Upper or lower pulley?
Discussion in 'Off-Topic' started by Hammer Down, Feb 24, 2016.
  1. Hammer Down
    Hammer Down Gold Member
    Jan 11, 2016
    437
    283
    South Jersey
    I thought I saw it somewhere, but can't remember and can't find it. So I need to pull from our knowledge bowl.
    Pcm swap and tune along with pulley swap. Is there a difference in boost gain whether swapping the upper or lower pulley? Im leaning toward the upper pulley because there is no grinding to do. But if im leaving too much meat on the bone ill do the lower instead. I'm only doing one as I'm content to stick with pump gas. Thanks for any insight.
  2. rags
    rags Hellcat Member
    Dec 27, 2015
    78
    16
    Westwood, NJ
    I've read 4 lb increase with a 2.85 upper. Lower was 2-3 lbs. That came from the HHP HemiTuner tuning thread.
  3. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    3,078
    1,544
    598
    Virginia
  4. TNCHARGER
    TNCHARGER Gold Member
    Nov 19, 2015
    1,222
    485
    408
    AJ (Hemituner) advised me to go with the crank pulley because the upper OEM has a clutch built in to it that lets the SC free wheel when you let off the gas suddenly. My pulley is being installed as I type this....
  5. TNCHARGER
    Nov 19, 2015
    1,222
    485
    408
    You are one funny troll Bo....LOL...I have had that pulley sitting on my work bench long before you began trolling here...
  6. TNCHARGER
    Nov 19, 2015
    1,222
    485
    408
    Because no one believes you....and I wouldn't race you if you really had something...people with your attitude are not fun win or lose the race...I guess I better stop feeding you as we have been hijacking too many threads..been fun BoTroll...now where is that ignore button..
  7. graycat
    graycat Automobile Aficionado Extraordinaire
    Oct 1, 2015
    1,355
    526
    Knoxville, TN
    I decided to do the lower pulley because I will be working there anyway pinning the pulley to the crank plus in my past experience the lower pulley has always worked out better for me. On my 14 GT500 the torque was improved at a lower RPM range than another car with the same mods but using an upper pulley instead of the lower one. Plus "belt wrap" is not an issue with the lower pulley.
    Both work well and I'm not saying that one is better than the other but for myself, it's the lower pulley. (First) I use only pump gas so the lower will be changed but I'll leave the upper as is.
  8. Hammer Down
    Jan 11, 2016
    437
    283
    South Jersey
    The issue I have at this point is I see it put that the upper will give less boost than the lower and then I have seen it the other way too. I am really looking for a definitive answer on that. If the lower will give me more boost as far as just doing one or the other then that is the way I want to go.
  9. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    I did lower and a 2.65 upper have not driven yet due to roads
  10. rags
    rags Hellcat Member
    Dec 27, 2015
    78
    16
    Westwood, NJ
    The percentage difference between the 8.1" stock lower pulley and the 8.9" ATI pulley is less than the percentage difference between the 3.35" stock upper pulley vs the Metco 2.85" pulley so the upper change will always have more of an impact on SC speed than the lower pulley change. That is as long as you are changing to the sizes I have listed.
  11. Hammer Down
    Jan 11, 2016
    437
    283
    South Jersey
    Thanks all. I had originally ordered it for lower pulley. Then called down to HHP and switched it to the upper after thinking about it. If the same then I would rather not grind down the block if not necessary. So I'm sticking with the upper. Do you still run into issues with accessories at idle, if you swap the lower? Or is it a double with no Change to diameter of that part?
  12. Ray Hunsaker
    Jan 26, 2015
    625
    203
    doing the upper you have the advantage of changing sizes if you ever need or want to. maybe you do a road trip one day and want to drag the next. who knows.
  13. rags
    rags Hellcat Member
    Dec 27, 2015
    78
    16
    Westwood, NJ
    Swapping the lower reduces the speed of any accessories sharing the same belt causing some to have issues. Obviously not on a Hellcat as the SC belt is only for the SC Swapping the upper does not have this problem because the SC is a driven pulley and not a drive pulley.
  14. Ray Hunsaker
    Jan 26, 2015
    625
    203
    double it only turns the blower.
  15. Booky
    Booky Gold Member
    Feb 6, 2016
    1,126
    749
    763
    That '15 GT500 is one rare car that will be worth a lot of money!;)
    • Funny Funny x 1
gt500 lower pulley
hellcat charger lower pulley
hellcat pulley swap
hellcat upper pulley only
hhp lower pulley hellcat
lower pulley change boost gain for hellcat
lower pulley change for dodge hellcat
metco lower pulley hellcat
