Water/methanol spray
Discussion in 'SRT Hellcat Performance' started by CATONIC, May 3, 2016.
  1. CATONIC
    CATONIC Rookie
    Mar 31, 2016
    15
    1
    Anybody done or thinking about doing a water/methanol spray
  2. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,608
    888
    Virginia
    Don't believe water compresses...might not be good thing for a blower
  3. PlumbCrazy
    PlumbCrazy Gold Member Hellcat Car Club Gold Supporting Member HCC Club Member
    Nov 15, 2015
    160
    84
    278
    Land of the Free and Home of the Brave
    Liquids do not compress. Water does expand at a ratio of approximately 1/1600 so a little water would go a long way.
  4. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,041
    2,904
    818
    What was the cause of that supercharger exploding a month ago someone posted from Facebook?
    Be careful and do your homework/research
    Can you let us know the results?
  5. TNCHARGER
    Nov 19, 2015
    1,171
    426
    258
    Water/meth injection is popular for racers that have supercharged/turbo engines. The meth is high octane and cools the air intake...the water is mixed in for safety...cant remember the safe point but around 50/50..
    I used water/meth injection on the 2006 SRT10 I supercharged. Worked well but to get any real advantage you need the engine tuned for it. Mine was and it was good for about 3 tenths off my qtr ET.
    If you have it tuned correctly and the correct nozzles it will add HP..disadvantage is if something happens to the injection system (ie pump) it can cause a lean out condition while at WOT which can lead to a blown engine..
  6. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,773
    929
    563
    Lawrenceville, NJ
    I did it on my Cat, tried a Snow stage II kit. Had a 50/50 mix, dual nozzles, and it did very little, like maybe 5 HP gain (at best). I took it off, it is on the shelf.
    It is called running the blower wet, when you inject before the blower. HHP briefly played with it on my set up, Josh and Top Cat are not fans of it, I took it off.
    • Useful Useful x 2
  7. HadesGata
    HadesGata Gold Member
    Apr 8, 2016
    156
    103
    Overall it's a great safety net if tuned properly, centrifugal supercharger applications use it very successfully injected downstream. Pooling may be an issue injecting it upstream though.
  8. Rocky_Rhode
    Rocky_Rhode Senior Hellcat Member
    Oct 20, 2015
    87
    50
    The only advantage I could see is "IF" and its a big if, you are unable to get high enough octane; better to use a Nitrous setup as you get the same cooling effects and the added bonus of more fuel to burn. You still need a custom tune, and cooler plugs with shorter electrodes to aid in preventing pre-detonation.
  9. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,541
    590
    423
    I've played with water a bit on my diesels. We rarely used it for power, but the cooling effects were incredibly. Heat soak was eliminated. The water/steam will raise your compression ration slightly and on a supercharged motor, will make the charger more efficient. Will raise boost.
    On a dyno run, not much is gained, but I would bet a road course, there would be incredible cooling benefits.
    I haven't played with it on my car yet, so this is all just from general knowledge and previous experience.
    On our diesels we ran 100% water for cooling.
    At 75lbs of boost, you'll take all the cooling you can get your hands on. Heh
hellcat methanol injection
methanol on hellcat
water methanol helcat
