Uconnect remote control
Discussion in 'Dodge Charger SRT Hellcat' started by freedave, May 10, 2015.
  1. freedave
    freedave Hellcat Member
    Mar 10, 2015
    40
    21
    McKinney, TX
    I looked to find if there was a suitable existing thread but could not find one. The issue is using the remote control app on a smart phone. I must admit that sometimes I just want to make sure the HC is locked. Well about 1 time out 10 it actually works if the car has been off for more than an hour. It always works in accessoriy mode. I have had several attempts by the Uconnect Assist people to help but the results are the same.
    I have updated the firmware and gone through a factory reboot / reset.
    I would just like to know how your experiences have gone.
  2. rubbel
    rubbel Gold Member
    Jan 28, 2015
    167
    86
    278
    Wimauma, FL
    I downloaded the app but never tried it so after reading your post tried app on my iPhone 6. First attempt to lock took about 1-2 minutes but did lock car. Unlocked and locked serval times with no errors after that. Each time was under 5-10 seconds.
    My car has been off all night.
    Also received emails confirming each request from UConnect.
  3. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    If you don't use it all the time, it takes very long to send the command,, it's nothing like on-star..100% not worth $20 a month
  4. freedave
    Mar 10, 2015
    40
    21
    McKinney, TX
    Thanks, it may be the Sprint network that is used. The theory from the assist group is that the cars system enters a lower power sleep mode that only polls for communication ever so often. Once it does wake up it stays awake for awhile until there has been no communication for some time then in goes back to sleep and like a teenager hard to wake up.
  5. DNTBTHR
    DNTBTHR Silver Member
    Dec 4, 2014
    367
    77
    Takes for ever
  6. Mtr
    Mtr Silver Member
    Jan 13, 2015
    268
    71
    Nah. If you talk to someone on the Sprint network, do they complain that your words are delayed by several minutes? If not, then it's not the network. :D
  7. shaystoy
    shaystoy Silver Member
    Feb 12, 2015
    59
    178
    Spring, TX
    I had the app for my jeep. Would send a signal to start when I walked out of my office. Very rarely was the vehicle started by the time I got to it.
  8. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    Since I have an M6, I have used it a few times to lock the doors and it has worked each time after a few hours of sitting. I can't tell you if it for sure worked everytime because sometimes I am not positive if I locked it when I put it in the garage so I will it the Uconnect lock just in case.
  9. freedave
    Mar 10, 2015
    40
    21
    McKinney, TX
    I get a timeout message when it fails. It does seem to be related to the amount of idle time. Unlike a cellphone that much more often pings the tower I the Uconnect goes to sleep doesn't ping and does not wake up until someone wakes it up. If I go to car after I get several timeouts then I send it a lock command and touch the door handle it honks and tries to lock the door.
  10. WindowShaker
    WindowShaker Gold Member
    Oct 1, 2014
    760
    428
    VA
    I've used it twice. Once just to test it out and the 2nd time when I had a friend that owns a mobile detailing company come by to clean the car. Since I work out of state during the week, I unlocked it when he got there. Took about 2 minutes. When I sent the signal to lock it back, I tried 3 times without success. Kept getting the "failed" notification. Finally called Uconnect and they were able to get it to lock. As someone else said, it's not worth the $20 a month, in my opinion.
  11. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    Temecula, California
    I have set it up also. I am on Verizon wireless that has 4G in most areas. When I make a command it always has worked, does take about 60-90 seconds though. Like most here, not worth the $20 monthly charge.
  12. freedave
    Mar 10, 2015
    40
    21
    McKinney, TX
    Yes, I agree unless the system works better and has more functionality it is not worth even $2 a month. There is promises of greater functionality but it also needs to be much more reliable.
control remoto uconect
uconnect 4g
uconnect dodge forum
uconnect remote control
uconnect remote control not working
uconnect remote timeout
uconnect requests fail often
