What are you running for tire pressure?
Discussion in 'Dodge Challenger SRT Hellcat' started by Frehley6986, Jun 14, 2015.
  1. Frehley6986
    Frehley6986 Active Hellcat Member
    Jan 18, 2015
    107
    27
    28
    I believe I read that 32PSI is the magic number. I did set all the tires to that but it always seems to creep up to 36-38PSI. High speed run this week on a closed off section of an airport so I'm curious to anyones thoughts.
    Thanks
  2. darin skelly
    darin skelly Silver Member
    Oct 29, 2014
    283
    86
    I do a lot of track time on my other cars. Best bet is to keep at manufacturer setting and the creep up is expected.
  3. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,770
    Wisconsin, USA
    Depends what you are doing with the car.
    on the street I have mine bumped up from what the sticker on the door panel says but under the max on what the tires side way says.
    If you run the Auto cross stuff they run extreme high pressures.
    Drag strip some guys air down the rear tires.
  4. BIG DAWG
    BIG DAWG Hellcat, 1st Florida Cavalry Hellcat Car Club Gold Supporting Member HCC Charter Member HCC National Exec. Director
    May 4, 2015
    1,972
    1,675
    798
    Florida Panhandle
    Absolutely agree for general driving. Many complain about lack of hook up or being too hard of a compound...all of which are well founded for most anything beyond daily/ occasional driving. With stock I have ALWAYS found manufacturer suggested pressures the best for longevity and handling.
  5. Frehley6986
    Jan 18, 2015
    107
    27
    28
    Mainly just routine driving. Although I am scheduled to make some high speed runs.
  6. NinjaChicken
    NinjaChicken Gold Member
    Nov 13, 2014
    156
    85
    278
    Malvern, AR
    I found the stock tire pressures are about the best, i tried dropping them at the track my times got worse....
  7. 70Cuda
    Oct 19, 2014
    4,771
    1,770
    Wisconsin, USA
    dropping the pressure with street tires does not work so well now DRs its different.
  8. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    37 psi - right front
    35 psi - left front
    28 psi - rears
    Why? The car has always pulled to the right. I've had it to the dealer 3 times and the last time they adjusted the engine cradle...making it worse. I gave up and adjusted the air pressure and I'm watching for tire wear. BTW, it still pulls right consistently.
    My rears are Cooper 305/35s, which really suck. I'm hoping a little less pressure will improve the contact patch. Honestly I haven't noticed any difference. Guess I'll put them back up about 32-35.
  9. Frehley6986
    Jan 18, 2015
    107
    27
    28
    I just checked mine today with a guage. They were basically 32psi on the dot. The sensors are not reading correctly. I don't know if there is a reset for recalibration or not but the car's reading is incorrect.
    I remember when I first adjusted the pressure it did recalculate but now it's back to the old readings and the pressure is 32 not 36-38 on all tires.
    Weird
  10. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,382
    768
    Slinger Wisconsin
    40 psi
  11. Barry M Nimtz
    Barry M Nimtz Silver Member
    Sep 18, 2014
    273
    115
    Onalaska, WI
    All 4 on short or long cruises all remain @ 35. No changes.
  12. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Road racing or anything with corners, max PSI for the tire. That's what the CLEET law enforcement teaches you. Harder sidewall, less chance of the sidewall rolling and pulling the bead off the wheel. Drag racing, on drag radials I've seen 25-28psi seems to be the sweet spot (for the back tires only). Put nitrogen in your tires and the pressures won't change with temp changes. Any respectable tire shop now has nitrogen. They will vacuum out the air and replace it with nitrogen and put a green valve stem cap on them. I've ran it in all my cars/trucks for a few years now and never have to check tire pressure anymore. Doesn't drop in the cold winter weather, doesn't rise in the heat of summer.
    • Useful Useful x 2
  13. B5 Blue
    1,745
    32 cold
  14. kenhebe
    kenhebe Silver Member
    Jun 24, 2015
    519
    120
    Have you ever gotten an alignment spec sheet printed out? If so please post it or PM me with it. That will tell you what if any issue you have.
  15. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    70.196059, -148.559760
    What don't you like about the Coopers?
2016 hellcat tire pressure
dodge challenger srt tirepressure
hellcat front tire air pressure
tire air pressure on a 2016 hellcat challenger
what tire pressures do they run at the srt driving experence
