Understated Horsepower Ratings For The Hellcats
Discussion in 'SRT Hellcat General Discussions' started by Robo21, May 6, 2016.
  1. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    871
    430
    233
    So Cal
    In my online searches for Hellcat dyno results the average seems to be 670+ RWHP. We all know about the 15% rule for driveline loss. So adding the 15% back into the equation the flywheel horsepower should be no less than 790 HP.
    It would definitely not be unprecedented for an automobile manufacturer to understate horsepower ratings, particularly with insurance companies penalizing their customers for high output ratings. But I was surprised at the amount that Dodge has apparently understated the horsepower on the Hellcat - approximately 83 HP.
  2. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,004
    475
    403
    Westchester
    The 15% drive-train rule may not apply to newer 8/9/10 speed transmissions. Modern engineering has given the capability of lowering the percentage of drive-train loss. There is no way it's 5% drive-train loss, but the 15% number doesn't seem to hold true to any car today thanks to modern engineering
    • Agree Agree x 3
  3. saagz87
    saagz87 Senior Hellcat Member
    Feb 13, 2016
    157
    46
    I think we all know the 707 number is a bit understated based on some quarter mile times we have seen stock based on our vehicle weight. Still haven't seen a third party do a stock engine dyno on a bench. Would love to see that!
    I have also heard it makes 714 at 6200 rpm instead of the 707 at 6000rpm. But based on past experience, my bone stock ZL1 with TR6060 trans made 495whp before I modded it. Rated 580 at crank for 85hp loss.
    Hellcat with same trans has been said to make 670ish whp. Add 85 hp and your in the 750 crank hp range. I think that's somewhat accurate but it's hard to say. Some stick cars have dynod 650 range which would make more sense based on rating. But dynos are all different so.... Driveshaft angles and other things can change whp as well. It's not a direct or scientific comparison but I found in interesting to think about. As far as the 8 speeds go, I have no idea how much power they eat up to turn. But I love my 8 speed haha
  4. Rob Sold
    Rob Sold Silver Member
    Nov 22, 2014
    344
    89
    I had 674 on my back wheels on a dyno jet A8
  5. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    871
    430
    233
    So Cal
    Perhaps, the new auto transmissions are more efficient and perhaps the friction losses throughout the rest of the driveline have been reduced due to engineering improvements but a 33% improvement? Bringing it down to only a 10% drivetrain loss? I have a hard time believing that. But if that were true there should still be between 745 and 750 HP at the flywheel. The only way true numbers can be established is to either find exact driveline loss figures - hard to find - or bench test the engine. In any case, I think we can all agree 707 is underrated.
  6. Lucky Campbell
    Lucky Campbell Rookie
    Feb 8, 2015
    21
    14
    SAE engineers measured 714hp @ 6200, 652 lbs @ 4800, rated it at 707 @ 6000, 650 lbs @ 4800. Limiting factor appears to be RPM limiter, I have observed on various Dyno sheets with the RPM limiter removed that HP peaks at about 720-725 @ 6400, then is flat up to 6600 then begins to drops off. Obviously a camshaft would change the power profile.
  7. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,078
    2,954
    818
    What is a typical dyno charge to run it? No experience doing this and I would love to know. M6 cat for my car.
    It is one of those things we always say we want to do but never do. Kind of like getting your home property lines surveyed.
  8. themarshall
    themarshall Silver Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    Feb 3, 2015
    229
    50
    Everyone of you guys have good points. There is one other reason to think about N.H.R.A. Back in the day when Dodge & Plymouth uncorked the 426Hemi it was delibertly underated H.P. WHY? Insurance Comp. had not yet caught up with high H.P. engines. (1966-67) no problems there yet. Stock & Superstock class was decided by advertised factory H.P. vs. factory curb weight. Ford did this also with there 427 side oiler. Chev did this with there 427/ 435 vet. All NHRA tracks had what was called "weight brake" index books. The lower the factory H.P. the lower class you could race in, the lower class you raced in the more chance you had of going to the next round thus, " Win on Sunday sell on Monday " $$$$
  9. CAR BUFF
    CAR BUFF Gold Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    Aug 30, 2015
    212
    117
    Someone here posted a few months ago a a dyno sheet I don't remember the rear wheel numbers but it was 743hp at the crank.He stated it was a stock hellcat.
  10. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    871
    430
    233
    So Cal
    My '69 Z/28 was underrated as well at 290HP.
    743 HP is a helluva lot more believable than 707 based on the RWHP dyno reports and IMO still very conservative. I have a hard time believing the drivetrain loss below 12% but that's just based on gut feelings and educated guess work. Like I said above, we need to see a bench dyno or get some accurate drivetrain loss estimates.
  11. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,599
    451
    368
    Henderson, NV
    I'm thinking maybe 10-12% loss with the efficient drive train we have. Certainly not 15%
  12. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,339
    824
    Suwanee, Georgia
    May be they are waiting for Ford to announce their big hurrah before 2018 then with small modification, dodge go out with bang.. LOL
    • Funny Funny x 1
  13. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    871
    430
    233
    So Cal
    Bingo, 12% I can buy - but I just don't see a magical 33% improvement in drivetrain losses - 20% is huge and that would bring it down to 12%.
  14. phil hunter
    phil hunter Hellcat Member
    Sep 23, 2015
    85
    17
    NHRA quickly caught on to the low horsepower ratings as mentioned by themarshall. 426 Hemi was quickly factored from 425 hp to 525 hp. Ford 428 Cobra Jet was also quickly factored, but can't remember the number. Several other engines were factored as well.
    Phil
  15. 1949chopper
    1949chopper NC STATE PRESIDENT Hellcat Car Club HCC Charter Member
    Oct 5, 2014
    1,323
    630
    563
    Gold Hill NC
    How can it possibly be a percentage ? If we use 15% as driveline loss, my wife's R/T challenger only takes 56 HP to move the rear wheels but my Hellcat takes 106 ? What if I add 100 shot of nitrous, does it now take 121 ?
hellcat horsepower rating
hellcat stock whp
