WHAT IS BEST RPM SETTING FOR LAUNCH CONTROL?
Discussion in 'SRT Hellcat Performance' started by VAL, Feb 2, 2016.
  1. VAL
    VAL Silver Member
    Dec 22, 2015
    140
    57
    178
    So this will vary based on a number of factors, but has anyone run multiple tests with an A8 Challenger, stock "summer tires", non-prepped surface (street), in warm summer weather 80-90 degrees? Have you timed your 0-60 to see what rpm setting works best? All (constructive) input welcome.
  2. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,136
    746
    LC= worthless for the Automatic....dont know anyone who is using it at the track or has talked about it here
    Automatic is more about feeling the gas pedal and easing it down just right......
    LC is for Manuals
    my best 0-60 on the street is 3.5 (a few times) and best at the track is 3.4 (some get 2.9)
    i have DR's
  3. VAL
    VAL Silver Member
    Dec 22, 2015
    140
    57
    178
    Interesting. I just assumed the computer would do a better job than I would. I will have to compare to see. Are you launching in 1st or 2nd gear?
  4. huggytree
    Nov 22, 2014
    3,136
    746
    1st....i tried 2nd gear at the track....my times were worse
    you dont need to start in 2nd......
    its all about easing your car into it.....with my 2011 392 i could pretty much just floor it.....but with 707hp you cant.....by 3rd gear(60 mph) my foot is to the floor....maybe a bit sooner....just slow and steady pushing it down more and more.......1st try is always 3.9-4.0.....now the tires are heated...next runs are 3.6-3.8....ive done it over and over getting 3.6 3-4x's in a row.....occasionally i get a 3.5
    dont spend 1 more sec. on the TC idea....launching a A8 at 3,000 rpms will result in nothing happening.....you need to start at 1,000 or your tires will just spin
    the computer is for TC...keeping you alive if your an idiot (like me)....doing something stupid on a twisty road (like thinking you have a Z06 when you have a 4,400 brick)
  5. VAL
    VAL Silver Member
    Dec 22, 2015
    140
    57
    178
    Sounds reasonable... :) Thank you and if all else fails, there is always LC. :)
  6. huggytree
    Nov 22, 2014
    3,136
    746
    you let me know if LC ever gets you below 4 seconds 0-60......i suspect you will just spin
  7. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,216
    281
    Forgot LC
    2nd gear start ease throttle down quickly and smoothly, you need to ride the line between accelerating as hard as you can without the tires breaking loose.
    On the stock tires I got a 1.79 60' foot time on the drag strip that way. (0-60 in 3.4 seconds)
    On the street got a 3.6 seconds that way with full 32 psi in the tires.
    1st gear is only useful if on a Drag Strip (which has sticky VHT applied to launch area) with wider than stock DR's on too.
  8. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,477
    473
    408
    The Boonies
    with drag radials starting in 1st feathering the pedal i got 3.3 sec 0-60
  9. MeanMachine
    MeanMachine Hellcat Member
    Apr 1, 2015
    30
    12
    Sorry to be a bit dense, but are you referring to starting in second gear with a manual or with an auto. If auto, how are you doing that? Are you auto shifting each gear or is there a way to start out an auto in second and let the car shift itself from there?
  10. Bandit
    Bandit Gold Member
    Jun 20, 2015
    975
    312
    When you hit your paddles to engage the paddle feature, hit the right paddle and it'll go to 2nd gear.
  11. Bandit
    Bandit Gold Member
    Jun 20, 2015
    975
    312
    I played with LC right after the feature opened up (after 500 miles), and it wasn't helpful, even at the lowest rpm setting. I still shredded the tires. Not as much as launching at WOT on my own, but you can't launch a car this powerful at WOT anyway.
    I think that maybe with DRs and the lowest rpm setting, maybe it might be a little helpful, but I can't speak to that.
  12. MeanMachine
    Apr 1, 2015
    30
    12
    Yes. But will the car shift itself from there or do you have to use the paddles?
    QUOTE="Bandit, post: 344617, member: 3346"]When you hit your paddles to engage the paddle feature, hit the right paddle and it'll go to 2nd gear.[/QUOTE]
  13. Driver72
    Mar 10, 2015
    1,216
    281
    2nd in an auto.
    When you come to a stop, just hit the + paddle, you'll go into 2nd.
    Use left foot on brake and right on the throttle.
    Lift left foot off brake just as you start to engage throttle slowly and smoothly.
    Keep getting into the throttle to and avoid wheels spinning.
    By the time you are doing 50 mph or so you should be able to be to the floor.
    Then just keep your foot planted, it will shift for you from there on.
    Don't go into "manual' mode otherwise you need to shift with the paddles and nail it just right or you will bounce off the rev limiter, and if you hit the paddle too early you won't get the very best acceleration.
    Paddle shifting is fun, but the computer does the best job of shifting when you want max acceleration.
2015 hellcat higest rpm launch control setting
best rpm to launch the charger hellcat
best setting for lunch control rpm light for hellcat
challenger launch control
helpcat launch rpm
how to drag race a hellcat start in second gear
lauch rpm on hell cat
launch control settings
