Vibration/grinding feeling at RPMs between 2500-3000
Discussion in 'Dodge Challenger SRT Hellcat' started by alxsanz, May 18, 2016.
  1. alxsanz
    alxsanz Hellcat Member
    Jan 19, 2016
    53
    17
    Northern Jersey
    Hi All,
    I have a 2016 Hellcat Challenger M6 with only 1,000 miles. About 100 miles ago I started to feel this vibration/grinding feeling under my feet by the pedals when I'm in 1 to 3 gears between 2500-3000 RPMs. Has anyone experience this issue? If so what's the cause and fix. Any feedback would be greatly appreciated.
    Thanks,
    Alex
  2. pivotal
    pivotal Senior Hellcat Member
    Mar 24, 2016
    122
    35
    Silver Spring MD
    Have you made any modifications to the car? Does the vibration/grinding only happen when you're in gear?
    Matt
  3. alxsanz
    Jan 19, 2016
    53
    17
    Northern Jersey
    The only thing that I did was the muffler delete, but that was at 68 miles, this started happening at 800 miles. Yeah, only happens when I'm in gear.
  4. pivotal
    Mar 24, 2016
    122
    35
    Silver Spring MD
    Hard to say for sure - could be a bearing or bushing, or something wrong with the flywheel. With so few miles, I'd take it to the dealer. Good luck.
    Matt
  5. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    1,010
    524
    413
    So Cal
    It does sound like something in the manual transmission. I got lucky and found that all the grease had run out of one of the rear CV boots before something broke. I would get it in ASAP.
  6. alxsanz
    Jan 19, 2016
    53
    17
    Northern Jersey
    Got it towed to the dealer this afternoon...it was doing it all the way home from work ...I'll call the dealer tomorrow and see what's up.
  7. CanHP
    CanHP Silver Member
    Mar 23, 2015
    323
    123
    Mississauga Ontario
    Let us know what they find
  8. pivotal
    Mar 24, 2016
    122
    35
    Silver Spring MD
    Any update?
  9. Baddkty
    Baddkty Senior Hellcat Member
    May 1, 2016
    82
    33
    You may want to make sure when they did the mid muffler delete and that it's not rubbing on your drive shaft. That will create what your feeling. It could have came just a tad lose over time and is now rubbing on floor board or drive shaft. Had this happen on my GT 500.
  10. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,807
    972
    Suwanee, Georgia
    I had similar issue to your description. I change DS and my DS was touching exhaust. I used hammer then vibration/grinding noise went away. However, I still notice small grinding/rubbing once in while (heat shield was touching exhaust pipe). Based on input, I received on the forum today, I removed the heat shield between exhaust and DS (car is running smooth so far)
    hoping that Dealer can fix OP issue quickly
  11. alxsanz
    Jan 19, 2016
    53
    17
    Northern Jersey
    Dealer says that they don't notice anything different...I haven't had a chance to stop by and drive the car with them in it.
grinding gears at 2500 rpms
gt 500 transmission vibration 3000
