Upper Pulley Change
Discussion in 'Canada' started by Radride, May 2, 2016.
  1. Radride
    Radride Silver Member
    Jan 15, 2016
    1,026
    202
    198
    Up Here!!!
    How much are you guys getting charged to swap out the upper pulley and a tune? Locally, its $5000 apparently.
    R.K.
  2. Mills
    Mills Silver Member
    Jan 28, 2015
    775
    194
    Airdrie, Alberta
    Considering the PCM / tune will cost us $1600 US (call it $2k CDN) - 3k seems extremely expensive for what others can do varying from 4-8 hrs from what I've seen / read.
  3. Radride
    Jan 15, 2016
    1,026
    202
    198
    Up Here!!!
    That's what I thought as well.
    R.K.
  4. Linda's Hell Cat
    Linda's Hell Cat SRT Hellcat Supporter Gold Supporting Member Fastest HC Charger/Record Holder
    Oct 28, 2015
    1,681
    2,224
    763
    Bucks County Pa
    Is this a place that has experience working on Hell Cat's and or Modern Mopars?
    What is the break down for the Tuning?
    Linda :)
  5. Radride
    Jan 15, 2016
    1,026
    202
    198
    Up Here!!!
    Linda,
    This is a newer shop in town (a couple of years old) but seems to be messing with the Mopar stuff. They've done a couple of Hellcats I believe. Here in Canada, they're pretty rare so not to many shops are going to have tons of experience with them.
    R.K.
  6. Mills
    Mills Silver Member
    Jan 28, 2015
    775
    194
    Airdrie, Alberta
    What shop?
    I had the work on my Charger done at Dale Adams...the guy in the back wrenching had his own SRT and there were 5 other SRT's in there at the time getting varying work from cams, rears, all the way to a 426 S/C'ed Stroker Jeep. I was impressed with their knowledge...I ended up having a mis-ground cam that was "supposed" to be pre-checked in a motor prior to shipping and had I done it would have probably just tossed it in. Back then there was no adjustable timing set for the 6.1 (at least one that was even remotely cost feasible) and they came up with a way I thought was a decent solution. Everything worked great and wasn't too expensive all said and done for Intake / Cam / Heads / UD Pulley / Convertor Install
  7. Radride
    Jan 15, 2016
    1,026
    202
    198
    Up Here!!!
    It's just outside of Edmontonin Spruce Grove. CCMR
    R.K.
  8. Linda's Hell Cat
    Oct 28, 2015
    1,681
    2,224
    763
    Bucks County Pa
    I'm not shocked at your quote, because depending what ET you are asking for, $5,000 could include many items and be a fair price.
    Here is some info off of HHP's website, for the cost of Parts and their Tuning.
    http://www.highhorseperformance.com/SearchResults.asp?Search=hellcat
    What tuning Product does your shop use?
    If they have tuned Hell Cats, can they give you information for their work being track proven?
    Also, Josh also does do tuning remotely.
    For the quickest response, please call the shop 888-894-1115
    For sales questions use extension 306 for Greg.
    For tech questions use 302 for Bruce.
    For tuning questions use 301 for Josh.
    http://www.hhpracing.com/
    And here is a thread, that you may to read or post up a question.
    Hellcat Tuning Q&A's with Josh (HHP) and AJ (HEMITUNER)
    Linda:)
  9. Mills
    Mills Silver Member
    Jan 28, 2015
    775
    194
    Airdrie, Alberta
    Oh yeah - "Ron's Build" used them. Can't really argue with his dyno or track results...so they seem to know what they are doing
upper pulley on hellcat
