there are 4 models with different functionality. The Dodge.com site says ask your dealer about the details. And now that it's standard equipment there is no way to view the details. So my question is, can you guys who are lucky enough to have your cars in hand take a look and see if there is a model number in little characters on the front? I'm hoping the model is "8.4N/RB5". That's the one with the most functionality. Thanks for your help.
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    I'm pretty sure all the hellcat's are the same,, one with nav, or without, everything top of the line
  3. RoyG
    RoyG Silver Member
    Sep 18, 2014
    397
    170
    Landenberg, PA
    Jim - sitting in car and looking at UConnect, not sure where to find a model number. System info only shows software version, stuff about Navi and map database.
  4. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,623
    702
    greasy cardboard box
    not sure which is available or standard equipment on Hellcat model but 2015 LD Charger can be equipped with one of 3 different radios.
    from FSM:
    RA2 - The RA2 radio has a 127 millimeter (5 inch) touchscreen with hard keys on the faceplate. RA2 radios with control knobs have an integrated center stack that allows the HVAC system to be controlled with the touchscreen, or the redundant controls. There is no external hands free module, all hands free functions are integrated into the radio. An optional remote mounted media hub contains access ports for a 3.5 mm auxiliary audio plug, a powered Universal Serial Bus (USB) connector and a Secure Data (SD) card slot.
    • 127 mm (5 inch) touchscreen
    • AM/FM receiver
    • satellite radio receiver (optional)
    • Bluetooth™ connectivity for hands-free phone; streaming audio; voice commands
    RA3 or RA4 - The RA3 or RA4 radio is identified by a 213.36 mm (8.4 inch) color touch screen display. There are no visible differences between the RA3 and RA4 with the unit turned off. However, on vehicles sold in the United States, the RA4 offers High Definition (HD) radio reception and can be identified by the HD symbol located on the screen when the radio is in radio mode. If the radio will not power up, the only way to identify the system is through a direct Single VIN inquiry using the TechConnect application on the DealerConnect web site.
    • 213.36 mm (8.4 inch) color touchscreen display
    • AM/FM/Remote Aux/USB/SD receiver
    • dealer activated factory installed Global Positioning System (GPS) navigation option (RA3 only)
    • factory installed GPS navigation (RA4)
    • iPod support via USB
    • remote steering wheel mounted controls
    • climate control integration
    • Electronic Vehicle Information Center (EVIC) personalization (optional)
    • 3G Wi-Fi hot spot capability (subscription required)
    • free form Short Message Service (SMS) dictation (subscription required)
    • HD radio receiver (RA4 only)
    • 911 - ASSIST automated calling
    • remote CD player (optional)
    • remote services - door lock/unlock, remote start, panic (subscription required)
    not mentioned above: 3D navigation is RA4 only. RA3 has 2D navigation.
  5. Jim M
    Jan 12, 2015
    620
    217
    Oviedo, FL
    Further online research has left me even more confused about which model Uconnect is installed. I found a chart to identify the Uconnect model that is installed but the numbers don't match the model info chart. I wonder if one of you might find it in the owner's manual.
  6. fnkychkn
    Jan 24, 2015
    1,623
    702
  7. Jim M
    Jan 12, 2015
    620
    217
    Oviedo, FL
  8. fnkychkn
    Jan 24, 2015
    1,623
    702
    8.4AN = RA4 in LA models
  9. Jim M
    Jan 12, 2015
    620
    217
    Oviedo, FL
    Thanks fnkychkn. I've found it now under Ram Trucks.
challenger hellcat u connect system
gps navigation for 2015 hellcat
ra3 radio hands free module
reset ra4 radio in challenger hellcat
uconnect on dodge challenger hellcat cd location
